Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
98 registered members (4WD, 53' Stude, 240_Ed, AandPDan, 97f150, 11 invisible), 2,244 guests, and 30 spiders.
Topics296,643
Posts4,956,486
Members66,950
Most Online2,577
Jan 14th, 2019
(Video) Head Gasket Test #4532036
10/02/17 12:08 PM
10/02/17 12:08 PM
Venezuela, South America
Emanuel Offline OP
Emanuel  Offline OP
Iīve been loosing coolant on my 01 Corolla, I have already replaced the radiator cap and the lower radiator plastic tank because it had a leak there. I decided to bleed the system again and accelerate the car to see if there was a presence of bubbles when doing that, wich could indicate a faulty head gasket or cracked cylinder head.
I recorded a video so you can help me to determine whether it looks normal or not. Personally I would say that combustion gasses arenīt entering into the cooling system because I donīt see that much bubbles, but I would like to know your opinion.
https://youtu.be/MZU7ukFwCFQ
Re: (Video) Head Gasket Test [Re: Emanuel] #4532049
10/02/17 12:25 PM
10/02/17 12:25 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
One way to know for sure if you're getting combustion gases in the AF is to test it with a combustion gas leak tester. If it is shows then all likelihood you have a compromised head gasket. However, you could still have a bad head gasket even if no combustion gases.
Perhaps best place to start is to pressure test the system, if there is one that should show where leak is.
Re: (Video) Head Gasket Test [Re: Sayjac] #4532073
10/02/17 12:50 PM
10/02/17 12:50 PM
Emanuel Offline OP
Emanuel  Offline OP
A combustion gas leak tester isnīt avaible here, but I need to find a place that can pressure test the cooling system. This problem has been really annoying.
Re: (Video) Head Gasket Test [Re: Emanuel] #4532090
10/02/17 01:14 PM
10/02/17 01:14 PM
USA
mk378 Offline
mk378  Offline
USA
Bleed the system and put radiator cap on. Stop engine and wait until completely cold.
Take radiator cap off and confirm it is completely full. Start engine and rev it with cap off (no funnel). There should be no action in the radiator.
Re: (Video) Head Gasket Test [Re: Emanuel] #4532157
10/02/17 03:26 PM
10/02/17 03:26 PM
Michigan
khittner Offline
khittner  Offline
Michigan
You don't have to have coolant hitting the ground to have a leak in the system other than the head gasket. I had a slow loss of coolant in my '10 Hyundai, and my local dealer supposedly pressure-tested the system and found no leak. Months and several top-offs later, my regular mechanic found the tell-tale coolant staining the upper corner of the radiator, obscured by the fan shrouding. A new Denso radiator from RockAuto ($90 to my door) and I think I'll be good-to-go for many miles. Your 16-year old cooler has probably gone as far as you can reasonably expect.
