Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
Why buy low mileage tires?
by HowAboutThis
06/17/18 05:49 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
17 registered (Exhaustgases, FT92, dishdude, GrtArtiste, FordBroncoVWJeta, ctechbob, 2 invisible), 717 Guests and 39 Spiders online.
65258 Members
67 Forums
285504 Topics
#4531888 - 10/02/17 09:23 AM Brake pedal - hard at startup
Chester11 Offline
Loc: PA
Hi folks:
Slow motion brake job here - I have been messing with the brakes on an 07 Mazda 6i for going on a month. Replaced the front pads, brake fluid change / flush, and did couple bleeds to removed any air.
Now the pedal is hard before startup - which is different than before. After starting it drops slightly, and everything feels normal.
Does this indicate a master cylinder or vacuum booster leak, or did I just have a ton of air in the system?
For background - the pedal originally felt squishy under braking (like there was air in the system), and I did all this to improve the initial "bite." After a few bleeds and activating the ABS a couple times, it feels better, except for when I first get in and turn the car on.
Thanks guys - this is probably my 4th or 5th post on this - and the input has been helpful.
#4531957 - 10/02/17 10:42 AM Re: Brake pedal - hard at startup [Re: Chester11]
Alex_V Offline
Loc: Campbellsville, KY
Having no knowledge of your particular car but speaking on general principles - it's
normal for the pedal to drop once engine vacuum comes in and increases the amount of assist via the booster.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 112K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 167K
'67 Suburban, 350, 331K
#4531966 - 10/02/17 10:56 AM Re: Brake pedal - hard at startup [Re: Chester11]
mightymousetech Offline
Loc: Ontario, Canada
If it is really hard before you start it, you may have a leaking check valve in the brake booster.
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4531994 - 10/02/17 11:58 AM Re: Brake pedal - hard at startup [Re: mightymousetech]
i_hate_autofraud Offline
Loc: Canada
Yup! I've seen leaking vacuum check valves on the booster before!
#4531998 - 10/02/17 12:01 PM Re: Brake pedal - hard at startup [Re: mightymousetech]
Chester11 Offline
Loc: PA
Thanks...not seeing a check valve in any parts diagrams, maybe it's built into the booster?
I'm also looking around for leaks. Haven't found any yet....
#4532003 - 10/02/17 12:04 PM Re: Brake pedal - hard at startup [Re: Chester11]
meep Offline
Loc: Southeast
either the check valve, or the booster is leaking down itself.
-m
2018 F150
2015 crv (wifey!)
2009 s60 2.5T
#4532006 - 10/02/17 12:07 PM Re: Brake pedal - hard at startup [Re: Chester11]
bdcardinal Offline
Loc: Santa Barbara, CA
The check valves are either part of the port where the vacuum line connects or part of the vacuum line.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#4532008 - 10/02/17 12:09 PM Re: Brake pedal - hard at startup [Re: i_hate_autofraud]
JHZR2 Offline
Loc: New Jersey
That was going to be my guess. Ive had cars that do this after a short while, others that are soft after forever... Too long to assume that vac is maintained.
But nothing that OP did would point me to damaging the check valve or booster...
Which to me would point to air in the system that was removed.
#4532021 - 10/02/17 12:35 PM Re: Brake pedal - hard at startup [Re: Chester11]
Usually part of the large vacuum line going to the engine.
Mighty Mouse Tech
Acura Tech
#4532079 - 10/02/17 01:56 PM Re: Brake pedal - hard at startup [Re: mightymousetech]
440Magnum Offline
Loc: Texas
Yep, its usually in the fitting itself. It doesn't matter if the check valve leaks down SLOWLY, so long as it will at least hold for a few minutes. Leaking down overnight isn't a concern, IMO. But you DO want to be sure that it holds vacuum during any periods of wide-open throttle so that you have boosted brakes if you have to stand on the brakes right after a WOT burst. You don't want a delay while vacuum builds, or worse, no power brakes if the throttle sticks open!
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
#4532113 - 10/02/17 02:59 PM Re: Brake pedal - hard at startup [Re: Chester11]
Chester11 Offline
Loc: PA
Thanks guys - I think I actually found the check valve. It appears to be in-line within the vacuum hose, a little bit away from the brake booster. It's about 3 inches long, looks like a regular hose, but is reinforced, and has rusted clamps on either side. This actually works to my benefit because it is right on top winking at me.
I have been chasing what I think is a vacuum leak anyway, so if I can find the part, I may just replace it along with the clamps.
Finding the part will be the problem since I can't even find a hose diagram. (The ford part guys get all confused when I show up looking for Mazda parts).
#4532372 - 10/02/17 08:08 PM Re: Brake pedal - hard at startup [Re: Chester11]
Loc: Canada
Yeah, the bellows in the booster can have a small tear or fatigue crack allowing air to leak.
