How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
108 registered members (4WD, AandPDan, advocate, aircooled, 2003f7, 53' Stude, 13 invisible), 2,296 guests, and 55 spiders.
Topics286,017
Posts4,900,829
Members67,548
Most Online2,967
Mar 10th, 2019
Unused Ecogard X4612 Cut Open #4531613
10/01/17 09:50 PM
10/01/17 09:50 PM
Indiana
5AcresAndAFool Offline OP
Indiana
I decided to dissect a new Chinese Ecogard filter. I am big on using American made parts if the quality is there even if the price is higher (within reason), so I would likely not consider these filters as long as you can get an American made filter for a reasonable price. (Ignore the fact my fleet is composed of two Toyotas...Though one is made here in Indiana.)
None of vehicles I have even use this filter, but it was the cheapest one on amazon I could find. One of the vehicles this filter fits is a Honda S2000. Now would I go zinging my s2000 to 9k rpm with the ecogard filter protecting it?.... Probably wouldn't kill it, but I wouldn't.
Anyway, I found a few issues that would preclude me from using the ecogard vs. say a Orange fram for a few bucks more, even if it strictly came down to only dollars and cents.
Im curious what every thinks.
"Premium" Oil filter. Its a nice touch to have the cross reference on the box.
Plastic seals the can. Its a long ride from China, got to keep those creepy crawlies out.
Looks Good so far.
A relatively young sample. I got this off Amazon for 1.88 as an add on item.
The sybols Get the point across. Note the arrows that indicate quarter turn revolutions on filter.
The ADBV was soft and pliable. No cuts or imperfections noted.
The inside has the slightest residue inside. It didn't feel oily.
Soapy water residue? It didn't wipe off using light pressure.
Pleats are uniform and plentiful.
Sloppy Glue Job.
Blowing on the Bypass valve it seemed like a little bit of air leaked thru thru. It was hardly a scientific test though.
I cut the media away to get a better look at the glue job.
The flange where the threads were tapped were very rough and I was concerned that a flake could possibly come off, but everything seemed secure. Still though I feel its concerning.
The Ecogard tap plates compared to two frams. The frams have a much better finish and quality. The roughness is not there on the frams.
The Media seems thin.
The centertube is flimsy and does not have a solid edge on the ends, but it gets the job done.
I noticed some molding flash on the pressure relief valve.
A closeup of the flash. I was able to dislodge some by running my finger over it a few times. I feel this easily could become dislodged and end up going into the engine. Probably wouldn't hurt anything though...
You can see where the bypass sealed off center on the endcap, it was close to the edge of not sealing at all. But in the end it appears to have sealed.
Re: Unused Ecogard X4612 Cut Open [Re: 5AcresAndAFool] #4531620
10/01/17 09:58 PM
10/01/17 09:58 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
Thanks for the pics. I wonder if they do the leak testing with air? It would have to be air right?
Re: Unused Ecogard X4612 Cut Open [Re: 5AcresAndAFool] #4531630
10/01/17 10:14 PM
10/01/17 10:14 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
About the same as what I found when I cut mine open, but I am using them. I have one on my truck right now.
I mean it is a <$2 filter.
Yes, they said they use air when doing leak testing when I contacted them.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Unused Ecogard X4612 Cut Open [Re: Reddy45] #4531637
10/01/17 10:22 PM
10/01/17 10:22 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
... I wonder if they do the leak testing with air? It would have to be air right?
I'd bet their leak testing checks only the can-to-base seam, not the valves or any other possible points of internal leakage.
2011 Toyota Prius now at 97K
Re: Unused Ecogard X4612 Cut Open [Re: 5AcresAndAFool] #4531640
10/01/17 10:25 PM
10/01/17 10:25 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
I doubt any issues running it but I think a Napa proselect for likely 3$ +/-, is far superior. The proselects also have the plastic covering on them, I do wonder if its to keep the nitrile adbv good in some way? Toyota OEM filters have the plastic too, but they are prelubed.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Unused Ecogard X4612 Cut Open [Re: Rolla07] #4531654
10/01/17 10:37 PM
10/01/17 10:37 PM
Indiana
Indiana
Do you know who makes the proselect? I always figured the plastic was to keep bugs and moisture out of the filter when it's on the slow boat from china.
It certainly does the job, especially for under 2 bucks, but if I was going based on cost vs quality Id say a Fram orange can wins out in my book, or the Napa filter. I feel better using a u.s. made filter.
I could see a some shops using ecogards because the savings add up, but at what cost...
Re: Unused Ecogard X4612 Cut Open [Re: 5AcresAndAFool] #4531657
10/01/17 10:41 PM
10/01/17 10:41 PM
Indiana
Indiana
Would it be better in the long run to buy a Fram ultra and run it 30k miles vs an ecogards for 5k? It would certainly be cheaper.
I'm curious what an ecogard with 10k miles on it would look like.
I will try to find some performancespecs on ecogards. I seem to remember reading here that they were 80 some percent efficient at 30 microns.
Re: Unused Ecogard X4612 Cut Open [Re: 5AcresAndAFool] #4531691
10/01/17 11:48 PM
10/01/17 11:48 PM
blupupher Offline
blupupher  Offline
This blue ECOGARD Premium Oil Filter is 98.8% efficient > 30um and 87.97% efficient > 20um per the rep I contacted.
Their Synthetic+ filter (a silicone ADV/syn blend media) is 99.9% @ 25 microns.
Re: Unused Ecogard X4612 Cut Open [Re: 5AcresAndAFool] #4531776
10/02/17 05:47 AM
10/02/17 05:47 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Thanks for the very detailed dissection of that filter along with excellent pictures.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Unused Ecogard X4612 Cut Open [Re: 5AcresAndAFool] #4531844
10/02/17 07:59 AM
10/02/17 07:59 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Looks like a beater car special, not sure I would use this on an engine under warranty, or even one I cared much about-you're not going to have any warranty. Lucky if you got paid for the damage in Renminbi!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Unused Ecogard X4612 Cut Open [Re: 5AcresAndAFool] #4531883
10/02/17 09:17 AM
10/02/17 09:17 AM
New York
pbm Offline
pbm  Offline
New York
I would prefer this filter over a torn Purolator...otherwise, I'd probably use an ST by Wix. Because both of my Ford's have the PITA to remove 'bellypan'....I'm starting to think of running an FU (or other premium filter like the Bosch D+ that I bought on Clearance) for 2 OCI's, using my Mityvac for a top-side oil change.
'Journalism is Dead'
Re: Unused Ecogard X4612 Cut Open [Re: 5AcresAndAFool] #4546166
10/17/17 11:45 AM
10/17/17 11:45 AM
Maryland
Triplicate Offline
Triplicate  Offline
Maryland
I bought 10 of these exact filters on Amazon for 18 bucks back in June. I have one on a 2010 Sentra with the MR20DE engine and one on a 2011 Rogue with the QR25. Both running Magnatec 10w30 at a 5k OCI.
No issues yet. If anything goes sideways I'll post pics.
