2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
106 registered members (240_Ed, 1foxracing, Bailes1992, bandito, Astro14, 11 invisible), 1,701 guests, and 38 spiders.
Topics295,211
Posts4,930,031
Members66,711
Most Online2,553
Oct 27th, 2018
DOT Brake Fluid #4531263
10/01/17 02:37 PM
10/01/17 02:37 PM
WA
Skitter302 Offline OP
WA
I will be flushing the Brake fluid in my 1991 Ford Bronco soon and I wanted to use a fluid with a higher boiling point then DOT 3. While looking up Brake fluid I found mention of a DOT 5.1 fluid.
I know that DOT 5 is silicone based and is not compatible with any other DOT brake fluid. I was planning on just going with DOT 4 but Everything that I can find says that DOT 5.1 is glycol-based so putting that in my system is no big deal. And I don't have a ABS system so I have no need for DOT 4 LV. I'm now wondering about DOT 5.1 and I'm wondering if their are any things I should worry about before switching?
If nobody has any experience with this I'm happy to be the Guinea pig.
"Skill is when luck becomes the usual."
Re: DOT Brake Fluid [Re: Skitter302] #4531264
10/01/17 02:38 PM
10/01/17 02:38 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
As long as it is 5.1 you will be fine.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: DOT Brake Fluid [Re: Skitter302] #4531276
10/01/17 02:52 PM
10/01/17 02:52 PM
Canada
i_hate_autofraud Offline
Canada
Just for fun I pushed my brakes with hi speed stops I would never make then
measured the rotor temperatures, they came in at 200F 210F, lower then I thought,
with normal stop and goe driving, I was down to 160F!
The bigger issue is regular brake fluid changes since the fluid is very hydroscopic
and wants to suck moisture out of the air and corrode the lines and calipers from the inside.
For years on older car brake jobs, I saw lots of corrosion pitting in wheel cylinder bores
and black crud that was actually rubber piston ring material that wore off and went into the
fluid! So old fluid is capable of corrosion damage even when not immediately exposed to air!
Very old brake fluid is often black and may even have visible metallic bits in it! The boiling
point is something that's far less of a problem then scaremonger suppliers want you to believe!
Re: DOT Brake Fluid [Re: Skitter302] #4531290
10/01/17 03:02 PM
10/01/17 03:02 PM
USA
slacktide_bitog Offline
USA
You can use DOT 5.1 with no worries smile
I use it in my car.
Re: DOT Brake Fluid [Re: Skitter302] #4531300
10/01/17 03:08 PM
10/01/17 03:08 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Yup, DOT5.1 came out partially for the compatibility with older fluids.
Kind of a waste as a top off fluid, but since you are doing a flush, 5.1 is a great choice.
It is what I am putting in my bike's clutch and brake fluid when I flush it.
2018 Hyundai Santa Fe: Dealer oil and filter/5k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: GTX HM 5w-20, EcoGard, 1yr
1994 Honda VT1100c: Peak 15w-40, PSL, 5k
Re: DOT Brake Fluid [Re: i_hate_autofraud] #4531319
10/01/17 03:25 PM
10/01/17 03:25 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
For Dot 4, it's more hydroscopic than regular Dot 3. Most manufacturers that use it recommended 2 or 3 year brake flushes. You can go for much longer on Dot 3 without changing it. Not sure if 5.1 is worse. You don't really need a fluid with a high boiling temperature if you're not going to get it up to that temperature.
Re: DOT Brake Fluid [Re: Skitter302] #4531339
10/01/17 03:43 PM
10/01/17 03:43 PM
USA
ArcticDriver Offline
USA
Why do you think DOT-3 offers insufficient boiling point for a 1991 Ford Bronco?
Do you use it for extreme applications?
Multiple Diesel and Gasoline vehicles
Re: DOT Brake Fluid [Re: ArcticDriver] #4531353
10/01/17 04:03 PM
10/01/17 04:03 PM
WA
WA
Correct, My use is above normal and is very performance related. No proof if I exceed DOT3 Specs but I want to upgread and just wanted to confirm flud compatibility before I gel'd up my system.
Re: DOT Brake Fluid [Re: slacktide_bitog] #4531354
10/01/17 04:04 PM
10/01/17 04:04 PM
WA
WA
I use it in my car.
Thanks for the Feed Back!
Re: DOT Brake Fluid [Re: Skitter302] #4531357
10/01/17 04:06 PM
10/01/17 04:06 PM
USA
USA
Understandable. grin
Re: DOT Brake Fluid [Re: Skitter302] #4531546
10/01/17 07:10 PM
10/01/17 07:10 PM
Vancouver, Canada
dubber09 Online content
dubber09  Online Content
Vancouver, Canada
I switched to 5.1 on both our cars as well as did same on my daughter's 2008 Acura. No issues, will be changing it every 2-3 years anyway.
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Re: DOT Brake Fluid [Re: Skitter302] #4531575
10/01/17 07:40 PM
10/01/17 07:40 PM
NY
demarpaint Offline
demarpaint  Offline
NY
So there's no benefit in using a Dot 4 brake fluid in a Dot 3 application?
God Bless Our Troops
Re: DOT Brake Fluid [Re: demarpaint] #4531593
10/01/17 08:10 PM
10/01/17 08:10 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
There are benefits and drawbacks. Higher boiling point, but more hydroscopic than Dot 3. Cost is higher and needs more frequent flushing. So if you need it, be prepared to pay for it.
Re: DOT Brake Fluid [Re: Skitter302] #4531639
10/01/17 09:24 PM
10/01/17 09:24 PM
Oklahoma
CELICA_XX Offline
CELICA_XX  Offline
Oklahoma
Al Cowlings should have used 5.1
15 Toyota Prius - M1 EP 0w20 SN+
02 Toyota ECHO - Valv MaxLife Full Syn 5w30 SN+
97 Lexus LX450 - M1 EP HM 5w30 SN+
93 Lexus LS400 - Valv MaxLife Full Syn 5w30
Re: DOT Brake Fluid [Re: Wolf359] #4531706
10/01/17 11:08 PM
10/01/17 11:08 PM
WA
WA
I'd use DOT 4 but they don't sell the good blue stuff any more and all I can find is TYP200.
