better day
by mx5miata
06/19/18 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
06/19/18 05:17 AM
People Watching ....Airport style.
by ZZman
06/19/18 04:24 AM
Subaru's at play...
by OneEyeJack
06/19/18 03:50 AM
Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
43 registered (bradepb, BoiseBound, bbhero, das_peikko, CleverUserName, Char Baby, 7 invisible), 872 Guests and 39 Spiders online.
65265 Members
67 Forums
285578 Topics
Page 1 of 2 1 2 >
#4531166 - 10/01/17 01:07 PM Diesel truck; short tripping vs leaving it parked
Seventh Offline
Loc: NorCal
Which is worse?
Truck is a 1994 Ford IDI factory turbo F250 with 84k miles, in perfect condition. I'm always looking for reasons to drive it, but so far this year I've only put about 1800mi on it. It sits around a lot.
I sometimes drive it to work, but it's only 2 miles from my house, so it doesn't get up to temp. When I need it to work, I work it hard (heavy loads/towing), but otherwise it sits or gets short tripped. I don't have time to drive it just for fun.
Currently has about 1500mi on delo synthetic 5w40, which I'll likely leave in until at least next year. Severe service interval is 2500mi, "normal" interval is 5k miles.
So what say you, bitog? Short trip it or let it sit?
#4531178 - 10/01/17 01:24 PM Re: Diesel truck; short tripping vs leaving it parked [Re: Seventh]
motor_oil_madman Offline
Loc: Houston, Texas
Why not ride your bike to work? Honestly it's not going to hurt it.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#4531179 - 10/01/17 01:25 PM Re: Diesel truck; short tripping vs leaving it parked [Re: Seventh]
ArcticDriver Offline
Loc: USA
Only my opinion but short tripping of under 20 miles is best avoided since these trucks take so long to get up to operating temp.
1) The batteries never have a chance to recover the voltage used in starting and cycling glow plugs.
2) The engine and transmission never have a chance to get up to operating temp and burn off condensation and fuel.
I don't see any harm with leaving in the DELO 400 5w40 as long it is the LE variety. As you mention it is full synthetic and is actually good for 5,000 miles severe duty according to most Powerstroke forums.
BTW, you have a great looking low miles truck.
Multiple Diesel and Gasoline vehicles
#4531181 - 10/01/17 01:30 PM Re: Diesel truck; short tripping vs leaving it parked [Re: motor_oil_madman]
Seventh Offline
Loc: NorCal
I do normally ride my bike haha. Unless it's over 100 degrees, raining, or I have errands to run after work or at lunch
#4531200 - 10/01/17 01:53 PM Re: Diesel truck; short tripping vs leaving it parked [Re: ArcticDriver]
Seventh Offline
Loc: NorCal
My concern with leaving it parked (often for a month+) is the crank settling into the bearings and causing excess wear on start up. The longer it sits, the more clackety it sounds when I fire it up, which I'm sure is valve train noise also, but it makes me cringe.
Yes it is the Delo LE synthetic, and thank you. It was a once in a lifetime find, got it from the original owner several years back with only 73k miles!
#4531209 - 10/01/17 02:02 PM Re: Diesel truck; short tripping vs leaving it parked [Re: Seventh]
JMJNet Offline
Loc: TX, USA
Go on a scenic route to work instead of the 2 miles.
Leave a little early or come back after work in a scenic route aka longer route.
  • 2017 Toyota Sienna
#4531212 - 10/01/17 02:08 PM Re: Diesel truck; short tripping vs leaving it parked [Re: ArcticDriver]
gathermewool Offline
+1 on all counts.
#4531232 - 10/01/17 02:42 PM Re: Diesel truck; short tripping vs leaving it parked [Re: JMJNet]
Seventh Offline
Loc: NorCal
The problem with that is, in order to get any significant miles on it, I'd have to get on the freeway, which is very close to me, but is ridiculous traffic before and after my work hours, and even on surface streets in the area.
So much so that riding my bike to work takes only a few minutes longer than driving.
I try to use it for family activities on weekends, but with a 3 year old to cart around, it's a lot more convenient to use my wife's Forester. Although she does like us using it in the summer, as it has the best AC out of all our vehicles.
#4531259 - 10/01/17 03:26 PM Re: Diesel truck; short tripping vs leaving it parked [Re: Seventh]
Loc: USA
I can appreciate that concern.
I wonder if someone can suggest an oil that offers superior long-term adhesion.
If you are unable to set aside 30 minutes early Saturday/Sunday every 2-3 weeks then I think plugging in the block heater 2-3 hours before start-up might help the oil flow more quickly immediately after start-up.
#4531332 - 10/01/17 04:38 PM Re: Diesel truck; short tripping vs leaving it parked [Re: Seventh]
Loc: USA
One other consideration would be to turn off the O/D when you do drive since it will result in higher RPMs and reaching operating temp in fewer miles.
#4531425 - 10/01/17 06:17 PM Re: Diesel truck; short tripping vs leaving it parked [Re: Seventh]
Boczech Offline
Loc: Norcal
Which is worse?
Good looking rig you have there. I would take it out on a trip and run it if you plan on keeping it. Napa area one weekend then the Sierra's , etc.
1996 Dodge RAM 2500 5.9l diesel
#4531439 - 10/01/17 06:25 PM Re: Diesel truck; short tripping vs leaving it parked [Re: Seventh]
totegoat Offline
Loc: Ca
Running it once a month up to operating temp would be better than short tripping. Use lower gears to reach temp quicker.
#4531455 - 10/01/17 06:36 PM Re: Diesel truck; short tripping vs leaving it parked [Re: ArcticDriver]
Seventh Offline
Loc: NorCal
We need magnatec diesel! But all seriousness aside, I never thought to use the block heater after long periods of sitting. That's a good idea.
I've actually done that, and I do drive it like that around town in traffic, lots of stoplights, etc. It seems like it does help it warm up just a tad.
#4531479 - 10/01/17 06:59 PM Re: Diesel truck; short tripping vs leaving it parked [Re: Seventh]
philipp10 Offline
Loc: Minnesota
wow....talk about a bunch of worry warts......
#4531540 - 10/01/17 08:04 PM Re: Diesel truck; short tripping vs leaving it parked [Re: philipp10]
Seventh Offline
Loc: NorCal
Thanks. I try to get it out whenever possible. I sometimes think of selling it, but I know I'll never find another one like it.
I never said I was losing sleep over it. grin The question was; which is worse?
Page 1 of 2 1 2 >
