debris in my engine oil--what to do?
by Jasper8146. 09/22/18 03:50 PM
Is this seal bad?
by parshisa. 09/22/18 03:44 PM
Leather Masters Protection Cream review....
by gregk24. 09/22/18 03:13 PM
Aisin WS
by RodneyM. 09/22/18 03:11 PM
Husqvarna trimmer questions
by BrianF. 09/22/18 02:51 PM
Uber Self-Driv Death: Disabled Pedest Avoidance!!!!
by oil_film_movies. 09/22/18 02:29 PM
Question on Backlight setting on LED tv's
by LoneRanger. 09/22/18 02:16 PM
Are all Dexos 1 Gen 2 Oils the Same?
by Gene K. 09/22/18 01:58 PM
ECOGARD X10479 CUT OPEN
by 53' Stude. 09/22/18 01:38 PM
Rust-Oleum Driveway Sealer review
by SVTCobra. 09/22/18 01:24 PM
Flush OAT/IAT mixture
by OpenClose. 09/22/18 12:20 PM
And They Say Spelling is Not Important.
by PimTac. 09/22/18 12:06 PM
Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
electric brakes rely on heat to work?
by motor_oil_madman. 09/22/18 09:09 AM
help please 7.25 briggs idle too fast
by edwardh1. 09/22/18 08:49 AM
Java update and Flash not working
by JLTD. 09/22/18 08:47 AM
Bought a Giulia
by RamFan. 09/22/18 08:38 AM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
82 registered members (77GrandPrix, 4WD, Anduril, 2oldtommy, 14 invisible), 1,868 guests, and 39 spiders.
Topics290,833
Posts4,851,151
Members66,040
Most Online3,590
Jan 24th, 2017
Plugged Oil Filter #4531126
10/01/17 12:34 PM
10/01/17 12:34 PM
MIchigan
Warstud Online content OP
Warstud  Online Content OP
MIchigan
Can you tell if the oil filter is plugged when you drain the oil out of it. I've noticed that sometimes when draining the filter all the oil will drain out immediately. Then other times it requires placing the filter up-right (hole on top) for 10 minutes or so then flipping it over and getting more oil out of it. Thoughts.
Re: Plugged Oil Filter [Re: Warstud] #4531148
10/01/17 12:52 PM
10/01/17 12:52 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
If I suspected a filter to be plugged, I'd cut it open.
Sometimes they hold oil and sometimes they drain. I don't think there's a real explanation aside from a misbehaving ADBV.
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
Re: Plugged Oil Filter [Re: Warstud] #4531161
10/01/17 01:04 PM
10/01/17 01:04 PM
New England
gathermewool Offline
New England
It's more than likely hydro-locked due to the ADBV.
I would never even suspect a filter of being clogged in any vehicle that is moderately maintained. If it was plugged, I'd imagine there would be symptoms while it was in operation.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter
Re: Plugged Oil Filter [Re: Warstud] #4531184
10/01/17 01:33 PM
10/01/17 01:33 PM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
Definitely the ADBV. If it won't drain, jam something sharp through the inlet holes and puncture/push open the ADBV. That will usually fill the center tube with oil so it can be drained. If anything, it's a good sign when no oil comes out of a used filter until you jam open the ADBV because it means it seals good.
Re: Plugged Oil Filter [Re: Drew99GT] #4531218
10/01/17 02:15 PM
10/01/17 02:15 PM
New England
New England
It's the reason I can remove my Subaru's top-mounted, base-down filter without making any mess. Makes me feel good when I see that a "used-up" filter has a good-working ADBV.
Re: Plugged Oil Filter [Re: gathermewool] #4531229
10/01/17 02:33 PM
10/01/17 02:33 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Can or can't? So the filter is empty when you remove it?
My Tacoma has the filter mounted vertically with base down. If I don't punch a hole in the dome end to drain it, it'll puke oil upon removal.
Re: Plugged Oil Filter [Re: Warstud] #4531231
10/01/17 02:41 PM
10/01/17 02:41 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I had a pretty well plugged WIX filter (PSI drop on OP gauge), and the oil stayed inside until I cut the can.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 100K Napa 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 20K VR1 20w50, NG1515
14 RX450h 33k PP MIX, NG7047
Re: Plugged Oil Filter [Re: ZeeOSix] #4531236
10/01/17 02:57 PM
10/01/17 02:57 PM
New England
New England
Can - am able to. There is some that will drain as you remove the filter, but it is contained, by design. The filter itself doesn't leak much upon removal. The filter is heavy with oil when I put in on my drain pan. When I check however long after (weeks, usually), it feels much lighter and emptier. The filter isn't really even close to perfectly hydro-locked, so it will drain eventually.
https://www.youtube.com/watch?v=uvn-w8zW-lE
Re: Plugged Oil Filter [Re: Dyusik] #4531257
10/01/17 03:24 PM
10/01/17 03:24 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
From your other thread:
"No tears, not a thing to report other than I over loaded it. The large grit can be seen everywhere, and the cold oil pressure is now 78psi vs 60-65 @ 3K rpm."
Example of only seeing a filter restriction when the oil pressure sensor is after the filter and the PD oil pump was in pressure relief due to cold thick oil.
Once the oil got fully hot and thinned down you wouldn't be able to tell unless the filter was near 100% clogged.
Re: Plugged Oil Filter [Re: Warstud] #4531287
10/01/17 03:59 PM
10/01/17 03:59 PM
Canada
i_hate_autofraud Offline
Canada
A truly plugged filter means you have super dirty oil that should drain out with lumps,
check your oil drain pan for lots of debris, if none, the chance of a plugged filter is 1 in 10 million!
A freshly removed filter will be heavy with oil in the saturated media, even w/o a ADBV! or a 'fully drained' filter.
Re: Plugged Oil Filter [Re: i_hate_autofraud] #4531314
10/01/17 04:22 PM
10/01/17 04:22 PM
New England
New England
Not sure if this was in response to my post, but, as others have mentioned, the way to quickly drain a recently removed filter with an ADBV is to stick a screw or something into it and then set it somewhere to drain. The media will remain saturated and heavy for a long time, but not as heavy as a filter that is full of oil.
Re: Plugged Oil Filter [Re: Warstud] #4531608
10/01/17 09:40 PM
10/01/17 09:40 PM
Wa
Skanky Offline
Skanky  Offline
Wa
I just want to add everyone doing own OC should be draining the filter well before pitching it if you don't have a recycle option. I use a deck screw in the ADBV hole to push the elastomer valve open and leave it in tilted with the screw on the lowest side in the oil drain funnel until it is empty usually leave it a few weeks.
