Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
24 registered members (Aero540T, Bailes1992, anndel, DirtyOilGuy, bbhero, 3 invisible), 894 guests, and 36 spiders.
Topics295,007
Posts4,925,886
Members66,664
Most Online2,553
Oct 27th, 2018
Intermittent AC #4530840
10/01/17 03:22 AM
10/01/17 03:22 AM
NY
greasegunn Offline OP
NY
My 2010 Honda Civic with 98,000 miles is having an intermittent AC issue. The AC will work fine for approximately 20 minutes and then it stops. It seems to work longer in cooler weather and shorter in hotter weather. Once it has been parked awhile it will work again.
Some investigating on the internet indicates it may be a worn compressor clutch and the repair is fairly straightforward. The issue that Iím trying to resolve in my mind is why it is intermittent? Why does the AC work initially and then stop? If the clutch is worn why does it work at all?
Re: Intermittent AC [Re: greasegunn] #4530850
10/01/17 04:14 AM
10/01/17 04:14 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Check out this site. It's quick, you can skip ahead, and I have used this exact repair on the Mazda3 in my signature. Worked great!
https://www.youtube.com/watch?v=DNx0X4INfiw
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Intermittent AC [Re: greasegunn] #4530922
10/01/17 07:31 AM
10/01/17 07:31 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I've seen the clutch gap increase on high mileage cars and the AC quit engaging one they get hot. I've also seen the evaporator freeze up in hot weather and do exactly what you describe.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Intermittent AC [Re: SHOZ] #4530927
10/01/17 07:35 AM
10/01/17 07:35 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
Evap freezing can be caused by a low charge level.
Re: Intermittent AC [Re: greasegunn] #4530928
10/01/17 07:35 AM
10/01/17 07:35 AM
USA
mk378 Offline
mk378  Offline
USA
To diagnose, drive until it stops working then pull over (leave the engine and A/C switch on) and check whether the clutch is engaged or not. If you have freeze-up there will likely be ice on the line from the evaporator to the compressor.
The clutch is based on an electromagnet. As the magnet coil gets hotter, its magnetic output decreases slightly. This will cause a clutch that is a little too wide to stop engaging, though it works when cold.
Re: Intermittent AC [Re: HerrStig] #4530929
10/01/17 07:36 AM
10/01/17 07:36 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Or bad thermistors on the evap coil.
Re: Intermittent AC [Re: SHOZ] #4530934
10/01/17 07:41 AM
10/01/17 07:41 AM
DFW
DBMaster Offline
DBMaster  Offline
DFW
My 89 Accord did exactly that after about 100,000 miles. I could tell the clutch was energizing because a wrench would easily be held on the front of it due to the magnetism. I was unable to get the shim adjustment done because the shaft seal already had a slow leak so I ended up replacing the compressor. That car went through compressors every 100,000 miles like clockwork.
Re: Intermittent AC [Re: greasegunn] #4531019
10/01/17 08:54 AM
10/01/17 08:54 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Could be many things. Clutch gap,clutch coil,relay,expansion valve etc. Is the clutch still locked when it stops working?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Intermittent AC [Re: greasegunn] #4531055
10/01/17 09:38 AM
10/01/17 09:38 AM
Canada
i_hate_autofraud Offline
Canada
Don't forget to look at the pressure limit switches, too low, it stops, too high it stops too!
Re: Intermittent AC [Re: greasegunn] #4531104
10/01/17 11:05 AM
10/01/17 11:05 AM
WI
HoosierJeeper Offline
WI
Sounds like a clutch issue. I doubt anything would be freezing up in that short amount of time. I'd pop the hood next time it stops and see what the clutch is doing.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Intermittent AC [Re: greasegunn] #4531149
10/01/17 11:53 AM
10/01/17 11:53 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
If the AC Clutch is about to seize, you will hear screeching noise every time the AC is turned on.
In my 04 Sienna, it was running like that for about 6 months.
Then it completely seized.
At that point, it is not worth to just fixing the clutch because the price of new compressor is only marginally more than the price of just the clutch like $20-$30 difference.
Trouble is, you have to replace the condenser also since the new condenser cannot be flushed anymore, either.
  • 2017 Toyota Sienna
