More of an electrical issue than mechanical, but I'm facing a bit of a strange issue with the blinkers on my '01 Grand Marquis. There are zero issues with the turn signals when the lights are off, but if the lights are on, either automatically or manually, I have a hyper flashing issue. When you first turn on the blinker on either side, it'll flash normally for a second or two then start to hyper flash. No issue with the hazard flashers, none of the bulbs are out and I don't have LEDs or anything.
Not quite sure where to start with this one, and quite hesitant to dump crazy money on an LCM if it isn't the culprit. Any input will be appreciated, thank you!
