White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
29 registered members (billt460, claluja, c502cid, carlprop, Black_Thunder, Blkstanger, 3 invisible), 851 guests, and 33 spiders.
Topics296,866
Posts4,960,379
Members66,982
Most Online2,688
Jan 19th, 2019
GM 4L60E Whine #4530780
10/01/17 12:25 AM
10/01/17 12:25 AM
Kuwait
Falcon_LS Offline OP
Kuwait
4L60E in the Envoy that recently started whining, perhaps more like a fuel pump if I were to describe it. It doesn't happen when you first fire up in the morning, but when the transmission fluid warms up a bit, a tad over 100 F, and you lightly hit the gas taking off from a standstill, you hear the whine right away. You hear it under light acceleration from a standstill, as well as in in park or neutral. From a standstill, you can hear the whine going up to 2,500 rpm, after which it seems to disappear. As it whines in P or N, the whine disappears right away if you slap it in reverse or any other forward gear.
The unit has 115,000 miles on it. It's had very regular fluid (Dexron-VI with LubeGard) and filter (ACDelco TF-289) changes - a drain and refill every 6,250 miles and a filter replacement/pan drop every 25,000 miles. I have a Derale cooling pan, which an extra 2 quart capacity and drain plug. The reason I use a TF-289 shallow pan filter and not the 24208576 deep pan filter is because this particular pan has big cooling tubes, and you can't bolt the pan back on with the deep pan filter. The fluid is always a nice cherry red, the magnet in the pan and the magnetic drain plug are always clean.
Thinking it was the torque converter, which I did have some vibration issues with, I went ahead and replaced it. It's a lot smoother now and zero vibration issues, but it didn't resolve the whining problem. I also checked all exhaust shields, etc. whilst I was in there, just in case anything was loose and would happen to rattle - everything there is tight. Any input from GM transmissions gurus would be much appreciated - thank you!
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
03 Expedition SSV: XG2
05 Envoy: XG9837
06 XJ8L: C2C41611
07 SRX: XG8765
Re: GM 4L60E Whine [Re: Falcon_LS] #4530813
10/01/17 01:36 AM
10/01/17 01:36 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Sometimes an auto transmission will just whine, but I would take it to a ** reputable ** auto transmission shop for an inspection, bands might need alignment / tightening. The thing about auto transmissions is they are extremely robust, usually outlasting the engine (especially GM transmissions) but if there is an issue, it ** will ** get worse and it ** will ** cost more later versus right now.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: GM 4L60E Whine [Re: Falcon_LS] #4530853
10/01/17 04:18 AM
10/01/17 04:18 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Whining usually means pump is bad. They can whine for years and never quit. We found the 4L60E to either be real good for 200k miles or it blows up young...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: GM 4L60E Whine [Re: Johnny2Bad] #4530876
10/01/17 05:45 AM
10/01/17 05:45 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
The 4L60E is not exactly robust-and the heavier the vehicle it's in, and especially any towing, rebuilds come sooner than later. My concern for the OP is whining tends to be gears or other hard parts-might end up being expensive, a rebuilt replacement might end up less.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: GM 4L60E Whine [Re: Falcon_LS] #4530882
10/01/17 06:02 AM
10/01/17 06:02 AM
Kuwait
Kuwait
Thanks for the input. This truck has never towed a thing in its life, and with the very regular service intervals this unit has seen, I would have thought it would be a rather long time before anything needed attention in the transmission.
I am taking it to my transmission guy later on today - was just curious to see if anyone had any input before hand. I'm thinking more the planetary, since the pitch of the whine doesn't change with RPM, but I could be wrong. That said, if a rebuild is required, then be it. Will just bullet proof it like I did my torque converter, so I don't need to go in there again for a really long time vs. getting a reman. Did it with my 4R70W, will do it again with the 4L60E.
Given how long this transmission has been around, you would think it would be a very robust unit by now. smile
99 Explorer: H17W02
00 Pajero: XG9688
05 Envoy: XG9837
06 XJ8L: C2C41611
07 SRX: XG8765
Re: GM 4L60E Whine [Re: Falcon_LS] #4530943
10/01/17 07:53 AM
10/01/17 07:53 AM
North Carolina
Urshurak776 Offline
Urshurak776  Offline
North Carolina
I had a 1999 GMC Sierra with this transmission. All maintenance done similar to how you described. Transmission failed twice, the last of which I sold the truck at 228,000 miles. Great truck except the transmission issues. Seems they last about 110K and I didn't even really use it to tow or haul anything other than the occasional plywood from the big box store. Not So robust to me. ironically, At 220K, The water Pump Went out. Put a new One in, new belt, Etc. Then 8K later Tranny goes.
2012 Hyundai Santa Fe, 138,000 miles, Havoline Pro DS Full Syn 5W-30, WIX Filter.
2014 Kia Rio, 80,000 miles, Havoline Pro DS Syn 5W-30, WIX Filter.
Re: GM 4L60E Whine [Re: Falcon_LS] #4531069
10/01/17 09:59 AM
10/01/17 09:59 AM
Canada
i_hate_autofraud Offline
Canada
"Given how long this transmission has been around, you would think it would be a very robust unit by now."
Yup! exactly, GMs could be robust, but aren't, dealers need the work and GM bean counters and wannabe stars in the
supply chain like making things cheap! SAD!
Re: GM 4L60E Whine [Re: Falcon_LS] #4531072
10/01/17 10:13 AM
10/01/17 10:13 AM
Alberta
BigJakeChevy Offline
Alberta
426,000kms and counting on my 4L60E. grin
2007 Silverado Classic 1500 Crewcab 5.3L 460,000kms
Engine oil Mobil 1 0w40fs
Oil Filter Fram Ultra 10575
Trans Oil Amsoil Torque Drive
Front Diff Amsoil SG75w90
T-Case Autotrak II
Rear Diff Amsoil SG75w140
Re: GM 4L60E Whine [Re: Falcon_LS] #4531099
10/01/17 10:55 AM
10/01/17 10:55 AM
southwest Mo.
wtd Offline
wtd  Offline
southwest Mo.
I have a 98 chevy K1500 with this transmission and mine whines too and has for awhile. Mine has 135,000 miles on it and it's had regular tranny fluid changes. Mine has not towed much at all and nothing really heavy. I'm just going to drive it until it goes out.
I have a friend with the same truck that I do and he has right around 400,000 miles on the original transmission.
Wayne
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: GM 4L60E Whine [Re: Falcon_LS] #4531786
10/02/17 05:06 AM
10/02/17 05:06 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Yep, we have had Silverados here exceed 200k miles with nothing but occasional fluid changes.
Re: GM 4L60E Whine [Re: BigJakeChevy] #4531796
10/02/17 05:18 AM
10/02/17 05:18 AM
Texas
4WD Offline
4WD  Offline
Texas
BIL did 400k miles with regular fluid changes BUT did not tow trailer = it had tow package with cooler +++
Re: GM 4L60E Whine [Re: Falcon_LS] #4531853
10/02/17 07:20 AM
10/02/17 07:20 AM
Kuwait
Kuwait
Just an update, turns out the noise I am hearing is not from the transmission. Certainly a relief.
99 Explorer: H17W02
00 Pajero: XG9688
05 Envoy: XG9837
06 XJ8L: C2C41611
07 SRX: XG8765
Re: GM 4L60E Whine [Re: Falcon_LS] #4531895
10/02/17 08:32 AM
10/02/17 08:32 AM
Tennessee
ChevyMan93 Offline
ChevyMan93  Offline
Tennessee
What is it from then? Inquiring minds want to know! smile
2016 Chevrolet Silverado Z71 5.3
2017 Honda CR-V 2.4
Re: GM 4L60E Whine [Re: Falcon_LS] #4531924
10/02/17 09:00 AM
10/02/17 09:00 AM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
Power steering pump?
Re: GM 4L60E Whine [Re: Falcon_LS] #4532366
10/02/17 07:01 PM
10/02/17 07:01 PM
Lakeside CA
another Todd Offline
Lakeside CA
The wife in the next seat over?
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
