MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
I'm on a Lawn Boy jag
by andyd. 09/18/18 01:13 PM
Old (New) Tires
by ET16. 09/18/18 12:05 PM
iOs 12 for Apple
by madRiver. 09/18/18 12:01 PM
Synthetic oil overrated??
by Ablebody. 09/18/18 12:01 PM
Ferrari Monza SP 1/2
by DeepFriar. 09/18/18 11:58 AM
Any option to "Mark all forums read"
by Rick505. 09/18/18 11:54 AM
1981 280ZX Turbo
by 16HC. 09/18/18 11:12 AM
Muscle car emblems
by Snagglefoot. 09/18/18 10:15 AM
Burn out question
by Fitter30. 09/18/18 10:15 AM
tomkat22, tabar2004, SierraMan, Rennmeister, KeithCoates
66004 Registered Users
89 registered members (Astro14, AVB, 53' Stude, BAJA_05, 65convertible, 25ring, 10 invisible), 1,365 guests, and 36 spiders.
Topics290,604
Posts4,847,323
Members66,004
Most Online3,590
Jan 24th, 2017
2007 Sedona ATF Drain & Fill - 190K Miles #4530534
09/30/17 06:45 PM
09/30/17 06:45 PM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
Thanks to YouTube I bought a 15/16" wrench and did my first drain & Fill : 50% with Hyundai SPIII and 50% with Eneos SPIII . Prior to that I had my mechanic do it every 30K to 40K miles . I got about 5.5 qrts out of it and the fluid was dark red/brown . Also the drain plug magnet had about a 1/4" ~ 1/2" of gunk all around it which I cleaned off real good . I have not bought the Eneos SPIII before (always just bought SPIII from the Hyundai dealer) - the Eneos is a little cheaper and sold at NAPA which is much closer than the Hyundai dealer . How long should I drive before doing another ATF drain and fill and also your thoughts on Eneos SPIII ATF ?
2017 Hyundai Sonata 2.4L GDI 4 cylinder
2010 Hyundai Elantra 2.0L 4 cylinder
2007 Kia Sedona 3.8L 6 cylinder
Re: 2007 Sedona ATF Drain & Fill - 190K Miles [Re: ChrisD46] #4530546
09/30/17 06:57 PM
09/30/17 06:57 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
I would take a look at the fluid color and see if it remains more red than brown. If it does, then leave it in for 15-20,000 Miles and then do another drain and fill.
Otherwise do a drain and fill in a months time. Does the van have a removable drain pain and filter? If it does, I'd drop the pan and change the filter on the next service.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: 2007 Sedona ATF Drain & Fill - 190K Miles [Re: ChrisD46] #4530561
09/30/17 07:31 PM
09/30/17 07:31 PM
USA
slacktide_bitog Offline
USA
Nothing wrong with Eneos, but Maxlife is better, and at a better price if you're near an Autozone.
Re: 2007 Sedona ATF Drain & Fill - 190K Miles [Re: JC1] #4530822
10/01/17 03:06 AM
10/01/17 03:06 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
+1 for fluid color.
Re: 2007 Sedona ATF Drain & Fill - 190K Miles [Re: ChrisD46] #4530831
10/01/17 03:26 AM
10/01/17 03:26 AM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
No drain pan or filter in the Sedona ... *Eneos SPIII wording about as close as you can get to OEM SPIII (Hyundai) from what I have read - not sure about Maxlife ?
Re: 2007 Sedona ATF Drain & Fill - 190K Miles [Re: ChrisD46] #4531028
10/01/17 10:00 AM
10/01/17 10:00 AM
JC1 Offline
JC1  Offline
+2 on the Maxlife. It's rated for SP-III.
Re: 2007 Sedona ATF Drain & Fill - 190K Miles [Re: ChrisD46] #4531053
10/01/17 10:35 AM
10/01/17 10:35 AM
Iowa
cappilot Offline
cappilot  Offline
Iowa
Somewhere in the past I've written about my experience with my SO's 2006 Sedona. In a nutshell, the 2-3 or 3-4 shift began to flare somewhere shortly past 100,000 miles (the ATF had never been changed along the way). I immediately did a drain and fill using MaxLife. That stopped the slipping, though of course there had been some excess wear to reach that point. Since that first ATF swap, I've done partial changes every 12-15,000 miles. Overkill, maybe, but cheaper than transmission replacement. I've tried MaxLife, Dex III, and Castol Import ATF. Shifting was strange with the Dex III. Using only MaxLife, the downshift at slow speeds would sometimes be abrupt. A big percentage of Castrol gave sloppy shifts. For the past few years I've used a 50/50 mix of MaxLife and Castrol; that seems to give the results I prefer. At 227,000 miles the transmission still operates 'as normal', so I'm happy.
Re: 2007 Sedona ATF Drain & Fill - 190K Miles [Re: ChrisD46] #4531798
10/02/17 06:22 AM
10/02/17 06:22 AM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
There always seems to be some issue or another with any brand that isn't SPIII from Hyundai / Kia ... Why is this ? I suppose "meets" SPIII is not the same as "certified" SPIII ?
