Post your latest mileage achievement
by Snagglefoot. 09/23/18 08:23 AM
Field repair by the Mississippi!
by Number_35. 09/23/18 08:18 AM
F150 5.0 Lost power
by hatt. 09/23/18 08:15 AM
Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
More California BS!
by dogememe. 09/23/18 04:04 AM
Optimum No Rinse Wash and Wax or Shine?
by anndel. 09/23/18 03:44 AM
Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
72 registered members (AnthemBassMan, 53' Stude, 94astro, AandPDan, Al, alarmguy, 4 invisible), 1,440 guests, and 42 spiders.
Topics290,874
Posts4,851,690
Members66,047
Most Online3,590
Jan 24th, 2017
Permatex Ultra Black Question #4530476
09/30/17 05:48 PM
09/30/17 05:48 PM
Clovis, CA
Merkava_4 Offline OP
Clovis, CA
The instructions say to apply the product to ONE surface.
If I apply the product to BOTH mating surfaces, am I screwed ? frown
Re: Permatex Ultra Black Question [Re: Merkava_4] #4530481
09/30/17 05:51 PM
09/30/17 05:51 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Will they both be wet at the same time? If so, you are OK. But why go to all the bother ... Put it on the receiving surface and gently place the other part and snug lightly. Torque after set smile
Re: Permatex Ultra Black Question [Re: Merkava_4] #4530485
09/30/17 05:55 PM
09/30/17 05:55 PM
Vienna, VA
TinyVoices Offline
TinyVoices  Offline
Vienna, VA
You are fine. I do this for corners of valve covers where the seal does a 90.
1993 Toyota MR2 Hardtop N/A - 160k miles - Valvoline Max Life 5w30
2006 Toyota Matrix XR AWD (Fiancee) - 130k miles - Valvoline Max Life 5w30
Re: Permatex Ultra Black Question [Re: Merkava_4] #4530494
09/30/17 06:05 PM
09/30/17 06:05 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
Your all done start over again... spank
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive184k miles
Last Change;
Penn. Plat. HM. 5w30
Fram xg8a, Fram CA8141
I like my oil (slippery).
Re: Permatex Ultra Black Question [Re: BrocLuno] #4530505
09/30/17 06:18 PM
09/30/17 06:18 PM
Clovis, CA
Clovis, CA
Yes, both sides were wet during assembly.
Surface A was the intake manifold and Surface B was the thermostat housing.
I didn't put a bead down, but instead I cake frosted the surfaces with a thin coat.
And another thing I'm not so sure on is that after assembly, I wiped off the squeeze out; is that a NO-NO ?
Re: Permatex Ultra Black Question [Re: Merkava_4] #4530578
09/30/17 08:11 PM
09/30/17 08:11 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
That's fine, the sealant trapped between the two surfaces does all the sealing. The excess on the outside of the joint seam does little to nothing in terms of actually sealing.
Re: Permatex Ultra Black Question [Re: ZeeOSix] #4530621
09/30/17 08:50 PM
09/30/17 08:50 PM
Clovis, CA
Clovis, CA
Hey thanks ZeeOSix! I can relax now. smile2
Re: Permatex Ultra Black Question [Re: Merkava_4] #4530624
09/30/17 08:53 PM
09/30/17 08:53 PM
Colorado
sw99 Offline
sw99  Offline
Colorado
I've done both and not a noticeable difference when removing. Have you ever used the Right Stuff?
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2018 Ford F350 6.2L
Re: Permatex Ultra Black Question [Re: sw99] #4530633
09/30/17 09:06 PM
09/30/17 09:06 PM
Clovis, CA
Clovis, CA
I haven't used the Right Stuff yet. The 5-minute working window would be cause for some anxiety unless I could lay a bead down as fast as the robots do. And then as expensive as it is, I'd be afraid of what's left in the container drying up.
Re: Permatex Ultra Black Question [Re: Merkava_4] #4530800
10/01/17 02:09 AM
10/01/17 02:09 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
I've used Ultra Black on dozens of projects and it's never failed to do the job. thumbsup
Re: Permatex Ultra Black Question [Re: Merkava_4] #4530803
10/01/17 02:12 AM
10/01/17 02:12 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
I stick it in the freezer. Slows the chemical reaction down significantly.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: Permatex Ultra Black Question [Re: Merkava_4] #4530816
10/01/17 02:43 AM
10/01/17 02:43 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
I think the "one surface rule" is for when you wait the 20 minutes for it to skim set and then assemble. If you are assembling immediately, I don't think it matters, but be careful you don't apply too much (use half the recommended bead size on both surfaces). If you over-apply blobs of cured RTV can break off the assembly and clog oil passages. A continuous bead is all that's needed.
You're probably OK that way if you skim coated the parts and you didn't see too much excess squeeze out from the outside (visible) portion of the assembly, plus you were doing water passages, not oil-wetted ones.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Permatex Ultra Black Question [Re: Johnny2Bad] #4531429
10/01/17 06:18 PM
10/01/17 06:18 PM
Clovis, CA
Clovis, CA
So far no leaks, but I did give it a full 24 hour cure time before I even poured the coolant back in. The new thermostat won't let the engine cool down to 176F with the air conditioner on like it used to. It's holding the engine to 198F with the A/C on.
Re: Permatex Ultra Black Question [Re: Merkava_4] #4531770
10/02/17 05:25 AM
10/02/17 05:25 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
And another thing I'm not so sure on is that after assembly, I wiped off the squeeze out; is that a NO-NO ? [/quote]
I would have used a gasket with Permatex 2 instead for the thermostat housing.
The "thinking" man's friend.
