FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
111 registered members (ArrestMeRedZ, AndyB, addyguy, avi1777, anndel, 13 invisible), 2,079 guests, and 55 spiders.
Topics286,151
Posts4,903,046
Members67,565
Most Online2,967
Mar 10th, 2019
What temp is safe to shut down? #4530243
09/30/17 12:47 PM
09/30/17 12:47 PM
SC
73PSD Offline OP
73PSD  Offline OP
SC
I have a 2000 Excursion with a 7.3L PSD. I bought it at 140k and I have no idea of the maintenance history, but it was bone stock except for a drop-in K&N (which is long gone). Earlier this year I replaced all the O-rings and HPOP hoses, replaced the turbo with a Garrett 38R, and put a set of 160/80 injectors in. I've always used Rotella T6 5w-40 in it and Blackstone says my engine is in great shape.
I'm familiar with most of the saga over Ford and CK-4 oil, but from what I've read (and also a little common sense thrown in) I really don't think the issue affects older diesels like mine. I should have no problem running CK-4 going forward, right?
Here is my main question: At what temperature (EGT-wise) is it safe to shut down the engine? I've been told 400 is the maximum, but I also think that the information is probably quite a bit dated and based on older oil like CI-4 or even CH-4, both of which were more susceptible to coking. So the question is, with modern oil, do I need to let the turbo cool down some before I shut it down?
Thanks for any input.
Re: What temp is safe to shut down? [Re: 73PSD] #4530248
09/30/17 12:53 PM
09/30/17 12:53 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Re: What temp is safe to shut down? [Re: 73PSD] #4530257
09/30/17 01:12 PM
09/30/17 01:12 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
close to 300*f.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: What temp is safe to shut down? [Re: CT8] #4530267
09/30/17 01:20 PM
09/30/17 01:20 PM
SC
73PSD Offline OP
73PSD  Offline OP
SC
Originally Posted By: Reddy45
That's not an answer, and I really don't care what Bill says anyway as half the things he believes are made-up nonsense.
Originally Posted By: CT8
close to 300*f.
I can let it idle all day long with the AC off and it will never reach 300* F.
Re: What temp is safe to shut down? [Re: 73PSD] #4530284
09/30/17 01:41 PM
09/30/17 01:41 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
close to 300*f.
Close. My wife has a 2002 Power Stroke and it gets down to about 325 maybe 3408 ish on the pyrometer at 100+ temps during the summer idling at best, so around 300.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: What temp is safe to shut down? [Re: 73PSD] #4530307
09/30/17 02:03 PM
09/30/17 02:03 PM
USA
ArcticDriver Offline
USA
The "saga" does appear to be coming to an end now that so many 5w40s are being added to the Approved list and no chemistry changes took place to make that list so CK-4 should present no issues; however,
it was Ford itself who stated the new API rated oils affected ALL Powerstrokes. CK-4 only came about to address the issues unique to new diesel emission systems and minimal concern would have been given to your 17 year old 7.3 which both the EPA and new car manufacturers would like to see off the road anyway. grin
Hope your X has many years ahead of it.
Multiple Diesel and Gasoline vehicles
Re: What temp is safe to shut down? [Re: 73PSD] #4530309
09/30/17 02:08 PM
09/30/17 02:08 PM
New England
gathermewool Offline
New England
Is this turbo water-cooled?
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: What temp is safe to shut down? [Re: gathermewool] #4530367
09/30/17 03:35 PM
09/30/17 03:35 PM
SC
73PSD Offline OP
73PSD  Offline OP
SC
Originally Posted By: ArcticDriver
however, it was Ford itself who stated the new API rated oils affected ALL Powerstrokes. CK-4 only came about to address the issues unique to new diesel emission systems and minimal concern would have been given to your 17 year old 7.3 which both the EPA and new car manufacturers would like to see off the road anyway. grin
That's how I feel about it. The message from Ford was targeted to the 6.7L trucks and they never said how much, if any, of the concern was for older diesels. Since oil specs are supposed to be backward compatible so I tend to believe that there wouldn't be any issues with CK-4 in an older engine.
It better - I just spent a bunch of money on it! smile
No, it's not.
Re: What temp is safe to shut down? [Re: 73PSD] #4530422
09/30/17 04:28 PM
09/30/17 04:28 PM
TX
KJSmith Offline
KJSmith  Offline
TX
When I had my '02 7,3 I worried a little at first.
But the reality is unless you are towing a heavy load, no need to wait at all.
Most of the time looking for a parking spot or idling around the lot is good enough.
I had 304k when mine was stolen... wish I was still driving it,
Blackstone said 400k would be no issue on mine.
On our stationary generators, we cool them to 600f before shutting down.
Re: What temp is safe to shut down? [Re: 73PSD] #4530428
09/30/17 04:33 PM
09/30/17 04:33 PM
USA
USA
Too late for me to edit my earlier post to add Ford's "Position Statement".
API CK-4
Ford will not be recommending the use of CK-4 motor oils in any Ford diesel engines, new or old. Testing Ford has done on some CK-4 formulations have shown inadequate wear protection compared to CJ-4 formulations developed and licensed before 2016.
But it all seems like much ado about nothing at this point.
Re: What temp is safe to shut down? [Re: 73PSD] #4530451
09/30/17 04:59 PM
09/30/17 04:59 PM
Texas
PumpPusher Offline
PumpPusher  Offline
Texas
I don't have a certain temp, but most 7.3 forums says 5min after freeway driving or towing. If your just short tripping around town, no need. That's what I do.
Re: What temp is safe to shut down? [Re: 73PSD] #4530599
09/30/17 08:33 PM
09/30/17 08:33 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
What does Garrett say? After all, you just got a new turbo, and the issue really is about oil coming in the bearings of the turbo...
Re: What temp is safe to shut down? [Re: ArcticDriver] #4531009
10/01/17 09:47 AM
10/01/17 09:47 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
API CK-4
Considering an E6 lubricant was already on the old "E" list, their position is laughable at best, especially when it comes to older engines.
Plain, simple Garak.
Re: What temp is safe to shut down? [Re: 73PSD] #4531882
10/02/17 09:16 AM
10/02/17 09:16 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
I've had several diesels over the years (still have a few) and I've never been able to get my Dmax EGTs much lower than 350-370 after the engine is fully warmed. The only time I see anything as low as 300F is right after a cold start. As the block/pistons warm up, it will idle around 350-370 shortly after a cool down period.
Given the history of the 7.3L and it's turbo system, I'd say it won't matter much, as that is generally not a failure mode associated with the 7.3PSD. I'd say if you can get it below 400F for a few minutes, allowing it to balance at that temp, it will be fine.
If you've been pulling heavy loads, and have heat-soaked the engine bay, it often helps to cool down quicker if you pop the hood; helps transfer the heat a bit quicker rather than it pooling in under the hood. That is, of course, depending upon the conveniences or obstacles of doing so.
As for the CK-4 in your old 7.3L, I'd not worry about it. Ford has done nothing to fully inform anyone of WHY they have stated such a concern, and yet they not only say it's an issue with current engines (6.7L,) but all engines previously produced aren't compatible either? As if they've taken the time to grab some old 7.3L and 6.0L trucks and spend engineering time and money assessing the risks with testing? That's a load of bovine manure! Further, has Navistar come out publicly with the same concern? Not that I'm aware of.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: What temp is safe to shut down? [Re: 73PSD] #4532301
10/02/17 07:14 PM
10/02/17 07:14 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
I shut my Cummins down when EGT (pre-turbine) reaches 350F.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
