Let's Talk Bed Pillows
by LoneRanger
06/20/18 09:21 AM
Changed Speedo Gear on 700r4 Tailshaft
by Pike51
06/20/18 09:20 AM
Which do you prefer: ZL-1 Camaro or GS Corvette ?
by Mr Nice
06/20/18 08:41 AM
CVT Discussion
by Sierra048
06/20/18 08:28 AM
Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
06/20/18 07:34 AM
Need mini grease gun
by Duffyjr
06/20/18 07:02 AM
Mazda 6 O2 sensor - CA emission
by Chester11
06/20/18 06:57 AM
Brake Bleeder
by supton
06/20/18 06:56 AM
As close to blowing out as you can get
by wwillson
06/20/18 06:04 AM
changing tranny filter
by Dennisistheman
06/20/18 06:04 AM
From small things...
by Silk
06/20/18 05:57 AM
Anyone signing up for the Space Force
by Shannow
06/20/18 03:58 AM
Pennzoil Platinum at Walmart
by TheLawnRanger
06/19/18 11:21 PM
Mopar OEM and Fram Ultra Oil filters, '18 Jeep JL
by IndyFan
06/19/18 10:45 PM
What’s the odds..
by Eric Smith
06/19/18 09:51 PM
Who can relate?
by Reddy45
06/19/18 09:43 PM
No more oil changes
by goodtimes
06/19/18 09:19 PM
Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Theraven, battleman13, Shassis, Santo, aligoodn
65276 Registered Users
83 registered (2015_PSD, 9050lx, 853okg, 28oz, 2009Edge, 330indy, 9 invisible), 1457 Guests and 32 Spiders online.
65276 Members
67 Forums
285641 Topics
Page 1 of 2 1 2 >
#4530198 - 09/30/17 12:00 PM What size genset for frig?
Ed_T Offline
Loc: Taxachusettstan
Have a 2011 Maytag kitchen refrigerator, tag says 7.1 amps. Does not say if this is running or starting surge amps. Seems like a ton of amps for running, at around 800+ watts.
For those of you with frig/gen experience, what size generator output am I looking for with this frig? I'd like to stay around 2,000 watts surge rating for fuel efficiency reasons, but I am fearful that is nowhere near enough starting surge power. Opinions welcomed...
#4530216 - 09/30/17 12:18 PM Re: What size genset for frig? [Re: Ed_T]
dwendt44 Offline
Loc: Central Wisconsin
Amps X Volts=Watts.
Always figure heavy. 12 amps(a guess) starting would need
1400 watts, so 2000 should work if that's all your feeding.
My 2¢
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
#4530217 - 09/30/17 12:20 PM Re: What size genset for frig? [Re: Ed_T]
clarkflower Offline
Loc: US
Google How many watts does it take to run a refrigerator on a generator?
Many devises need more power to start up (Maximum Output Watts) and then require less power (Rated Watts) to run continually. For example, a refrigerator requires 2200 starting wattage with a 700 running wattage, so you would need a generator with at least 2200 watt maximum output.
Honda says less https://powerequipment.honda.com/generators/generator-wattage-estimation-guide
Edited by clarkflower (09/30/17 12:21 PM)
#4530259 - 09/30/17 01:14 PM Re: What size genset for frig? [Re: Ed_T]
JHZR2 Offline
Loc: New Jersey
Many of the starting load requirements are overstated and drive to buying oversized and thirstier generators.
#4530348 - 09/30/17 03:04 PM Re: What size genset for frig? [Re: Ed_T]
Chris142 Offline
Loc: Deplorable in apple valley, ca
My 800w 2 stroke hf genny ran my fridge and moms oxygen machine at the same time.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4530371 - 09/30/17 03:37 PM Re: What size genset for frig? [Re: Ed_T]
eljefino Offline
Loc: ME
I have also done it with my HF 800 watt two-smoke.
What I did to get it going was I ran a power strip at the end of the extension cord with a hair dryer on it on low (800 watts) to load the generator then I killed the hairdryer while simultaneously plugging in the fridge. In the time since, I think I broke said generator in as it makes more power and I don't have to do the hair-dryer thing.
But my kill-a-watt meter says my fridge takes 280 watts running. It's a whirlpool with 6.5 Amps on its data plate.
Beware the defrost cycle, about 2x a day, runs on a timer and uses a bit more power.
That all said I'd get a small 4-stroke generator of the 1500 watt sizing for efficiency. 2-strokes blow 10+ percent of the incoming gas straight through the exhaust.
Take note that a conventional 3600 RPM non-inverter generator has an engine flywheel spinning along, so when it's suddenly loaded, the flywheel carries it through. Generally enough for the compressor's locked rotor inrush current.
#4530387 - 09/30/17 03:55 PM Re: What size genset for frig? [Re: eljefino]
punisher Offline
Loc: snowblind in TX
Great observation. Something like a 5500 BTU AC will usually trip the breaker on a 1000 watt inverter unit, but start OK on that little HF unit.
#4530389 - 09/30/17 03:57 PM Re: What size genset for frig? [Re: Ed_T]
LotI Offline
Loc: America's Dairyland
My Champion 1600W inverter runs a fridge just fine
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
#4530441 - 09/30/17 04:52 PM Re: What size genset for frig? [Re: Ed_T]
Eddie Offline
Loc: Florida, Cape Coral
With a Honda 2000 inverter gen, I was running a std refrigerator ~ 600 Watts, a 46 inch TV ~ 300 watts, 2 60 watt lights and a computer without any issues for 3 days continuous except for gas fill ups. Ed
CX5 Touring 2.5L :-)
#4530478 - 09/30/17 05:49 PM Re: What size genset for frig? [Re: Ed_T]
Donald Offline
Loc: Upstate NY
I would buy or borrow a clamp on ammeter with peak hold. Before spending money on a generator.
2015 Ford F250 w/Powerstroke
#4530496 - 09/30/17 06:07 PM Re: What size genset for frig? [Re: Ed_T]
BrocLuno Offline
Loc: Kalifornia Kollective
So a fridge is basically an A/C compressor. Load side pressure is low at start-up unless it is running nearly continuously (?). That motor starting load is based on starting current to come up to speed and then running current based on compressor load. The starting current is mostly fixed. The compression load varies depending on how long between cycles. And that depends on delta T between ambient and internal temps and insulation value ...
You need to factor worst case. 110* outside and the house is hot and the wind is blowing and tree goes down. Now you have to generate enough t start a frequently cycling refer. More load.
Never skimp on gen set. You will just hurt the gen set and maybe your appliances. Better to get a bigger gen set and a more efficient motor, than a smaller gen set ...
Fuel is cheap. New refer, not so much ...
Edited by BrocLuno (09/30/17 06:09 PM)
#4530606 - 09/30/17 08:38 PM Re: What size genset for frig? [Re: Ed_T]
Cujet Online   content
Loc: Jupiter, Florida
The Honda EU2000 will do it with zero effort, as I've done it for weeks.
The suggestion above is a good one a small generator with 4 stroke engine will also do it without any issues. Champion makes an 80cc, 4 stroke, 1200w/1500w unit that would easily and efficiently run the fridge, with power left over for lights. They used to sell for $99 but are now about $180-200, and are known to last thousands of hours.
Edited by Cujet (09/30/17 08:44 PM)
#4530889 - 10/01/17 07:21 AM Re: What size genset for frig? [Re: Ed_T]
Kamele0N Offline
Loc: Slovenia
Germans are slightly overexeggerating but maybe you will find that tabel useful
http://www.kipor.org/technik.php
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4530890 - 10/01/17 07:25 AM Re: What size genset for frig? [Re: Ed_T]
Kamele0N Offline
Loc: Slovenia
Kuhlshrank is refrigerator smile
#4530901 - 10/01/17 08:05 AM Re: What size genset for frig? [Re: Ed_T]
Astro_Guy Offline
Loc: Pennsylvania
Maybe you can extrapolate something from my experience with a Champion 3500 watt running / 4000 watt peak generator. I've managed to run three refrigerators and one 15 cubic foot freezer simultaneously. One refrigerator and freezer are on the same circuit, so there is a pretty good chance that they start at the same time when that circuit gets energized. That's the first circuit I energize, and the generator does slow down momentarily. It doesn't bog down.
I've also got the gas range with electric ignition wired to the generator via a transfer switch. The electric ignitor for the oven has a more noticeable impact on the generator than the refrigerator and freezer starting, but then the generator is more heavily loaded at that point.
One thing yet to be mentioned in this thread is that a refrigerator is an inductive load. There will be a momentary drop in voltage when it comes on, which will reduce the current it draws. I've seen guidelines for commercial applications suggesting that you can get away with 70% of the nameplate starting amps because of this. In your case, that means you should be fine with 5 amps or perhaps as little as 600 watts. That latter figure does seem consistent with some of the other advice posted here.
'01 Volvo V70XC, 225k, 0w40 M1
'16 Accord, 11k, soon to be 0w20 M1 EP
Page 1 of 2 1 2 >
