Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
tedonom, 01ws666, ariefnrst, tcoffin014, Schm1d
66657 Registered Users
110 registered members (28oz, 2018matto, 4WD, 1foxracing, 64bawagon, Alfred_B, 9 invisible), 1,825 guests, and 35 spiders.
Topics294,973
Posts4,925,172
Members66,657
Most Online2,553
Oct 27th, 2018
How to clean a Mityvac 7201? #4530036
09/30/17 07:30 AM
09/30/17 07:30 AM
Michigan
BobsArmory Offline OP
Michigan
I have used my Mityvac for a couple of years now with great results. I have used it for sucking out everything imaginable trans fluid, brake fluid, power steering fluid, differentials, well you get the idea.
Well now comes the time where I would like to use it for a fluid refill. How do you Mityvac users clean out the unit to assure a clean fill?
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
Re: How to clean a Mityvac 7201? [Re: BobsArmory] #4530046
09/30/17 07:49 AM
09/30/17 07:49 AM
On the road Midwest
Ihatetochangeoil Offline
On the road Midwest
I run some acetone thru it immediately after every time I use it. If I recollect right, the instructions say to do this. A quart or gallon of acetone is not expensive in the paint dept. at Walmart or Home Depot.
My favorite use for it is to suck out the transmission pan prior to a pan drop...Saves a lot of splashed fluid and avoids a big mess. I haven't tried it, but I think with the Mityvac I could change transmission fluid and filter and not waste a dress shirt.
2003 Lesabre Celebration Edition
2004 Lesabre
2004 Lesabre Celebration Edition
Re: How to clean a Mityvac 7201? [Re: BobsArmory] #4530135
09/30/17 09:25 AM
09/30/17 09:25 AM
CA
raytseng Offline
raytseng  Offline
CA
buy a second mityvac.
id youre looking for just good enough and dont need full assurance, if youre sucking out old transmission fluid, then replacing it back, then majority of any residue that gets put will be transmission fluid. Esp. if youre doing 2x or 3x replacements, its not the end of thr world if an ounce or 2 of old fluid gets pumped back in.
Re: How to clean a Mityvac 7201? [Re: BobsArmory] #4530138
09/30/17 09:32 AM
09/30/17 09:32 AM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
Personally I would not bother using the same vacuum pump to evacuate and to fill, as the risk of contamination is too great. I know that my pump is filthy from used oil and other fluids. Cleaning all that up would be hard, time consuming and the solvents involved may pose a problem as well.
I would simply buy a fluid transfer pump, either manual or electric, or as suggested, another mityvac.
2015 Dodge Grand Caravan-27k miles.
2006 Mazda 3-163k miles
Re: How to clean a Mityvac 7201? [Re: BobsArmory] #4530152
09/30/17 09:58 AM
09/30/17 09:58 AM
Arizona
SIXSPEED Offline
SIXSPEED  Offline
Arizona
I recall cleaning it up after first use with soap and water but I don't bother cleaning it any more after use. I just pour out as much fluid as I can. I only use it for extracting oil from one car so there's no mixing different types of fluids.
Re: How to clean a Mityvac 7201? [Re: raytseng] #4530252
09/30/17 11:57 AM
09/30/17 11:57 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
But how do you clean the second mittyvac? Would you buy a third mityvac to clean the 2nd one?
Re: How to clean a Mityvac 7201? [Re: BobsArmory] #4530260
09/30/17 12:15 PM
09/30/17 12:15 PM
NY
demarpaint Offline
demarpaint  Offline
NY
When I'm done I hang mine upside down over a container with a large funnel in it. When everything is out of it I add Simple Green and water and shake it up and pump it out. I do that a few times then hang it upside down to drip dry. I blow air through the hoses at a very low pressure into a 5 gallon joint compound bucket, and use them when I flush out the Simple Green and water, then blow them out with air again. Using this method I get it very clean.
I don't use it to add and extract fluid in the same day. I add fluid via the dipstick, or fill hole.
God Bless Our Troops
Re: How to clean a Mityvac 7201? [Re: BobsArmory] #4530472
09/30/17 04:37 PM
09/30/17 04:37 PM
Michigan
Michigan
Good info. I will be doing a couple dump and fills on my wife's Malibu transmission soon. Since it doesn't have a dipstick to fill from I was thinking of using the mityvac to refill it.
Re: How to clean a Mityvac 7201? [Re: BobsArmory] #4530480
09/30/17 04:50 PM
09/30/17 04:50 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
2nd MityVac.
2015 Ford F250 w/Powerstroke
