New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
24 registered members (dlundblad, BlakeB, Buzzsaw, Bailes1992, DTrip, ArrestMeRedZ), 753 guests, and 41 spiders.
Topics290,744
Posts4,849,451
Members66,033
Most Online3,590
Jan 24th, 2017
No Crank - No Turnover #4529785
09/29/17 08:07 PM
09/29/17 08:07 PM
Clovis, CA
Merkava_4 Offline OP
Clovis, CA
2000 Buick LeSabre
No crank when turning the key. Battery is at 12.23 Volts across the battery terminals.
I have the battery charger hooked up to it right now and the battery is pulling in 6 Amps. If the battery was fully charged, it wouldn't be pulling any current, correct ?
The battery normally has 14.7 Volts when the engine is running.
Is 12.23 Volts not enough to turn the engine over ?
Re: No Crank - No Turnover [Re: Merkava_4] #4529793
09/29/17 08:15 PM
09/29/17 08:15 PM
USA
mk378 Offline
mk378  Offline
USA
That should be enough to start. The voltage may go away under load though. Or it could be a bad connection somewhere between the battery and the starter (on either the power or the ground side).
Measure at the starter (big wire to the battery to starter ground), while someone turns the key. The voltage should stay up around 12. Then check the small wire at the starter to starter ground. It should become live when the key is turned. If both of those pass, the starter is probably bad.
Re: No Crank - No Turnover [Re: Merkava_4] #4529794
09/29/17 08:16 PM
09/29/17 08:16 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Maybe but I wonder about it buddy. It is definitely hurting at 12.2. I know my Ford Fusion had trouble starting at that voltage. It would start and then not start... Battery had 66k miles worth of starts on it. Replaced it and it was done after that. And yeah it is pulling those amps it is certainly down on charge. How old is the battery man??
Nissan Altima 3.5 Coupe
Quaker State High Mileage 5w30 Purolator Boss 14610
"Treat your family like your friends and treat your friends like your family."
Re: No Crank - No Turnover [Re: Merkava_4] #4529798
09/29/17 08:20 PM
09/29/17 08:20 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Evidently. 12.7 is 100% I would give it at least 1/2 an hour.
Thick oil is better grin2
Re: No Crank - No Turnover [Re: Merkava_4] #4529799
09/29/17 08:21 PM
09/29/17 08:21 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
My lady had a friend who was going on vacation and I just checked her open battery voltage. It was 12.45. Their vehicle did not start three times on that trip... I had a feeling that the battery was shaky. It was 6 yrs old.
Re: No Crank - No Turnover [Re: Merkava_4] #4529834
09/29/17 09:03 PM
09/29/17 09:03 PM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
Is your starter relay getting power? Easy check to see if it's upstream or down stream
2005 Tahoe - 135k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: No Crank - No Turnover [Re: Merkava_4] #4529846
09/29/17 09:20 PM
09/29/17 09:20 PM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
I just replaced the battery in my mom's car as it was 5 years old and was getting harder to start. Didn't want her to get stranded and for $100 it was a wise decision.
Re: No Crank - No Turnover [Re: Merkava_4] #4529849
09/29/17 09:24 PM
09/29/17 09:24 PM
USA
oldhp Offline
oldhp  Offline
USA
Turn the headlights on, turn key, lights go out or stay bright? Lights out? Bad battery or connection. Lights stay on, don't dim? Starter not being engaged, bad starter solenoid, bad neutral safety switch, or bad ignition switch. This check works 99% of the time.
Re: No Crank - No Turnover [Re: mk378] #4529852
09/29/17 09:27 PM
09/29/17 09:27 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Yes, check for voltage at the big terminal, and the little terminal while someone holds the key in 'Start'
If they are both at battery voltage, then the starter is bad.
Sometimes, like 90% of the time, tapping the starter with a hammer will make it work again. But thats a 'get it home' or 'get it to the mechanics' without a tow bill trick.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: No Crank - No Turnover [Re: oldhp] #4529853
09/29/17 09:27 PM
09/29/17 09:27 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Very very good post oldhp.
And Mr. Nice that is a very good way to go. That's the way I do that as well.
Re: No Crank - No Turnover [Re: Merkava_4] #4529860
09/29/17 09:34 PM
09/29/17 09:34 PM
Lakeside, CA
Blkstanger Offline
Blkstanger  Offline
Lakeside, CA
Try moving the shifter to neutral. It's always worth a try.
99 Jeep WJ 4.7 190,000 Maxlife 10w30, Fram Ultra.
Re: No Crank - No Turnover [Re: Merkava_4] #4529893
09/29/17 10:26 PM
09/29/17 10:26 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Load test the battery.
Voltage test is non-conclusive in terms of battery health.
If you don't have the load tester, part store will be happy to help you.
If you have a nearby Harbor Freight, spending $20 will help you diagnose the battery issue in the future also.
  • 2017 Toyota Sienna
Re: No Crank - No Turnover [Re: Merkava_4] #4529913
09/29/17 10:49 PM
09/29/17 10:49 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
Check the battery voltage when it has a load applied to it. Turn on the head-lights, and interior lights and check the battery voltage with that load on it. It should be above 11.0 Volts.
If you have someone to help you, read the battery voltage while someone turns the key to start.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: No Crank - No Turnover [Re: JimPghPA] #4529920
09/29/17 11:02 PM
09/29/17 11:02 PM
Clovis, CA
Clovis, CA
All is well now fellas. Thanks for all your replies. smile
Apparently, 12.23 Volts is not enough to turn the engine over -- but 13.85 Volts is.
After startup, the battery was back to 14.5 Volts with a little jolt from the alternator.
Earlier today, I put the car in neutral so that I could roll the car out of the garage for cleaning the garage. I must've either left something on, or didn't put the ignition tumbler back to the full off position.
Re: No Crank - No Turnover [Re: Merkava_4] #4530668
09/30/17 09:42 PM
09/30/17 09:42 PM
Austin, Texas
RemingtonHill Offline
Austin, Texas
You more than likely need a new battery. How old is it?
1988 Acura Legend ~171K miles - MaxLife ATF, MaxLife Synth Blend, Liqui-Moly MoS2
1992 Honda Accord ~151K miles - MaxLife ATF, PP High Mileage.
