Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
80 registered members (Aero540T, 2010Civic, -SyN-, 2002 Maxima SE, 4WD, 6 invisible), 1,325 guests, and 32 spiders.
Topics290,810
Posts4,850,826
Members66,036
Most Online3,590
Jan 24th, 2017
Best Replacement brake calipers Honda Accord #4529732
09/29/17 07:29 PM
09/29/17 07:29 PM
new jersey
jrvn Offline OP
jrvn  Offline OP
new jersey
I have a 2006 Honda accord I4 with a sticking RR brake caliper and I am afraid of what the Dealer will charge to replace usually it will be both RR and LR calipers with new rotors and pads to make it work properly again probably about a $1300 bill. anyone have any recommendations for non OEM parts that are as good as the originals OEM Honda or is it best to bite the bullet and pay for the OEM parts. the car has been well maintained with 105k miles. I was thinking of buying the parts online and let an ex Honda tech who now owns his own business to do the work.
Re: Best Replacement brake calipers Honda Accord [Re: jrvn] #4529735
09/29/17 07:30 PM
09/29/17 07:30 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
A sticking caliper doesn't necessarily mean it needs to be replaced. Have you greased up the slides? Brake hose going bad?
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Best Replacement brake calipers Honda Accord [Re: jrvn] #4529744
09/29/17 07:35 PM
09/29/17 07:35 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
A good remanufactured caliper can work, it's what I used on my Element's left front caliper. I got mine from Rock Auto, but I'd recommend getting them locally so you can more easily inspect the remanufactured caliper and return the core afterwards.
Here's a post from today about Cardone remans:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4529181/Re:_Bit_the_bullet_on_Cardone_
Re: Best Replacement brake calipers Honda Accord [Re: jrvn] #4529748
09/29/17 07:36 PM
09/29/17 07:36 PM
texas
danez_yoda Online content
danez_yoda  Online Content
texas
Exactly, If you cant DIY it , You need a good independant to service your calipers or tell you to get new ones.
Re: Best Replacement brake calipers Honda Accord [Re: jrvn] #4529756
09/29/17 07:42 PM
09/29/17 07:42 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Most rebuilds of a decent name are of good enough quality, cardone ac delco napa, etc. Theres really not too much to a brake caliper, so usually the rebuilding is only a quick hone, new seals and bleeder screw, all cheap parts. Theres also new calipers, I recently needed 2 rear calipers on my golf and found new TRWs, same as OEM except had the VW logo scratched off.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Best Replacement brake calipers Honda Accord [Re: jrvn] #4529770
09/29/17 07:51 PM
09/29/17 07:51 PM
USA
slacktide_bitog Offline
USA
Napa Eclipse. It is the same as Cardone Ultra, except the coating is black (instead of silver on the Cardone Ultra). I have them on my car, and they are awesome. Coated caliper are a MUST to deter the rust. Non-coated calipers rust overnight.
Even the dealer "OEM" rebuilds are done by Cardone
Also, get coated rotors. Centric Premium or Wagner E-shield.
The best pads to use are Akebono ProACT, Wagner Thermoquiet, Advics, or Beck/Arnley OE Pads (they are the actual OE pads in the original box with a B/A label on them)
Re: Best Replacement brake calipers Honda Accord [Re: jrvn] #4529773
09/29/17 07:52 PM
09/29/17 07:52 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
I had bad luck with AAP calipers, believe they were cardone ones. Looked good enough to start, but they were as rusty as could be in no time flat. The 23 year old ones I removed looked better!
Re: Best Replacement brake calipers Honda Accord [Re: JHZR2] #4529791
09/29/17 08:12 PM
09/29/17 08:12 PM
USA
USA
That's why you need coated calipers like Cardone Ultra or Napa Eclipse smile
other reman calipers, Cardone or otherwise, usually don't come with any coating on the bare metal, and they strip away the original coating during the cleaning process.
Brand new factory calipers are coated.
Re: Best Replacement brake calipers Honda Accord [Re: jrvn] #4529855
09/29/17 09:30 PM
09/29/17 09:30 PM
California
Kool1 Offline
Kool1  Offline
California
I've replaced a handful of brake calipers over the years and have always masked off the piston as well the bleeder screw and shot them with a coat of clear. The matte finish clear produces the best finish as the gloss clear on calipers makes them a little flashy and highlights the caliper.
Re: Best Replacement brake calipers Honda Accord [Re: jrvn] #4529976
09/30/17 05:07 AM
09/30/17 05:07 AM
MD
t1snwrbrdr12 Offline
MD
Accords tend to have hand brake cables seize up and make the rear caliper drag too. Just make sure of your problem first.
I've done plenty of calipers on accords just wanted to let you know that though.
Re: Best Replacement brake calipers Honda Accord [Re: jrvn] #4530021
09/30/17 07:52 AM
09/30/17 07:52 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
As the others said, verify the actual issue and don't forget to replace the rubber flexible hose too. I use NAPA calipers and they have worked well for me. They are painted black like someone else said, so I have one original silver caliper and a black one on the other side of my Mustang but you can't see both sides of the car at once lol.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Best Replacement brake calipers Honda Accord [Re: t1snwrbrdr12] #4530045
09/30/17 08:43 AM
09/30/17 08:43 AM
new jersey
jrvn Offline OP
jrvn  Offline OP
new jersey
its my moms car I took it in for a oil change to the local Honda dealership and the service lady comes back after waiting 2.5 hours with a list of critical safety issues one being the RR inner brake pad is down to 1mm thickness and the pads are wearing unevenly which could be the caliper pins frozen or the caliper sticking or mal functioning so I told her I have to discuss it with the owner before I can make a decision to fix it seems like it was a high pressure deal to get me to say yes fix it immediately been there done that. My worse case assumption is that they will open it up and tell me the caliper is bad and will need to replace both rears,new rotors(they are pitted service lady says and maybe could be resurfaced depending on the thickness) and new pads all very high priced Honda OEM parts and then add to that the Labor costs,Im assuming over$1300 total.She also says the tires needed to be replaced. I was thinking of buying my own parts online at a cheaper cost and have a Ex Honda mechanic who now owns his own business to do the labor. The initial Dealer recommended repair was to replace rear pads resurface rotors and check/lube the caliper pins($250) this repair is not verified as a one and done fix only if they open up the calipers to see if further repairs are necessary it could spiral out of control quickly at these Dealerships.
Re: Best Replacement brake calipers Honda Accord [Re: jrvn] #4530049
09/30/17 08:51 AM
09/30/17 08:51 AM
new jersey
jrvn Offline OP
jrvn  Offline OP
new jersey
Honda rear brake DIY this is exactly the same situation that happened to me as far as the Dealer recommendations
Re: Best Replacement brake calipers Honda Accord [Re: jrvn] #4531863
10/02/17 08:41 AM
10/02/17 08:41 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Lots of good info in the postings but if you need a caliper I would give the new OPTI-CAL line from Raybestos a shot, at $85ea and no core for new not rebuilt its a great alternative.
http://www.rockauto.com/en/moreinfo.php?pk=8466560&cc=1432618&jsn=402
Re: Best Replacement brake calipers Honda Accord [Re: jrvn] #4531980
10/02/17 11:43 AM
10/02/17 11:43 AM
California
nthach Offline
nthach  Offline
California
Before ruling out the caliper's hydraulic and parking brake mechanicals, make sure there's still sufficient fluid going to the calipers and the slide pins in the caliper bracket are moving freely.
I haven't had much experience with calipers that have built-in parking brakes but if the mechanism outside of the piston bore or the screw/ratchet in the caliper is frozen it will result in stuck pads.
