More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
New TV bad picture some channels
by raaizin. 09/24/18 09:35 AM
Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
2007 Toyota Camry LE Alternator
by maverickfhs. 09/24/18 08:28 AM
AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
TCam, OzFrog, Kursk, DMB, bcrossen
66060 Registered Users
95 registered members (beanoil, Billbert, Blkstanger, 2004tdigls, BAJA_05, 14 invisible), 1,748 guests, and 33 spiders.
Topics290,936
Posts4,852,733
Members66,060
Most Online3,590
Jan 24th, 2017
Coolant change Interval #4529490
09/29/17 03:07 PM
09/29/17 03:07 PM
NY
BigD7 Offline OP
BigD7  Offline OP
NY
Hi all, 2010 5.7 commander here. Did a radiator dump and refill in 2014 and again in 2015. Was about to do it again but started wondering whether it's overkill. Do I do it or wait another yr? Using mopar long life coolant. Thanks in advance.
Re: Coolant change Interval [Re: BigD7] #4529491
09/29/17 03:10 PM
09/29/17 03:10 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
The long-life coolant in my Mazda is 10 year 120,000 miles. I think most long-life is at least 5 year 75,000 miles. Ed
CX5 Touring 2.5L :-)
Re: Coolant change Interval [Re: Eddie] #4529494
09/29/17 03:14 PM
09/29/17 03:14 PM
NY
BigD7 Offline OP
BigD7  Offline OP
NY
Thanks Eddie. Yes, this one is 5 yrs 100K miles. I'm just wondering since I'm doing the radiator only, whether more frequent changes r needed.
Re: Coolant change Interval [Re: BigD7] #4529502
09/29/17 03:34 PM
09/29/17 03:34 PM
Toronto Canada
WobblyElvis Online content
WobblyElvis  Online Content
Toronto Canada
Been maintaining older cars for the past 45 years. In the past 20 years the coolant has advanced significantly and I find a rad flush and new fluid is not necessary at all. I don't know how they do it but it is far better than it used to be. In my experience going 10 years on the original fluid is very doable. If I kept a new car 20 years, I would only expect to service the cooling system fluid once and that's it.
Re: Coolant change Interval [Re: WobblyElvis] #4529508
09/29/17 03:40 PM
09/29/17 03:40 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Agreed. With the old plain green coolant, I never had a corrosion issue with a radiator drain and refill every 2 years.
With the new fluids, you could likely do the same every 4-5 years and be well protected.
Thick vs Thin test: 15k / 43k miles complete
Re: Coolant change Interval [Re: BigD7] #4529510
09/29/17 03:45 PM
09/29/17 03:45 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
This is a inexpensive tester Maybe an overkill but I do mine every 2 years I check it with this... 1 gallon antifreeze the rest water...Ive' never had a antifreze relateded problem in over 30 plus years...
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive184k miles
Last Change;
Penn. Plat. HM. 5w30
Fram xg8a, Fram CA8141
I like my oil (slippery).
Re: Coolant change Interval [Re: BigD7] #4529517
09/29/17 03:49 PM
09/29/17 03:49 PM
MN
ZebRuaj Offline
ZebRuaj  Offline
MN
I service per manual (usually as I near 100k). If the engine drains aren't a PIA to reach, I'll do them. If not, rad drain and fill is good enough if the car has no prior cooling issues.
If I want more alone time in the garage, I usually find other "maintenance" stuff for excuses.
~Shade tree mechanic for friends and family.
Re: Coolant change Interval [Re: BigD7] #4529518
09/29/17 03:49 PM
09/29/17 03:49 PM
WI
HoosierJeeper Offline
WI
Make sure to use HOAT coolant (such as Zerex G05) in your Jeep! Flush it ASAP if it's OAT stuff like universal.
With HOAT, probably every 5-7 years is good. Mileage, probably up to about 100k.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Coolant change Interval [Re: BigD7] #4529578
09/29/17 04:55 PM
09/29/17 04:55 PM
VA
Gebo Online content
Gebo  Online Content
VA
Id find the engine drain plugs and open them. Oh, and make sure you have the temp knob turned to hottest temp.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Amsoil in all engines, transmissions and differentials
Re: Coolant change Interval [Re: BigD7] #4529615
09/29/17 05:30 PM
09/29/17 05:30 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
I've been adding RMI-25 every 15,000 miles and don't ever plan to change mine.
Re: Coolant change Interval [Re: BigD7] #4529675
09/29/17 06:30 PM
09/29/17 06:30 PM
ME
eljefino Offline
eljefino  Offline
ME
What does your manual say to do? Mine literally says drain the radiator, not squeeze every drop out.
I hate to parrot the "cheap insurance" bit but most cars are junked due to transmission or cooling issues. And if you read here about all the 12-15 year old cars with $1000 heater core problems etc, you don't want that to be you. And it takes all those years to show issues.
Re: Coolant change Interval [Re: BigD7] #4529688
09/29/17 06:43 PM
09/29/17 06:43 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Sounds like your coolant is basically all new as of 2015, so long life coolant = 5+ years = theoretically change it in 2020.
(I am an obsessive coolant changer, so I have never let a car go 5 years with any sort of coolant.)
Re: Coolant change Interval [Re: BigD7] #4529771
09/29/17 07:51 PM
09/29/17 07:51 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
Change the coolant with a long life coolant every 4 years with a radiator flush only. 5 years is probably fine but, 4 years is a compromise to help people sleep better. Ed
Re: Coolant change Interval [Re: BigD7] #4529772
09/29/17 07:51 PM
09/29/17 07:51 PM
socal
barkingspider Offline
socal
If I were you, I would not change the coolant until 2020 or another 100k miles.
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Coolant change Interval [Re: BigD7] #4529812
09/29/17 08:41 PM
09/29/17 08:41 PM
NY
Kage860 Offline
Kage860  Offline
NY
Jeep coolant is good for 5 years. So if the radiator drain changes half the coolant you could do that every 2.5 years and be ok based on my logic.
2007 Jeep Liberty
