One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
06/18/18 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
06/18/18 04:28 PM
Same grade with differing low start temps
by mjoekingz28
06/18/18 04:24 PM
Self defense
by Camprunner
06/18/18 03:13 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
39 registered (bbhero, BigJakeChevy, Atesz792, AVB, 2strokeNorthstar, Aero540T, 3 invisible), 980 Guests and 41 Spiders online.
65265 Members
67 Forums
285570 Topics
Page 1 of 2 1 2 >
#4529038 - 09/29/17 05:54 AM Bit the bullet on Cardone reman calipers...
NoNameJoe Offline
Loc: New York
Given the shaky reputation Cardone has, I was a little hesitant but decided to give it a go.
Got two Cardone reman calipers from their ultra line with the powder coat on it. Box is nice and fancy, when you open it up it has a card facing you that talks about how impressed you'll be with their ultra premium calipers.
First caliper had the piston boot installed incorrectly, not seated on the piston and actually twisted/pinched against the body of the caliper with a rusty looking piston as well. The boots for the guide pins were seated into the bracket but not the pins. Okay. The caliper guide pins were ugly looking too, clearly not new.
Second caliper looked fine from the piston boot and guide pin boot side, the plastic cap on the inlet port that they brag about on their description (they claim it protects the threads) was missing and instead the banjo bolt was threaded in there. Kind of weird since the first one had the plastic cap. Piston looks scratched to [censored] from whatever blasting they did to it but at least there's no rust this time. C-clip for the piston boot was slightly out so I had to push it back in. Pulled the bracket and noticed the guide pins were brand new unlike the first, noticed they put two of the same guide pin when they were supposed to have two different guide pins. The one with the bushing on it was missing.
Had RockAuto cut me a refund for the amount it would cost to replace the guide pins and had them replace the other one. I hope the replacement is not as bad. I have to admit this makes me wonder how the things I can't see like the other side of the piston and the square cut seal are. I find it kind of hard to believe their quality control could be this bad.
#4529042 - 09/29/17 06:06 AM Re: Bit the bullet on Cardone reman calipers... [Re: NoNameJoe]
demarpaint Offline
Loc: NY
Why am I not surprised? I think the way to go with reman parts is to buy them local so you can actually look them over. Even that is no guarantee with the lousy quality these days but its a start. It might cost more but could end up being a time saver if you need the vehicle "yesterday."
God Bless Our Troops
#4529056 - 09/29/17 06:35 AM Re: Bit the bullet on Cardone reman calipers... [Re: NoNameJoe]
HangFire Offline
Loc: Central Maryland
I love Rock Auto, but demarpaint is right, for some refurb items it's best to buy local and look them over first (and avoid Cardone).
Various musings: http://hangfire.net
#4529089 - 09/29/17 07:19 AM Re: Bit the bullet on Cardone reman calipers... [Re: HangFire]
Chris142 Offline
Loc: Deplorable in apple valley, ca
i think cardone is the only game in town for calipers. All i have ever seen anyway
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4529122 - 09/29/17 08:05 AM Re: Bit the bullet on Cardone reman calipers... [Re: Chris142]
HangFire Offline
For rebuilt. There's always dealer options, and online dealers. Sometimes, when your life is on the line (brakes), and there are no good rebuild options, just buy new OEM.
Maybe it's time for some Public Shaming: https://www.facebook.com/pages/A1-Cardone/330162340357112
#4529154 - 09/29/17 08:30 AM Re: Bit the bullet on Cardone reman calipers... [Re: NoNameJoe]
Char Baby Online   content
Loc: ROCHESTER, NY
Yeah, I too have had only marginal success with reman Cardone Brake Calipers. Often the bleeder screw is stripped or the anti rattle spring(mazda/ford) were broken off inside the caliper hole(s) therefore, not being able to put the spring into the hole and had to drill out the hole(which Cardone reman facility should have inspected & performed). This one I just bought last week(mazda3) was OK.
"Retired"
'06 Mazda 3i 2.0L
'15 Nissan Altima 2.5 SV
#4529181 - 09/29/17 08:57 AM Re: Bit the bullet on Cardone reman calipers... [Re: NoNameJoe]
EdwardC Offline
Loc: Chicago, IL
Hm, well, that makes me a little nervous about my caliper that I replaced a year and a half ago. I got the Ultra Cardones as well, hoping to get the better end of the Cardone remans.
What makes me nervous is that since I'm just an amateur, I may not have noticed any of the issues like you did. I'd imagine a lot of home garage guys may not either. I did check and silicone grease the slide pins since that's a known issue. At least, it's been working great for about 18 months and 20,000 miles.
#4529204 - 09/29/17 09:18 AM Re: Bit the bullet on Cardone reman calipers... [Re: NoNameJoe]
andyd Offline
Loc: Marshfield , MA
I musta hit the parts lottery when I bought stuff for the Rat. I bought a set of re-manned calipers from Auto Zone. The calipers cost me 16$ each and my calipers as cores. I bought a cheap set of pads and have had no further drama. All the brake and clutch parts came from Parts Geek. Parts selection was mostly price driven. The heavy stuff was bought at the local AZ to avoid shipping. Only splurge was for a LUK rep set. I bought a new starter for 48$ from Amazon. It was almost too pretty to hide on the Rat. Works as good as it looks. grin2
Thick oil is better grin2
#4529227 - 09/29/17 09:51 AM Re: Bit the bullet on Cardone reman calipers... [Re: NoNameJoe]
NHGUY Offline
Loc: USA
BBB/King Kaliper does calipers too.As do Raybestos,Centric,Dorman new and others....
#4529310 - 09/29/17 11:05 AM Re: Bit the bullet on Cardone reman calipers... [Re: NoNameJoe]
ragtoplvr Offline
Loc: missouri
LOTS of competition in the reman caliper business. With the intense competition on price, and part number proliferation, makes it very hard to the reman to make a profit. Quality can suffer, some care more than others.
Rod
#4529426 - 09/29/17 01:32 PM Re: Bit the bullet on Cardone reman calipers... [Re: NoNameJoe]
Bottom_Feeder Offline
Loc: Occupied Virginia
I bought Raybestos remans for my wife's Corolla assuming they would be a slightly higher quality but I had nothing but trouble with them. The Cardone-reman'd Wearever calipers from Advance fixed those problems. Take that however you will...
#4529465 - 09/29/17 02:37 PM Re: Bit the bullet on Cardone reman calipers... [Re: Bottom_Feeder]
NoNameJoe Offline
Loc: New York
What kind of problems?
#4529742 - 09/29/17 07:33 PM Re: Bit the bullet on Cardone reman calipers... [Re: HangFire]
slacktide_bitog Offline
Loc: USA
With reman items that have a core charge, I prefer to buy local in-store* because of return shipping to Rock Auto.
*For the purpose of this post and buying reman parts, in-store also includes their respective online sites (eg autozone.com) since they let you buy online and return in-store
Napa Eclipse is the same as Cardone Ultra, except the coating is black instead of silver.
even the dealer "OEM" rebuilds are done by Cardone
#4530003 - 09/30/17 07:10 AM Re: Bit the bullet on Cardone reman calipers... [Re: NoNameJoe]
dlundblad Offline
Loc: Indiana
So are NAPA calipers even Cardones?
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4530029 - 09/30/17 08:22 AM Re: Bit the bullet on Cardone reman calipers... [Re: slacktide_bitog]
HangFire Offline
Sometimes, such as GM. Some marques do not sell refurb calipers at all. Anyway, that is why I said "just buy new OEM."
Page 1 of 2 1 2 >
