Originally Posted By: sunruh
does it weigh less than 1000lbs?
Glad you asked!
If your click the link in my first post (the review) wet weight is only 770 LBS as tested and the model tested is the fully loaded with all options model at 24k, base model is only 20K.
In this world of WAY overweight bikes, that truly is light weight not that different from my current bike.
... and 7 gallon fuel tank too! 6 cylinder engine ...
2018 BMW K 1600 B Specs
Base Price: $19,995
Price as Tested: $24,390 (Premium and Touring packages, engine protection bars, floorboards)
Warranty: 3 yrs., 36,000 miles
Website: bmwmotorcycles.com
ENGINE
Type: Liquid-cooled, transverse in-line six
Displacement: 1,649cc
Bore x Stroke: 72.0 x 67.5mm
Compression Ratio: 12.2:1
Valve Train: DOHC, 4 valves per cyl.
Valve Insp. Interval: Varies, computer monitored
Fuel Delivery: BMS-X EFI, 52mm throttle bodies x 6
Lubrication System: Dry sump, 4.75-qt. cap.
Transmission: 6-speed, hydraulically actuated wet clutch
Final Drive: Shaft, 2.75:1
ELECTRICAL
Ignition: BMS-X computer controlled
Charging Output: 700 watts max.
Battery: 12V 19AH
CHASSIS
Frame: Cast-aluminum-alloy twin-spar main frame w/ engine as stressed member & aluminum subframe; cast-aluminum Paralever single-sided swingarm
Wheelbase: 63.7 in.
Rake/Trail: 27.8 degrees/4.2 in.
Seat Height: 30.7 in.; optional low seat: 29.5 in.
Suspension, Front: BMW Duolever w/ Dynamic ESA, 4.5-in. travel
Rear: BMW Paralever w/ single shock & Dynamic ESA, 4.9-in. travel
Brakes, Front: Dual floating 320mm discs w/ opposed 4-piston calipers & ABS Pro
Rear: Single 320mm disc w/ 2-piston pin-slide caliper & ABS Pro
Wheels, Front: Cast, 3.50 x 17 in.
Rear: Cast, 6.00 x 17 in.
Tires, Front: 120/70-ZR17
Rear: 190/55-ZR17
Wet Weight: 770 lbs. (as tested)
Load Capacity: 465 lbs. (as tested)
GVWR: 1,235 lbs.
PERFORMANCE
Fuel Capacity: 7.0 gals., last 1.0 gal. warning light on
MPG: 89 PON min. (high/avg/low) 33.8/37.7/43.5
Estimated Range: 264 miles
Indicated RPM at 60 MPH: 2,750
