M1 0W20 EP Good To At Least 10K Miles ?
by ChrisD46. 12/16/18 03:29 AM
Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
23 registered members (Bjornviken, DaHen, citationxeleven, 4WD, daves87rs, ChrisD46), 805 guests, and 40 spiders.
Topics295,136
Posts4,928,358
Members66,691
Most Online2,553
Oct 27th, 2018
Differences between ADBV and by-pass valve ? #4529002
09/29/17 03:13 AM
09/29/17 03:13 AM
Seattle, Washington
joyi Offline OP
joyi  Offline OP
Seattle, Washington
I've been wondering what are the functions of Anti Drain Back Valve and by-pass valve?
I know both of them is for preventing oil starvation of the motor but not sure how they work
Re: Differences between ADBV and by-pass valve ? [Re: joyi] #4529028
09/29/17 04:22 AM
09/29/17 04:22 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
welcome
To the site!
The ADBV essentially is a check valve that prohibits the oil from flowing out of the filter when the system is shut down. This is most generally achieved by using a nitrile or silicone formed gasket near the holes. Depending upon location of filter, and orientation of filter, on the engine, the effectiveness of the ADBV can be substantial or moderate.
The BP valve in the filter is a pressure relief valve. It's there first and foremost to protect the media of the filter from a rupture if the pressure differential (dP) across the media becomes very significant. This most often happens when the filter is first installed dry, or when the ADBV does not hold the filter full upon shut down. Additionally, the BP valve can have a secondary benefit, but one that we'd hope does not come into use. If the media were to become so loaded with particulate that it were to "blind off" (fully or partially) to a point where the flow requirement of the engine exceeded the flow ability of the filter, the BP would start to crack open and aleviate the dP, thereby saving the filter from a rupture (avoiding media bits going into the stream) as well as giving vital flow to the engine. This BP function does not happen nearly as often as many infer. Jim Allen did some data logging testing on a live engine in normal use, and found that the only time the BP opened up was at really cold starts, with an oil thicker than was spec'd for his truck, and only for a second or two until the dP balanced out. With warmed oils, or the right fluid, it didn't happen at all. How does it work? It's essentially a spring loaded relief valve. There are a few different variations in the designs used by various makers, but they all seem to work just fine. Some are on the dome end; others the base end. Different spring sizes, shapes and locations don't seem to matter in function nearly as much as they matter for fodder in a BITOG debate ... Some vehicle even have this BP feature in the engine block and it's not part of the filter, but most applications have this in the filter itself. So some filters may not list a BP value in the product data, because they don't have one.
You didn't ask, but I'll round out the last tidbit here. The oil system has a BP relief valve to protect the pump and filter. It's function is to keep the oil pressure from spiking to a point of rupturing the filter canister, and/or harming the pump as they are of positive displacement design. It will bleed off pressure to keep it at a safe level for system supply and yet still provide oil flow and pressure to the engine lube circuit. They are spec'd to the right dP and flow requirements to balance the need for relief with the need for supply.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Differences between ADBV and by-pass valve ? [Re: joyi] #4529029
09/29/17 04:23 AM
09/29/17 04:23 AM
South Oz, Australia
ozdrrider Offline
ozdrrider  Offline
South Oz, Australia
The Anti drain back valve stop the oil from siphoning back to the sump to keep the filter/pump and oil galleries primed with oil for the next engine start.
The Bypass valve on a e.g. Ryco Z30 (for a Holden/Buick) in this instance, lifts off its seat when suction Not positive pressure overcomes a preset restriction value in the filter by pass spring. Oil gets sucked through the filter with these models.
A chev Small block gets its oil filter pressurised through the oil filter media and once the bypass valve overcomes a preset restriction value in the filter housing, it springs off it seat to allow unfiltered oil flow.
The principle of the bypass valve is that any oil is better than not enough, and safety etc!
FYI: Oil will always flow from the outside of the filter media to the inside threaded hole.
To directly answer your question they are mechanical devices, you will find plenty of cut open examples on this site to look at, to imagine/see how they work. wink
And welcome too! smile
15 Pajero 3.2 Penrite 10w40 full syn 50K km
06 Suzuki Swift Sport 1.6L 5w30 Nulon full syn
17 Suzuki DR650: Trialing LUBEALLOY LA 35 ES
83 350 Chev powered Ski Boat: Nulon 15w40
Re: Differences between ADBV and by-pass valve ? [Re: joyi] #4529030
09/29/17 04:25 AM
09/29/17 04:25 AM
PA
d00df00d Offline
d00df00d  Offline
PA
welcome to BITOG!
Deleted the rest of my post as dnewton3 and ozdrrider have it covered. :]
2008 BMW M3
Re: Differences between ADBV and by-pass valve ? [Re: d00df00d] #4529043
09/29/17 05:09 AM
09/29/17 05:09 AM
Texas & Global
4WD Online confused
4WD  Online Confused
Texas & Global
ADV - My filters are vertical so IMO the worst case is a result of hydrostatic condition if there is a small amount of U-tube effect. The filter would remain full - but destination of evacuation at point of equalization creates a second or so delay in oil to top of engine. Residual film takes care of that.
What does that mean? You will not see me at Walmart with my mouth on an oil filter.
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: Differences between ADBV and by-pass valve ? [Re: joyi] #4529094
09/29/17 06:25 AM
09/29/17 06:25 AM
USA
dbeau Offline
dbeau  Offline
USA
What I don't understand is how the filter stays full after shut down. What keeps the oil from continuing past the media and out the outlet?
Re: Differences between ADBV and by-pass valve ? [Re: joyi] #4529096
09/29/17 06:29 AM
09/29/17 06:29 AM
New England
Virtus_Probi Offline
New England
Against my wishes, my wife took our daughter's car to some fleabag operation for a quickie oil change.
I was totally infuriated when my daughter said she had a really hard time starting her car before a softball game later that day, feeling that my wife had just bought us a new problem at cheapo lube instead of letting me cause problems for free. After making sure there was no leak from the drain plug, I opened the hood to make sure nothing was gushing up there and noticed that the oil filter was some Brand X that I had never heard of. On a whim, I put a Mazda-branded Tokyo Roki filter that matches Subaru bypass pressure specs on the car and we haven't had any trouble with it starting since then. I got some advice on what to look for on the Brand X filter from here and verified that it didn't have an ADBV.
I don't really know why my daughter's car didn't start well that one time and I honestly have to say it's probable that it had nothing to do with the oil filter, but I also know that it didn't start well the one time it sat for several hours with an oil filter without an ADBV.
2014 Forester XT, 90000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: Differences between ADBV and by-pass valve ? [Re: dbeau] #4529107
09/29/17 06:46 AM
09/29/17 06:46 AM
Texas & Global
4WD Online confused
4WD  Online Confused
Texas & Global
IMO - Hydrostatic U-tube principle ... inside geometry does not matter - height and fluid density does does - fluids on each side will seek an equilibrium and an air gap is formed on taller side. (Say you have no ADV or it leaks)
If the filter is at the low end of the U-tube (they are) - it remains full.
Re: Differences between ADBV and by-pass valve ? [Re: dbeau] #4529155
09/29/17 07:31 AM
09/29/17 07:31 AM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Good question. Combined with the adbv, vacuum, and surface tension of the media fibers, keeps the oil from going out through the media. This is for a base down application only. That's how I have come to understand it. "People" are known to make a hole in the filter to to allow the oil to drain out through the media.
Re: Differences between ADBV and by-pass valve ? [Re: Virtus_Probi] #4529157
09/29/17 07:33 AM
09/29/17 07:33 AM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
Link to thread where you cut the filter open please.
08 Honda Accord EX-L 2.4L M1 EP 0w20 145k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 193k
95 Yamaha Jog
Re: Differences between ADBV and by-pass valve ? [Re: Brybo86] #4529232
09/29/17 08:54 AM
09/29/17 08:54 AM
New England
New England
ADBV has been right by the holes and easy to see on the filters I've inspected, is there another design of which I'm not aware? Please teach me if I'm wrong. The consensus on here was it didn't have the ADBV if I couldn't see it through the holes.
No way I'm cutting a filter open, but I might have the Brand X in a bag in the garage and could google it if I can find it.
Last Change;
M1 5W30 d1G2
Re: Differences between ADBV and by-pass valve ? [Re: dbeau] #4529359
09/29/17 11:02 AM
09/29/17 11:02 AM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
NOTHING! Oil level in filter will stabilize at some point, depending on filter's orientation to the horizontal. On my V6, Toyota uses a nipple that is three times as long as needed to keep more oil in the filter.
Re: Differences between ADBV and by-pass valve ? [Re: joyi] #4529643
09/29/17 04:58 PM
09/29/17 04:58 PM
Irvine, CA
RevRider Offline
RevRider  Offline
Irvine, CA
A question on the ADBV, which material is better, the nitrile or the silcone for the valve? And, how do you tell the differnce? I notice some are black and others a reddish tone?
RevRider
Re: Differences between ADBV and by-pass valve ? [Re: RevRider] #4529786
09/29/17 07:08 PM
09/29/17 07:08 PM
USA
slacktide_bitog Offline
USA
silicone is the better material. It lasts longer.
Silicone ADBV's are usually red or terracotta color, while nitrile is black.
Re: Differences between ADBV and by-pass valve ? [Re: Yah-Tah-Hey] #4529808
09/29/17 07:38 PM
09/29/17 07:38 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Surface tension. I did a test years ago to see how well the ADBV worked on a PureOne.
Drainage setup for the filter to test the ADBV.
While the filter was still pretty hot I put it base side down in a funnel and let the hot oil drain out, and then left it to drain for a whole week. After the week of draining, I then jammed some folded over Q-tip sticks in 3 of the base plate holes to open up the ADBV to let the guts drain out in a clean glass. What drained out was what the ADBV was holding back for a week.
Results of the oil trapped by the ADBV - it came out to 6 ounces.
A rough calculation of the volume between the center core and the can shell showed to be about 13.7 cu-in. Six ounces of fluid will take up 10.8 cu-in, so this means basically the ADBV was keeping the entire space between the can and center core full of oil indefinitely.
