Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
38 registered (alarmguy, billt460, bradepb, BoiseBound, bullwinkle, crazy_raccoon, 6 invisible), 957 Guests and 36 Spiders online.
65282 Members
67 Forums
285683 Topics
Page 1 of 2 1 2 >
#4528999 - 09/29/17 04:01 AM Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles
mooferz Offline
Loc: TX
Here's my first UOA for this car. 1MZ-FE VVTi with 231000 Miles.
Ran 3218 Miles on Delo SD 15w-30 and a Bosch D3422.
This is mostly on E30 fuel- I usually add a few gallons of E85 to my tank while filling up.
I had reused the oil filter and had like a quart-and-a-half residual oil from the previous fill- API SL Quaker State Defy 10W-30.
Viscosity is rather low. Sure, this engine is hard on oil, but I wasn't expecting it in the SAE 20 range.
After a few more UOA's, I'm going to replace the rear valve cover with a redesigned one with the spin-on PCV valve.
I'm interested to see how this is reflected in the UOA trends, since this supposedly mitigates the oil sludging this engine is notorious for.
2001 Lexus ES300, 235k mi, German Castrol 0w-40, Fram TG8316
1985 BMW R80RT (1L)- M1 15w-50
1993 Volvo 945 Turbo- Rotella T5 10W-30 (CJ-4)
#4529012 - 09/29/17 04:40 AM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: mooferz]
Rolla07 Offline
Loc: MTL, CANADA
Wheres the sodium from? Delo or prev QS have any?
Wear metals are low. Any reason you are using 15w oil?
Edited by Rolla07 (09/29/17 04:40 AM)
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
#4529018 - 09/29/17 05:01 AM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: Rolla07]
mooferz Offline
Loc: TX
Don't think either these have sodium in their add pack. I've run some Valvoline in here recently- might be residual from that.
Using this 15W-30 mainly since I have a bunch of it from when O'Reilly had it on clearance. Don't need to worry much about cold pumping characteristics here in Texas. Will be using 10W-30 Rotella T5 next.
#4529065 - 09/29/17 06:47 AM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: mooferz]
krismoriah72 Online   content
Loc: wv
Keep an eye on the fuel pressure regulator on the end of the rail. I have replaced two due to E fuel. There is a rubber diaphragm that leaks pretty good. Also if u havent done it yet the fuel filter is probably pretty black after using E fuel.
I had one a few years back and pulled the front valve cover to make sure it wasnt a sludger.. dang good car.
#4529075 - 09/29/17 06:56 AM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: mooferz]
Camprunner Offline
Loc: MA.
That motor must be tough on oil I am surprised that this Delo thinned out its a stought oil.
#4529137 - 09/29/17 08:18 AM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: Camprunner]
kschachn Offline
Loc: Upper Midwest
How can you tell that this oil has been mechanically sheared as opposed to diluted by fuel? Considering the oil being used I would guess that it isn't the former.
This is typical with the UOAs posted here, even when an inferred number for fuel is being provided. I don't think that conclusions as to what is happening can be made based on the limited information that's provided. If it is indeed fuel then it doesn't matter what brand of oil is being used.
1994 BMW 530i, 227K
1996 Honda Accord, 262K
1999 Toyota Sienna, 394K
2000 Toyota ECHO, 267K
#4529184 - 09/29/17 08:58 AM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: kschachn]
mooferz Offline
Loc: TX
Perhaps it is indeed fuel dilution. Maybe I should stick to E10 for an OCI and compare.
Now that I think of it, I haven't looked at the long term fuel trims in a while...
Thanks, I'll watch out for the leaking pressure regulator.
I last changed the fuel filter about a year and a half ago, not long after starting to run gasohol.
Just remembered that I've used Valvoline VR1 as a topup oil recently, perhaps during the QSD fill, which explains the sodium.
#4529246 - 09/29/17 10:09 AM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: mooferz]
BrocLuno Offline
Loc: Kalifornia Kollective
I'm not saying your motor could not shear down Delo SD, but it would not be my first guess. I'm also thinking fuel dilution. If any top-up's used different oils, we can't be sure about anything because of how the add paks might have interacted. It's not terminal by any means, but the mixed chemistry can't be defined w/o a lot of lab work.
The basic benefit from your sample was to see that wear metals were low. The rest is sort of a guessing game with the fuel used and the mix of lubes ...
#4529326 - 09/29/17 11:23 AM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: mooferz]
beanoil Offline
Loc: Midwest, Illinois
Shearing has not been my experience with Delo SD.
I bet the E30 has something to do with it as well.
I agree with BrocLuno on his points. Spot on.
beanoil: Tough under heat, real dirty afterwards.
#4529368 - 09/29/17 12:05 PM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: mooferz]
Oro_O Offline
Loc: Seattle-ish, WA
From a fair number of UOA's I've read on the 1mz-fe, it's NOT that hard on oil. There are a number of excellent reports out there of great numbers run on full synthetics out to 8k miles and more. This buttresses what the prior posts are saying.
If you change the oil on a reasonable interval, you won't have a sludge problem and changing the rear cover is a not required if you don't plan on running dino oil 15k or more. There have been 0 of these engines shown to sludge with consistent oil changes appropriate to the usage and oil.
The oil choice is interesting, and I had considered it for ours (later ES). But I thought the specs/price didn't make it that attractive vs. similarly robust 10w-30 full synthetics out there.
#4529891 - 09/29/17 10:21 PM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: mooferz]
addyguy Offline
Loc: Canada
Wear metals are low, but oil sure took a beating - down to 8.7cst from 12; and down to 3.2 TBN after 3k miles!
I thought this oil would be a lot more resilient to adverse conditions!
Sure didn't hold up, what a poor showing.
2010 Kia Soul 2U - 2.0L I-4, auto; 126k miles.
M1 EP 10W-30; OEM Kia filter.
#4529921 - 09/29/17 11:08 PM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: mooferz]
danielLD Offline
Loc: Chicago
since fuel dilution is occurring, the oil used is even more important.
why you would still use such a thick oil is beyond me. 15W in Texas doesn't matter. You're diluting because it's taking your engine a lot longer to get proper ring seal, one thing most/all rarely consider. It's why your viscosity is getting slashed.
E30 has NOTHING to do with the shear. If ANYTHING, ethanol allows for much longer OCI's as it does not corrode internals, nor does it affect viscosity much. It also leaves little to no deposits in the engine.
I would continue the E30 runs.
Consider better UOA testing to truly reveal your engines condition.
#4529988 - 09/30/17 05:48 AM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: danielLD]
mooferz Offline
Loc: TX
This 15W-30 isn't THAT thick. I doubt this methodology would have such an extreme effect.
Can't find it offhand, but there's a guy on here that's running straight SAE 30 in a 3MZ and has experienced nothing comparable to this.
You're right about a better UOA leading to less speculation- the next analysis will go to Blackstone (for 3x the cost. whistle )
The long term fuel trims on the drive to work last night were respectively ~7 and ~3 for banks 1 and 2, so the ECU might not have been injecting the ideal amount of fuel to either or both banks.
Filled up with gas last night and reset the ECU.
I'm 700 miles into the current OCI, and like half of that was on E10 due to the recent post-gasoline-shortage E85 shortage. Will run the current fill till 3500 or so.
#4530099 - 09/30/17 09:43 AM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: mooferz]
danielLD Offline
Loc: Chicago
Blackstone hardly qualifies for a decent UOA. Their expensive and provide little data. Get a UOA with an analyst that will actually indicate to you what is happening.
ECU is fine, variance is never perfect.
You're only talking with a guy who did extensive studies proving that oil start up temps have huge impacts on wear, for Ford, Honda and Lexus.
#4530356 - 09/30/17 03:20 PM Re: Delo SD 15W-30, 2001 Lexus ES 300 - 3218 Miles [Re: danielLD]
mooferz Offline
Loc: TX
So who would you suggest using?
Where can we see your evidence and results?
Not sure how relevant this would be since wear doesn't appear abnormal.
Page 1 of 2 1 2 >
