AAP 25% Off
by Egg_Head
Today at 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
Today at 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
Today at 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
Today at 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
Yesterday at 10:41 PM
Chevy brought the blazer back
by WiskyBadger
Yesterday at 10:07 PM
LC20 and uses in modern motor oil
by synman
Yesterday at 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
Yesterday at 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
Yesterday at 08:37 PM
Fram SureGrip coating
by mobilaltima
Yesterday at 08:24 PM
Manual transmissioned electric car
by mjoekingz28
Yesterday at 06:45 PM
1991 Toyota Previa New JDM engine Redline
by Kurtatron
Yesterday at 06:26 PM
8 yr old channeling John Bonham
by Toy4x4
Yesterday at 06:02 PM
Traveller nlgi 2
by Spitter
Yesterday at 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
Yesterday at 05:08 PM
Any nano reefers here?
by RichardS
Yesterday at 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
Yesterday at 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
Yesterday at 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
Yesterday at 04:31 PM
help me choose...
by chaindrive
Yesterday at 04:07 PM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
70 registered (4WD, BoiseRob, brages, 01rangerxl, BeerCan, billt460, 7 invisible), 1170 Guests and 36 Spiders online.
65294 Members
67 Forums
285753 Topics
#4528623 - 09/28/17 05:20 PM Yamaha yxz1000r
SuzukiGoat Offline
Loc: Louisiana
This is a blend of 1qt synthetic VR1 20w50 and 2.75 qts of conventional VR1 20w50.
Unit sees A LOT of high rpm use and this change saw quite a few 70 mile runs at over 8k rpm.
Thoughts?
2003 Nissan Xterra 4x4 M1 HM 10w40
2001 Toyota 4runner 4x4 M1 0w40
2016 Yamaha YXZ1000R VR1 20w50
#4528637 - 09/28/17 05:34 PM Re: Yamaha yxz1000r [Re: SuzukiGoat]
JohnnyJohnson Offline
Loc: Wet side WA
My thought would be with a once a year OCI likely why aren't you just using all Full Synthetic since it a proven fact it has 50% less wear over conventional?
2004 Toyota Corolla 121707
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4528644 - 09/28/17 05:41 PM Re: Yamaha yxz1000r [Re: SuzukiGoat]
SuzukiGoat Offline
Loc: Louisiana
...not sure where that is a proven fact? But, I actually have about 30 qts of dino vr1 and only 5 or 6 synthetic quarts.
In any case, a once a year oil change interval is not likely.
Changed at 50 miles. 200 miles. 800 miles. 1660 miles. 2460 miles. 4344 miles. The longest interval being 1844.
The unit only has 116 hours of usage on it. 10 of which were on it when I bought it from the key being left on.
Oil change intervals are uncharted territory for this type of usage.
#4528687 - 09/28/17 06:15 PM Re: Yamaha yxz1000r [Re: JohnnyJohnson]
CT8 Offline
Loc: Idaho
50% less wear where?
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4528695 - 09/28/17 06:23 PM Re: Yamaha yxz1000r [Re: SuzukiGoat]
krismoriah72 Offline
Loc: wv
Wow you are averaging 40mph
My unit has 1200 miles and 120 hrs..my riding sees alot of hills and mountains and dusty roads so i change mine every 20hrs. Im sure i am tossing good oil after seeing your UOA. I ride with a couple of yxz1000s they sound wicked. I have a Teryx4.
#4528779 - 09/28/17 07:53 PM Re: Yamaha yxz1000r [Re: SuzukiGoat]
maverickfhs Offline
Loc: VA
Awesome. Just curious, Is it regular Valvoline and not motorcycle specific, right?
2006 Civic EX 200K/AT
2006 Acura TSX 177K/AT
#4528876 - 09/28/17 09:26 PM Re: Yamaha yxz1000r [Re: maverickfhs]
SuzukiGoat Offline
Loc: Louisiana
Correct. The transmission has a separate oil supply.
#4529128 - 09/29/17 08:11 AM Re: Yamaha yxz1000r [Re: SuzukiGoat]
sunruh Online   content
Loc: Cedar Park, TX
once again the stoners are smoking crack
this oil does not give a flash of ONLY 400 unless there is fuel in it
period
your flash should be well above 425 and i have 1 uoa of vr1 that shows flash of 465
vr1 is too good of an oil to have a c r a p flash of just 400
and
if the stoners could actually read a chart they would see that 80.x is NOT 50wt
it is 40wt!!! it takes a susvis of 83.11 to be 50wt
so definately there is fuel in this sample!
the rest of your sample results look good...IF they can be trusted
i mean if you cant get fuel and flash right in the report...what else is not correct?
imho, keep using this brew!
steve
Edited by sunruh (09/29/17 08:12 AM)
motorcycle oil myth buster
#4529249 - 09/29/17 10:10 AM Re: Yamaha yxz1000r [Re: sunruh]
SuzukiGoat Offline
Loc: Louisiana
it is 40wt!!!
Any chance a 3 cyl turning 7-10.5k rpm for 2000 miles sheared it out of spec?
Given how lean this motor runs, and the compression, I would not expect fuel issues.
#4529369 - 09/29/17 12:06 PM Re: Yamaha yxz1000r [Re: SuzukiGoat]
Loc: Cedar Park, TX
im sorry you didnt understand what i wrote.
#4529434 - 09/29/17 01:52 PM Re: Yamaha yxz1000r [Re: sunruh]
SuzukiGoat Offline
Loc: Louisiana
I'm sorry you're pretentious.
