Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
93 registered members (addyguy, ArrestMeRedZ, 2009Edge, anndel, 53' Stude, 240_Ed, 15 invisible), 2,070 guests, and 63 spiders.
Topics286,203
Posts4,904,149
Members67,576
Most Online2,967
Mar 10th, 2019
M1 5w-30 / 16,700km / 2014 Ford Escape 1.6L Eco #4528606
09/28/17 04:57 PM
09/28/17 04:57 PM
Alberta, Canada
Joseph_S37 Offline OP
Alberta, Canada
Hello Everyone!
Here's the first oil analysis from the wifes 2014 Ford Escape with the 1.6L ecoboost engine. The oil was in use from 30 Oct. 2016 - 28 Aug. 2017, covering 16,700km of use. Note KM not miles.
Filter used was a Fram XG filter. Air filter was changed at the same time as this oil was dumped, at the end of august this year.
Let me know what you all think!
Re: M1 5w-30 / 16,700km / 2014 Ford Escape 1.6L Eco [Re: Joseph_S37] #4528619
09/28/17 05:17 PM
09/28/17 05:17 PM
MN
oil_film_movies Online content
oil_film_movies  Online Content
MN
With silicon that high, definitely need to check to see if the airbox around the air filter, the entire path going into the engine is tight. If it looks good, then it might just have been a bad air filter with more porosity thant it should have (manufacturing variation). Extra silicon is probably what caused the extra iron wear.
Insolubles were high, which seems weird since you used a Fram Ultra which should be catching it. Try a MicroGreen oil filter to see if that gets more junk out. Amazon.com or MicroGreen's website.
Re: M1 5w-30 / 16,700km / 2014 Ford Escape 1.6L Eco [Re: Joseph_S37] #4528631
09/28/17 05:30 PM
09/28/17 05:30 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
Iron is three times the norm that would sure have me wondering.
2004 Corolla 130005
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: M1 5w-30 / 16,700km / 2014 Ford Escape 1.6L Eco [Re: Joseph_S37] #4528764
09/28/17 07:37 PM
09/28/17 07:37 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
If the car is a "keeper" don't worry until the next sample. A trend might be more interesting that one sample.
Re: M1 5w-30 / 16,700km / 2014 Ford Escape 1.6L Eco [Re: Joseph_S37] #4528822
09/28/17 08:23 PM
09/28/17 08:23 PM
Canada
addyguy Online content
addyguy  Online Content
Canada
Silicon and insolubles are high, and iron and aluminum are high.
Dirt is getting past the air filter and causing elevated wear.
2010 Kia Soul 2U - 2.0L I-4, auto; 141k miles.
M1 EP 10W-30; OEM Kia filter.
Re: M1 5w-30 / 16,700km / 2014 Ford Escape 1.6L Eco [Re: Joseph_S37] #4529399
09/29/17 12:49 PM
09/29/17 12:49 PM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
For almost 10,500 MILES on this OCI for an EcoBoost engine the overall wear is good. The wear that stands out appears to be the result of dirt getting into the engine some where along the line. Was that the factory air filter you changed out this oil change? Who did your previous oil changes, was it yourself or some place else that might have "inspected" the air filter as part of the oil change service. If not did you open the air box to inspect the air filter. As others have said here make sure all the intake connections are proper and tight, plus any vacuum lines. Though if there is a vacuum line was leaking I'd suspect there would be a running issue. You're a brave fellow running an EcoBoost for that mileage and length of time grin2. But it goes to show us that this DI turbo engine overall held up well for the use. What brand air filter did you use as the replacement?
Whimsey
Re: M1 5w-30 / 16,700km / 2014 Ford Escape 1.6L Eco [Re: addyguy] #4529407
09/29/17 12:55 PM
09/29/17 12:55 PM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
This proves the usefulness of at least the occasional UOA to monitor at least somewhat what's going on in the engine, especially if it's a relatively new vehicle and you intend to keep it. It gives you a chance to hopefully try to correct the problem.
Whimsey
Re: M1 5w-30 / 16,700km / 2014 Ford Escape 1.6L Eco [Re: Whimsey] #4529958
09/30/17 01:18 AM
09/30/17 01:18 AM
Alberta, Canada
Alberta, Canada
Whimsey
Thank you sir
that was the original factory air filter that was run up to the end of this OCI. The dealership did the first oil change, and I've done the rest since then, so I might guess the air filter has been leaking since that first oil change. Hopefully that changes now.
Now I too was worried running the oil out this long, but we made sure to do frequent highway runs on a regular basis, and it looks like it payed off in terms of keeping fuel dilution minimal.
With a new air filter installed, hopefully the next run shows better results.
