Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
80 registered members (avi1777, ARCOgraphite, Bailes1992, BeerCan, Blkstanger, Berny, 8 invisible), 1,622 guests, and 59 spiders.
Topics286,387
Posts4,907,333
Members67,614
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Anyone running "synthetic" coated bullets? #4528572
09/28/17 04:11 PM
09/28/17 04:11 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
I found a pretty good deal on some Federal "Syntech" ammunition. Just curious if there are any users on here with positive or negative results...
Thanks!
Re: Anyone running "synthetic" coated bullets? [Re: JHZR2] #4528590
09/28/17 04:24 PM
09/28/17 04:24 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Must be great stuff it looks like its outlawed in CA.
2004 Corolla 130035
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Anyone running "synthetic" coated bullets? [Re: JHZR2] #4528593
09/28/17 04:25 PM
09/28/17 04:25 PM
Michigan
khittner Offline
khittner  Offline
Michigan
So there is an actual "silver bullet" for long engine life?
Re: Anyone running "synthetic" coated bullets? [Re: khittner] #4528602
09/28/17 04:48 PM
09/28/17 04:48 PM
On the road Midwest
Ihatetochangeoil Offline
On the road Midwest
"Federal" manufactures handgun ammunition...The term "bullets" is being used literally, not metaphorically.
Whatever
Re: Anyone running "synthetic" coated bullets? [Re: JHZR2] #4528604
09/28/17 04:50 PM
09/28/17 04:50 PM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
What are the purpose of these? Does it have something to do with "lead contamination"?
Re: Anyone running "synthetic" coated bullets? [Re: JHZR2] #4528607
09/28/17 04:57 PM
09/28/17 04:57 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I rented a Walther PPQ and the range makes you buy ammo from them when renting and this was the required ammo. It was $12.99 per 50. Vances said they are the cheapest seller of this ammo in Ohio. I had some left over for my personal 9MM. It shoots very, very clean. Every componment of the ammo is designed around being utmost clean. It has a tad less recoil than other 115 gr 9MM ammo I've shot. It is definitely target ammo. I suspect a range that requires this ammo doesn't need to clean the rental pistols between each rental use. No jams in my 200 rounds of experience with it.
Me: 13' VW GTI 3 door 6 speed manual
Re: Anyone running "synthetic" coated bullets? [Re: Ihatetochangeoil] #4528608
09/28/17 05:00 PM
09/28/17 05:00 PM
USA
ArcticDriver Offline
USA
This is a very funny exchange.
Multiple Diesel and Gasoline vehicles
Re: Anyone running "synthetic" coated bullets? [Re: JHZR2] #4528625
09/28/17 05:22 PM
09/28/17 05:22 PM
TN USA
Crispysea Offline
Crispysea  Offline
TN USA
Reloaders have been powder coating lead bullets for years. Federal just copied the concept. They even sell the loose bullets for loading now.
Re: Anyone running "synthetic" coated bullets? [Re: skyactiv] #4528626
09/28/17 05:22 PM
09/28/17 05:22 PM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
I don't know ANY range that does that. Regardless of what kind of ammo they use.
Re: Anyone running "synthetic" coated bullets? [Re: JHZR2] #4528632
09/28/17 05:31 PM
09/28/17 05:31 PM
Ohio
jjjxlr8 Offline
jjjxlr8  Offline
Ohio
I'd like to see the bore after using a few hundred rounds of these. I bet some of the polymer stays in the rifling, at least in a traditionally rifled barrel. What's the best solvent for cleaning plastic out of your bore?
1993 Toyota MR2 Turbo
2008 Mazdaspeed3
2014 Toyota Highlander XLE
Re: Anyone running "synthetic" coated bullets? [Re: JHZR2] #4528692
09/28/17 06:22 PM
09/28/17 06:22 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
I'll have to get a box or two and try them out in my .40 S&W.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Anyone running "synthetic" coated bullets? [Re: jjjxlr8] #4528787
09/28/17 07:59 PM
09/28/17 07:59 PM
Georgia
AVB Offline
AVB  Offline
Georgia
I think that is what the acetone in "Ed's Red" is for.
These sound a lot like the old Federal Nyclad ammo with a cleaner powder and primer.
Re: Anyone running "synthetic" coated bullets? [Re: billt460] #4528793
09/28/17 08:03 PM
09/28/17 08:03 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
"lead contamination" of what? I suspect since the interior is lead, contamination isn't the consideration... Its more the fact that there is some copper on a typical bullet that is worth some amount of money, and this is cheaper.
And personally, Id lean towards the use of this, over the copper washed over steel from Russian ammo, I think...
In terms of other purposes, there's a claim of 12% less friction. There are some reviews that confirm that the barrel stays cooler, though I don't know that any are "scientific".
Re: Anyone running "synthetic" coated bullets? [Re: JHZR2] #4528802
09/28/17 08:09 PM
09/28/17 08:09 PM
Mahzurrah!
KCJeep Offline
KCJeep  Offline
Mahzurrah!
I got a couple boxes of 9mm on sale and burned them up. Seemed like good stuff to me.
2018 VW Passat GT VR6 - 6k - Valvoline MST 5w40 - VW OEM filter
2012 KIA Sedona 96k - PP HM 10w30
2009 Ford Focus 135k - Supertech FS HM 5w30
2004 Jeep Grand Cherokee, gone but not forgotten.
Re: Anyone running "synthetic" coated bullets? [Re: JHZR2] #4528810
09/28/17 08:16 PM
09/28/17 08:16 PM
Ohio
jjjxlr8 Offline
jjjxlr8  Offline
Ohio
In testing by the US military, steel jacketed bullets (copper washed or not) did not cause more barrel wear than traditional copper jacketed bullets. The more important factor for barrel wear, specifically throat, gas port, and muzzle erosion, is the type or propellant used. The propellant can make a significant difference in barrel life.
2008 Mazdaspeed3
Page 1 of 3 1 2 3
