Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
Wix 51522 vs Fram XG9837
by RDY4WAR. 03/25/19 04:13 PM
Rural King: 20K Lumen LED Tripod Worklight $34.93
by skyactiv. 03/25/19 03:55 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
129 registered members (2015_PSD, 2010Civic, agpatel, ABerns, 77GrandPrix, 16 invisible), 2,022 guests, and 67 spiders.
Topics286,429
Posts4,908,089
Members67,622
Most Online2,967
Mar 10th, 2019
Humidifier install on existing furnace #4528519
09/28/17 02:44 PM
09/28/17 02:44 PM
Chicago, IL
Brybo86 Offline OP
Brybo86  Offline OP
Chicago, IL
I have an older furnace that i wired up to an ecobee4 thermostat.
I bought an aprilaire 500m
I'm not sure what is the best placement of the humidifier.
Supply stack is out of question too cramped.
I could cover over an old basement return which I believe is supposed to be a dehumidifier of sorts for basement in the summer.
Or it could go on the back and leave the old basement return open?
I think I can run a single wire from ecobee acc+ terminal to water solenoid on humidifier
Without needing to use the transformer or manual humidistat it came with
08 Honda Accord EX-L 2.4L M1 EP 0w20 153k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 199k
95 Yamaha Jog
Re: Humidifier install on existing furnace [Re: Brybo86] #4528589
09/28/17 04:23 PM
09/28/17 04:23 PM
Madison, Wisconsin
TWG1572 Offline
TWG1572  Offline
Madison, Wisconsin
Ours is mounted on the supply side, but from what I understand the preferred side is the return. That way there is no chance a leak would go into the furnace. And it would be exhausting into negative pressure, vs. trying to blow into positive pressure on the supply side.
I just hooked an Ecobee4 up to ours. I used the two wire ACC + and - connections. The one wire method also works, but it will need to be internally powered.
Re: Humidifier install on existing furnace [Re: Brybo86] #4528667
09/28/17 06:00 PM
09/28/17 06:00 PM
CentralPA
SilverGt Offline
SilverGt  Offline
CentralPA
I've installed many humidifiers .You do "not" want it on the return. The moisture from the humidifier going across the heat exchanger of the furnace will cause it to prematurely rust through.
1984 Ford Mustang GT Castrol GTX 10w-40
2017 Chevrolet Trax Castrol Edge 5W-30
2003 BMW 325xi. Castrol Edge 0w-40
Re: Humidifier install on existing furnace [Re: Brybo86] #4528673
09/28/17 06:02 PM
09/28/17 06:02 PM
CentralPA
SilverGt Offline
SilverGt  Offline
CentralPA
Rust soon turns into holes .Then allowing carbon monoxide into the airflow
Re: Humidifier install on existing furnace [Re: Brybo86] #4528728
09/28/17 07:11 PM
09/28/17 07:11 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
Mine is mounted so it draws air from the warm side, across the humidifier, and feeds it to the return. It takes advantage of the pressure differential to enhance flow. This is the way I found it installed 32 years ago.
Re: Humidifier install on existing furnace [Re: Brybo86] #4528746
09/28/17 07:26 PM
09/28/17 07:26 PM
Chicago, IL
Brybo86 Offline OP
Brybo86  Offline OP
Chicago, IL
Is the air immediately behind the humidifier panel more humid than the air 5ft away from it?
Humidifiers nowadays are evaporators they don't disperse droplets unless you go the steam route.
I have used the cool mist room humidifiers that blow air over a panel and if you put your hand in front of them they don't condense moisture on your hand.
I have seen old humidifiers mounted on horizontal ducts with a spinning rotor inside that caused some rust.
I'm planning on running a wire from the C furnace panel to the humidifier then the acc+ from ecobee
Did you jump C and acc - behind the thermostat or do you have a powered fan humidifier?
Does this look too close on the supply side, about 3.5 inches from exhaust duct
01 Kymco People 50
95 Yamaha Jog
Re: Humidifier install on existing furnace [Re: Brybo86] #4528772
09/28/17 07:48 PM
09/28/17 07:48 PM
Texas
JustinH Offline
JustinH  Offline
Texas
whats wrong with a free standing cool mist humidifier?
I use one for the mild texas winter and it does a good job.
Mine has no filter and works fine with standard water. I fill it with a couple gallons of bath tub water every night the furnace runs.
'11 Hyundai Sonata GLS
'11 Scion XB
Re: Humidifier install on existing furnace [Re: Brybo86] #4528775
09/28/17 07:52 PM
09/28/17 07:52 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
I also want to install one but have heard mixed reviews about how well they actually work.
96 Grand Marquis
01 Sable LS
02 Montero
Re: Humidifier install on existing furnace [Re: Brybo86] #4528780
09/28/17 07:57 PM
09/28/17 07:57 PM
Chicago, IL
Brybo86 Offline OP
Brybo86  Offline OP
Chicago, IL
Last winter I ran a warm mist/stream unit that could barely keep a bedroom moist, Honeywell easycare
01 Kymco People 50
95 Yamaha Jog
Re: Humidifier install on existing furnace [Re: Brybo86] #4530023
09/30/17 08:00 AM
09/30/17 08:00 AM
Madison, Wisconsin
TWG1572 Offline
TWG1572  Offline
Madison, Wisconsin
I'm guessing your Ecobee question might be directed at me? I have an Aprilaire 760, so it's a powered fan model. It's plugged into an outlet in the furnace room. I don't remember the details exactly, I just followed the included directions for a two wire install. We had an existing humidistat mounted near the thermostat already, so I just moved the wires over to the Ecobee.
The internet is full of debate over supply vs. return side. Sorta like Pennzoil vs Valvoline. I'm no pro, so won't jump in the argument. I'm pretty sure my humidifier would be more efficient on the return side - just because of the negative pressure differential, vs fighting the positive pressure on the supply side. And I don't think the air going into the heat exchanger would be moist enough to make any difference. It's a small amount of air blown through a pad, which is then mixed with a lot of incoming dry air. Just my 2 cents based on internet reading.
I'm excited to try to humidity programming on the Ecobee that varies humidity based on outside temp. That's something I've forgotten to do before when the temp dropped, and had the iced up windows to prove it. But overall, I really like the whole house humidifier. Hope you do too!
Re: Humidifier install on existing furnace [Re: Brybo86] #4538586
10/09/17 10:57 PM
10/09/17 10:57 PM
Chicago, IL
Brybo86 Offline OP
Brybo86  Offline OP
Chicago, IL
Got it all hooked up!
01 Kymco People 50
95 Yamaha Jog
