AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
76 registered members (2003f7, Aero540T, 2010Civic, agpatel, AdditiveOCD, 8 invisible), 1,333 guests, and 63 spiders.
Topics286,438
Posts4,908,166
Members67,622
Most Online2,967
Mar 10th, 2019
Very over tightened drain plug #4528507
09/28/17 02:29 PM
09/28/17 02:29 PM
Albany, NY
ford46guy Offline OP
Albany, NY
tl;dr
This guy is a tech..
Another guy brought his van to {insert quick change place} and they torqued the bolt up enough to make the bung spin in the pan. The oil pan had to come off(there was a video before this).
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Very over tightened drain plug [Re: ford46guy] #4528513
09/28/17 02:35 PM
09/28/17 02:35 PM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
Good n' tight!
08 Honda Accord EX-L 2.4L M1 EP 0w20 153k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 199k
95 Yamaha Jog
Re: Very over tightened drain plug [Re: ford46guy] #4528522
09/28/17 02:47 PM
09/28/17 02:47 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
That sucks...Maybe some stooges put thread crazy locker on it ...
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PPHM 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: Very over tightened drain plug [Re: ford46guy] #4528530
09/28/17 03:02 PM
09/28/17 03:02 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
I don't think that's how torque wrenches work...
Re: Very over tightened drain plug [Re: ford46guy] #4528533
09/28/17 03:05 PM
09/28/17 03:05 PM
Florida
SilverSnake Offline
SilverSnake  Offline
Florida
I was particularly impressed with the "sandle in the pan" bracing method. I must have been asleep when they taught that technique in all the mechanics courses I have taken over the years.
Other than that, just one more reason not to take your car to a quick oil change "shop."
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PUP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
Re: Very over tightened drain plug [Re: SilverSnake] #4528534
09/28/17 03:13 PM
09/28/17 03:13 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
crackmeup
Pete.
Re: Very over tightened drain plug [Re: ford46guy] #4528538
09/28/17 03:15 PM
09/28/17 03:15 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
I definitely can empathize with that.
The first oil change I did after I bought my Fusion was.. problematic. When I went to remove the drain plug, I found that it had apparently been hand-tightened by Superman. Using a standard socket wrench and socket, I could not budge it, but I did find that the bolt head was noticeably deformed - So much so that the socket would not even go on straight.
My only solution was to grab an impact socket in the correct size, and carefully hammer it on the drain plug, and then use my breaker bar to carefully work it off. Luckily, it came off without causing damage to the oil pan.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 271,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 62,000mi
Re: Very over tightened drain plug [Re: ford46guy] #4528547
09/28/17 03:24 PM
09/28/17 03:24 PM
Canuck living in California
KrisZ Offline
KrisZ  Offline
Why didn't the guy flip the pan upside down and let it brace against the wrench? Could've saved us a lot of foot watching. Although I found the choice of footwear quite matching the job at hand lol.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Very over tightened drain plug [Re: SirTanon] #4528585
09/28/17 04:18 PM
09/28/17 04:18 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
Yep they did that to my Duramax when I was on my trip to the Gulf 4 years ago. I wanted to change the Oil when I got back with all the heavy towing had one H of a time getting it off. Had to replace the plug it was toast! I guess that's why those people make minimum wage!
2004 Corolla 130035
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Very over tightened drain plug [Re: ford46guy] #4528594
09/28/17 04:25 PM
09/28/17 04:25 PM
Specific Ocean
Kibitoshin Offline
Kibitoshin  Offline
Specific Ocean
I still can't wrap my head on how you can overtighten an oil drain plug or oil filter. I've done my own oil changes for ages and it does not take a lot of torque or require power or air tools to fasten a bolt that gets frequently removed.
Seriously why do you need air tools to do oil changes? What are the iffy lube monkeys doing with air tools that I can hear in their shop? Hopefully not on drain bolts and they are using it to jerk off themselves instead.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: Very over tightened drain plug [Re: ford46guy] #4528643
09/28/17 05:41 PM
09/28/17 05:41 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
Just to many Idiots out there...
This should read on the headlines
Beware people ... shops armed with air tools... with people who don't know how to use them...
No need for air tools for oil changes...
Pete.
Re: Very over tightened drain plug [Re: ford46guy] #4528664
09/28/17 05:56 PM
09/28/17 05:56 PM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
Torque wrenches are not generally used as breaker bars, BYMMV.
Re: Very over tightened drain plug [Re: ford46guy] #4528741
09/28/17 07:25 PM
09/28/17 07:25 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
While in the hospital away from our home my wife had the 4Runner oil changed. When I changed the oil the next time I had to pound a 3' long screwdriver through the filter and pull really hard with both hands to get it off. It finally let go with the feeling of something snapping. The oil pan drain plug, just a 14mm bolt required a breaker bar to get loose. They must have had the Incredible Hulk in his green state doing oil changes that day.
Re: Very over tightened drain plug [Re: ford46guy] #4528748
09/28/17 07:27 PM
09/28/17 07:27 PM
Central Florida
Mr Nice Offline
Mr Nice  Offline
Central Florida
If you want it done correctly.... Do it yourself.
Re: Very over tightened drain plug [Re: ford46guy] #4528763
09/28/17 07:37 PM
09/28/17 07:37 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
The gentleman in the video is a materials science PhD and a professional automotive diagnostician... but of course the superior minds of BITOG are going to make fun of him for wearing sandals, not putting the oil pan the way they'd like, et cetera.
