Bad cylinder 3 misfire.
by Hemispheres. 12/14/18 02:49 PM
Small leak at toilet base - bad wax ring?
by Oro_O. 12/14/18 02:38 PM
Ok I take it back about Keurig
by StevieC. 12/14/18 02:29 PM
Edge 5W-30 7.9k miles '13 F150 5.0
by dustyroads. 12/14/18 02:11 PM
Stick with WSS-M2C946-A?
by BlueFog. 12/14/18 01:42 PM
How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
wsalopek, jcr1293, maxwellk, BlueFog, Frank_G35
66682 Registered Users
101 registered members (barryh, 03s, bdcardinal, ARB1977, 94astro, 13 invisible), 2,002 guests, and 50 spiders.
Topics295,068
Posts4,927,192
Members66,682
Most Online2,553
Oct 27th, 2018
Suggestions for ls1 using my stash? #4528407
09/28/17 11:21 AM
09/28/17 11:21 AM
colorado springs
cool_breeze Offline OP
colorado springs
Hey guys, i know im over thinking this a little but isnt that the fun of this forum?
I am getting ready to change the oil on my ls1. Its in a weekend fun car so mostly sits in the garage except for weekend drives and a handful of track days per year. Maybe 2k miles a year but sees will see high rpm usage, 4-7k constantly for 20 minute stints this weekend and makes about 425whp.
Oil filter fram ultra
Id like to get rid of some of this vr1 if its possible. Or should i just avoid it..
So far the Normal oil has been M1 ow40 with great results but dont have any right now.
What i have in my stash now:
3qts vr1 syn 20-50 sl
3qts vr1 syn 10w30 sl
3 qts vr1 dino 50 (states exceeds sn/sm/sl )
4 qts Val syn HM 0w-20
4 qts val syn 5w-40 power mst
4 Edge 0w40 sn
6 edge 5w-50 sn
8 M1 15w50 sn
thanks!
1994 Land Cruiser: 222k
1997 BMW M3/LS1: M1 0w-40
Lexus Gx470: PP 5w-30
Cannondale scalpel to offset all my gas guzzlers lol
Re: Suggestions for ls1 using my stash? [Re: cool_breeze] #4528423
09/28/17 11:35 AM
09/28/17 11:35 AM
New England
Virtus_Probi Online mad
Virtus_Probi  Online Mad
New England
I guess I'd use the Edge 0W40 up and finish the fill with the 5W50.
If you're not planning to run it all when it get really cold, then the M1 15W50 would also be a good call to my way of thinking.
2014 Forester XT, 90000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: Suggestions for ls1 using my stash? [Re: cool_breeze] #4528668
09/28/17 05:00 PM
09/28/17 05:00 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
The valvoline 0w-40 MST is more like the M1 0w-40 (high calcium, no magnesium, plenty of Mo/B).
The 0w-40 Edge is a low calcium, high magnesium oil. If you've had good luck with the M1 0w-40, then try the Valv-MST next. Not familiar with the VR1 oils, but maybe mixing in 1-2 quarts could be ok...especially just before a track day.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Suggestions for ls1 using my stash? [Re: cool_breeze] #4528945
09/28/17 10:34 PM
09/28/17 10:34 PM
colorado springs
colorado springs
Thanks for the ideas. i went with;
3 qts vr1 syn 20-50
3 qts val syn hm 0w20
Re: Suggestions for ls1 using my stash? [Re: cool_breeze] #4528980
09/29/17 01:00 AM
09/29/17 01:00 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
3 qts vr1 syn 20-50
That's where I would have gone...
Then 2 changes of (trying to cut back the VII a little bit with a shear stable mono)
3 qts Castrol 5W50
2 qts Castrol 0W40
1 qt Valvoline straight 50
Then
3 qrts VR1 10W30
3 qrts M1 15W50
Then
4 qrts MST 5W40
2 qrts M1 15W50
leaves you (if I've done the math OK, one 0W20 and 1 15W50)...mix them now for top offs...
Seriously, I'd do a Sasha Gray blend, mix them all in a bucket, so that they are all the same...
Re: Suggestions for ls1 using my stash? [Re: cool_breeze] #4529724
09/29/17 06:24 PM
09/29/17 06:24 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
3 qts vr1 syn 20-50
Despite the same mfg name, I think those have very different add packs...one without sodium, and one with sodium.
1969 Ply GTX/RRs
Re: Suggestions for ls1 using my stash? [Re: cool_breeze] #4529784
09/29/17 07:06 PM
09/29/17 07:06 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
Mix the 20w50 vr1 with the 10w30 vr1 for one fill.
Mix 3 qts Val 0w20 syn with the VR1 50 for another fill.
Mix the 4 qts Val 5w40 MST with the last qt of Val 0w20 for another fill. Sweeten this fill with M1 15w50 to top up.
Mix the 4 qts of Edge 0w40 with 2 qts of Edge 5w50 for one fill.
Buy thinner oils to mix with the remaining 50-weight Edge and M1.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
