Originally Posted By: cronk
I know Op did not ask, but I am very happy with my Champion power Equipment 2000w inverter.
Conventional construction, cast iron sleeve, steel cam, overhead valves with pushrods.
Similar noise levels and performance fo its blue and red cousins, but less than half the price.
https://www.amazon.com/Champion-Power-Eq...pment+generator
Yup the champion is half the price.
It has half to 1/3rd the valve lash inspection interval - 100 for the champion vs 200 hours for the honda and 300 for the yamaha .
It appears to have been built with much softer material in the top end.
Finding parts for the red and blue gensets is as easy as going to a motorcycle shop of which there are usually several in every city. Not sure where to get parts for a champion.
UD
Yes, you come out on every small engine post that involves Champion and say this.
In reality recommended valve lash check intervals have little to nothing to do with engine life.
I have over 100 hours on my Champion and checked the valve lash, still in spec.
There was a poster over on RV.net that used a pair of Champion inverters to run his food truck, had well over 1000 hours with no issues. Still going strong last I heard.
Good luck finding many inverter gen parts in stock at any motorcycle shop. They might have a spark plug in stock.
I can order parts for My champion direct from the manufacturer. They have a large warehouse in California.
A carburetor for my Champion inverter is $35, how much is a Honda carburetor?
I come out of every small engine post where guys claim something - or other is just as good as a Honda yamaha subaru- for half the price - then go look up the specs.
Generac, champion, boliy, briggs, tecumseh - no names - I don't "have it out for" any brand, but I want to know the truth about the published maintenance schedule.
Ok - so you can order a part from the manufacturer and maybe they can send one right away, maybe they take a few days to process the order. Thats just great.
How does that help you if you need a genset on Saturday and find the carb is gummed up Friday night?
Never had to buy a carb for my Hondas, but I did need a switch once and an intake valve -(both in stock) can drive down the street TODAY and get one at several places.
100 hours is squat, that wont cover running an AC at a campsite for 7 day vacation. Its great your unit didnt need adjustment- but you still have to check it. Id rather not.
I have no issue with low priced gensets, but for people to claim they are getting the same quality, durability for half off when the spec say something else is when I chime in.
No emotion - simply data.
UD
