Guest's devices cannot connect to my WiFi
by boulderdentist
2 minutes 20 seconds ago
Battery stuck in flashlight.
by Chris142
Yesterday at 11:53 PM
Must read for everyone watching their diet
by JLTD
Yesterday at 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
Yesterday at 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
Yesterday at 10:47 PM
2020 mid-engine Corvette spy vid?!
by AZjeff
Yesterday at 10:45 PM
'05 base impala. NO turn signals.FAST blinking.
by Lee4212
Yesterday at 10:34 PM
Motul 15w-50, 5 Liter 4 Pack $19.42
by hatt
Yesterday at 10:10 PM
High Lead Redline 5W40 thoughts? Ty
by Pajero
Yesterday at 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
Yesterday at 09:32 PM
Another thick/thin article to discuss
by JLTD
Yesterday at 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
Yesterday at 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
Yesterday at 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
Yesterday at 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
Yesterday at 08:32 PM
VWs at Pick n Pull
by Eric Smith
Yesterday at 08:17 PM
Single Data Point: CK-4 destroys the flat tappet
by Gokhan
Yesterday at 08:12 PM
Breaking in new short block
by Bub
Yesterday at 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
Yesterday at 06:32 PM
Weber Q300 Grill Parts Help
by gathermewool
Yesterday at 05:24 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
36 registered (10WSmuckers, boulderdentist, ArrestMeRedZ, 4WD, clinebarger, Chris142, 4 invisible), 867 Guests and 28 Spiders online.
65299 Members
67 Forums
285814 Topics
Page 1 of 2 1 2 >
#4528146 - 09/28/17 06:29 AM LML Oil Pressure Variance???
redneck47441 Offline
Loc: Indiana
I did my 3rd oil change since 14k miles using Amsoil 15w40 Signature Series and EAO52 filter so far just using the oil life monitoring system. The oil pressure has been consistent 21psi hot idle and 40psi cruising at 60mph. I've had I bought the truck with 9k miles and first change the oil to Rotella T6 and Mobil 1 oil filter with same oil pressure results using my CTS2 monitor. The other night I changed my oil for the 3rd time using Amsoil and notice now oil pressure at 22psi hot idle and 45psi cruising on the highway also the truck feels to have an increase in power. So why would my oil pressure be higher now on the 4th oil change? I switched to Amsoil because I wasn't happy with the Rotella T6 I noticed a little oil coming from my exhaust and a puff of white smoke on startup but haven't experienced any of this with the Amsoil. Did I get a bad filter or possibly the the engine is broke in now with 33k on it. I also noticed my operating temp is a couple degrees lower too now.
#4528213 - 09/28/17 08:27 AM Re: LML Oil Pressure Variance??? [Re: redneck47441]
Loc: Indiana
The truck is a 2016 6.6 Duramax.
#4528214 - 09/28/17 08:27 AM Re: LML Oil Pressure Variance??? [Re: redneck47441]
motor_oil_madman Offline
Loc: Houston, Texas
It's colder outside now.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#4528217 - 09/28/17 08:28 AM Re: LML Oil Pressure Variance??? [Re: redneck47441]
Loc: Houston, Texas
Oil will be a bit thinner when it is 100 outside vs 80 degrees
#4528282 - 09/28/17 09:48 AM Re: LML Oil Pressure Variance??? [Re: redneck47441]
Loc: Indiana
I 100% agree but the temp just dropped a little this morning. We had the same temperature drop on the last oil change and it was ineffective. I'm just curious how do you know if your oil filter is in bypass or even bad?
#4528335 - 09/28/17 10:41 AM Re: LML Oil Pressure Variance??? [Re: redneck47441]
BrocLuno Offline
Loc: Kalifornia Kollective
Oil filter by-pass's internally when media won't flow the volume being pumped. Two ways to play this game. Filter with higher internal by-pass built-in, or bigger filter with more media area so it never sees enough restriction to cold oil to open the by-pass in the first place smile
#4528412 - 09/28/17 12:26 PM Re: LML Oil Pressure Variance??? [Re: redneck47441]
dnewton3 Offline
Loc: Indianapolis, IN
Totally coincidental. Oil pressures will always vary a bit. The oil will only be "thinner" when it's cooler outside because it will take a little bit longer to warm up. Once up to full op temp it will be controlled by the oil cooler which uses the engine coolant to control temps.
Also, oIl filters rarely ever go into BP, and when they do, it's only for a VERY short time (less than a few seconds) at cold start up. Once the oil pressure comes up in the full system, the dP across the filter is far less than the overall operating pressure, and never close to the filter BP crack-open. This has been proven (data logging experiments from Jim Allen) elsewhere on this site. Typically oil filters can flow WAY more than the engine will pump, as a safety design feature so as to not induce a media rupture.
What I don't understand is why folks worry about this stuff; it's minutia and is no indication of anything going right or wrong.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
#4528456 - 09/28/17 01:15 PM Re: LML Oil Pressure Variance??? [Re: redneck47441]
Loc: Indiana
Dnewton I wasn't necessarily worried as much I was curious? I was wondering if there was a difference in the oil enough to bring a 5 psi difference driving 60 or mabey even an issue or difference in the filters?
#4528733 - 09/28/17 07:18 PM Re: LML Oil Pressure Variance??? [Re: redneck47441]
dnewton3 Offline
No problem. It's really just too hard to compare/contrast such small nuances without understanding all the variables.
As a fellow Dmax owner, the wear rates are so low and consistence, I guess curiosity about oil pressure is about all we have to talk about!
And unless you're running extended OCIs, just ditch the syns; big waste of money.
The Dmax is the best wearing light-duty diesel engine in modern times. Simply impeccable wear traits. Using a syn does nothing to improve the already great wear rates.
Edited by dnewton3 (09/28/17 07:20 PM)
#4549791 - 10/21/17 12:29 AM Re: LML Oil Pressure Variance??? [Re: redneck47441]
Hasty66 Offline
Loc: San Antonio & Houston, Texas
I have a 2013 Duramax and have the EZ Lynk setup. Warmed up here in Texas my pressure will run around 22 psi at idle and 44 driving. First start up in the morning the pressure at idle can be as high as 62 psi. I'm currently at 53K miles and I use Mobil Delvac 15w-40 I buy at Wally World.
2013 Chevy Silverado 2500HD LTZ CC/SB 4x4 Duramax
2013 Jeep Grand Cherokee Overland 5.7L
2005 Ford F-150 Lariat CC/SB 4x4 5.4L
#4550170 - 10/21/17 12:40 PM Re: LML Oil Pressure Variance??? [Re: redneck47441]
Loc: Indiana
Hasty what I was getting at is my oil pressure was higher for the first few hundred miles after an oil change then the average dropped a bit with no difference in outside temperatures.
#4550669 - 10/22/17 01:18 AM Re: LML Oil Pressure Variance??? [Re: redneck47441]
Hasty66 Offline
I can't say the same with mine, it is pretty consistent from fill to drain with Mobil Delvac or Amsoil.
Edited by Hasty66 (10/22/17 01:22 AM)
#4551423 - 10/22/17 08:42 PM Re: LML Oil Pressure Variance??? [Re: redneck47441]
Loc: Indiana
Hasty your saying its the same with Mobil Delvac conventional 15w40 and Amsoil 15w40? If so are you also running the Amsoil filter? This last change I did 1500 miles ago with conventional 15w40 and donaldson filter and my pressure has been the same so far.
#4553452 - 10/24/17 07:20 PM Re: LML Oil Pressure Variance??? [Re: redneck47441]
benjy Offline
Loc: pa
oil viscosities are spec'd @ 40C + 100C + vary from there. base oils that are real synthetic-group IV + V which there are few will thicken less + slower under the 40C spec + they will thin less over the 100C spec. this could effect oil pressures both warm + cold!!
#4571850 - 11/12/17 01:59 PM Re: LML Oil Pressure Variance??? [Re: redneck47441]
Hasty66 Offline
Never used an Amsoil filter, I use M1-303 or B1441. I have run both filters with Mobil Delvac conventional 15w40 and Amsoil 15w40 OE/Heavy Duty oils. Temperature stays warm to HOT in this part of the country so not much experience beyond a very rare 32 and below start up when my pressure will jump up to 79-80 then drop down to normal once the oil is warmed up.
I have never noticed the slight difference after a change like you have noted.
Page 1 of 2 1 2 >
