Re-using building materials esp nails
by andyd
06/18/18 08:57 AM
Central A/C [censored] out
by TOMJ
06/18/18 08:43 AM
08 Scion tC under valve cover pics
by Highboy
06/18/18 08:39 AM
Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
80 registered (4WD, 87sammy, 2012AccentSE, andyd, AITG, Artem, 8 invisible), 1547 Guests and 33 Spiders online.
65262 Members
67 Forums
285515 Topics
#4528076 - 09/28/17 03:15 AM 0-20 & 10-30 oil mix
Shata Offline
Loc: Virginia, usa
Just curious what you guys thought about 8qts 0-20 pp and .75qts of 10-30 t5 mixed would look like as far as final number. I see people mixing around here and I did little top off with T5 since my oil change is 2k miles away finally.
My guess is somewhere around a 5-20? Since I have about 5k miles on this oil. I'm also getting blackstone UOA when time comes.
16 Silverado 2500 6.6 Dmax
15w-40 Chevron Delo SDE
Frantz bypass /w AC Delco pf2232
#4528103 - 09/28/17 05:12 AM Re: 0-20 & 10-30 oil mix [Re: Shata]
PimTac Offline
Loc: Soviet State of Washington
I doubt there will be any change.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
#4528119 - 09/28/17 05:39 AM Re: 0-20 & 10-30 oil mix [Re: PimTac]
Shata Offline
Loc: Virginia, usa
Ya with my oil capacity I figure it's more like 1w-22 but who knows, people mix around here all time with no noticeable change other then additive package showing different in UOA. We'll see what blackstone says to my viscosity.
#4528124 - 09/28/17 05:57 AM Re: 0-20 & 10-30 oil mix [Re: Shata]
KL31 Offline
Loc: South OZ
Not much difference at all.
95 MX-3 2.5L|Shell Helix Ultra 5W40|Wix 51356
04 Focus 1.8L|Wesfil Cooper WZ63|Valvoline MST 5W30
05 Kluger 3.3L|Wesfil Cooper WZ418|Magnatec 10W30 Semi Syn
#4528168 - 09/28/17 07:14 AM Re: 0-20 & 10-30 oil mix [Re: Shata]
JohnnyJohnson Offline
Loc: Wet side WA
The only reason I mix is I have something left over and all I use it for is top off oil.
2004 Toyota Corolla 121525
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74016
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4528183 - 09/28/17 07:44 AM Re: 0-20 & 10-30 oil mix [Re: Shata]
oil_film_movies Offline
Loc: MN
Shata, you're right, it would affect the very cold end of things to make it a 5w-20, since T5 is not a full synthetic.
Hot viscosity will go up by just 0.3 at kv100.
kv100 goes from 8.0 to 8.3.
http://www.widman.biz/English/Calculators/Mixtures.html
#4528226 - 09/28/17 08:43 AM Re: 0-20 & 10-30 oil mix [Re: Shata]
ARCOgraphite Offline
Loc: N.H, U.S.A.
THERE ARE NO SAE GRADE NUMBERS BETWEEN 0W/5W/10W OR 20/30/40 its EITHER IN THE MARGIN OR NOT.
Then there came frickin 16 grade ! That was a mistake.
Edited by ARCOgraphite (09/28/17 08:43 AM)
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
#4528234 - 09/28/17 08:48 AM Re: 0-20 & 10-30 oil mix [Re: ARCOgraphite]
bigj_16 Online   content
Loc: Douglas County, Colorado
What about 8 Grade?
#4528285 - 09/28/17 09:49 AM Re: 0-20 & 10-30 oil mix [Re: bigj_16]
weasley Offline
Loc: UK
Originally Posted By: bigj_16
What about 8 Grade?
What about 12?
Also, to OP, if you're topping off 8 quarts of oil that has been in an engine for a while, it's unlikely to still be a bona fide 0W-20, so adding a splash of 5W-30 to who-knows-what-it-is-now will give you... who knows what?!
2017 SEAT Leon 1.4 EcoTSI 150 FR Technology DSG
2018 Volvo XC60 D5
2011 KTM 990 SMT
#4528406 - 09/28/17 12:20 PM Re: 0-20 & 10-30 oil mix [Re: Shata]
Shata Offline
Loc: Virginia, usa
Ya it was top off and had nothing other left laying around it be fine if anything it brings it back into viscosity spec. Appreciate the Reply's and input.
#4528411 - 09/28/17 12:26 PM Re: 0-20 & 10-30 oil mix [Re: Shata]
Shata Offline
Loc: Virginia, usa
Normally what I see is 0w-20 pp is little low of viscosity spec range anyways during my UOA, still within spec but low so this should bring it right into middle-high side. We'll see I'll post it up when I pull the sample just for sake of speculation.
#4528415 - 09/28/17 12:28 PM Re: 0-20 & 10-30 oil mix [Re: ARCOgraphite]
Shata Offline
Loc: Virginia, usa
Well I know that I was just Using avg in sump and what I added to see theoretically how much it would effect the grade lol
#4528428 - 09/28/17 12:40 PM Re: 0-20 & 10-30 oil mix [Re: oil_film_movies]
Shata Offline
Loc: Virginia, usa
Thanks that's helpful site for mixing!
#4528433 - 09/28/17 12:51 PM Re: 0-20 & 10-30 oil mix [Re: Shata]
kschachn Online   content
Loc: Upper Midwest
Yes for viscosity only however, remember that any mixture is not necessarily going to meet any specification regardless of what you're starting with.
1994 BMW 530i, 227K
1996 Honda Accord, 262K
1999 Toyota Sienna, 394K
2000 Toyota ECHO, 267K
