Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
69 registered members (AandPDan, beanoil, Astro14, AndyB, beechcraftted, 8 invisible), 1,427 guests, and 43 spiders.
Topics295,097
Posts4,927,746
Members66,684
Most Online2,553
Oct 27th, 2018
OIL FOR 1969 CAT D333? #4528016
09/27/17 10:11 PM
09/27/17 10:11 PM
OKLAHOMA
Cat12f Offline OP
Cat12f  Offline OP
OKLAHOMA
I just bought a really clean 1969 cat motor grader with a D333 motor. Any suggestions for motor oil? I run mystic 15w-40 syn blend in my 2015 power stroke and also in my 2015 Case 580 Super N backhoe which both were bought new but I don't know much about the new oil goin in the older machines
Appreciate any comments
Re: OIL FOR 1969 CAT D333? [Re: Cat12f] #4528025
09/27/17 10:27 PM
09/27/17 10:27 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
I'll bet it calls for SAE 30 HD ... Not sure, but all the older CAT's I've worked on want that smile
Re: OIL FOR 1969 CAT D333? [Re: Cat12f] #4528046
09/27/17 11:18 PM
09/27/17 11:18 PM
Central Coast California
RedOakRanch Offline
RedOakRanch  Offline
My dad has an operators manual in his truck. Off the top of my head it is SAE30, and if it's really cold it gives advice on mixing kerosine to thin it out!
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: OIL FOR 1969 CAT D333? [Re: Cat12f] #4528152
09/28/17 05:38 AM
09/28/17 05:38 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Shell Rotella T5 10W30 will provide start up protection you need and is better than any 30W from 40+ years ago.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: OIL FOR 1969 CAT D333? [Re: Cat12f] #4528173
09/28/17 06:21 AM
09/28/17 06:21 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I ran 15w40 in my 62 pete with its 1962 cummins. Uoa showed it worked well
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: OIL FOR 1969 CAT D333? [Re: Cat12f] #4528265
09/28/17 08:17 AM
09/28/17 08:17 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
30 = 15W-40
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: OIL FOR 1969 CAT D333? [Re: CT8] #4528404
09/28/17 11:15 AM
09/28/17 11:15 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: CT8
30 = 15W-40
Pretty much.
Any cheap 15W-40 now is better oil than what was available 40-50 years ago.
Re: OIL FOR 1969 CAT D333? [Re: Cat12f] #4528635
09/28/17 04:33 PM
09/28/17 04:33 PM
OKLAHOMA
Cat12f Offline OP
Cat12f  Offline OP
OKLAHOMA
Since im not sure what oil was used in my grader previously Any reason I shouldn't convert to mystic 15-40 synthetic blend ? No worries of new oil consumption ?
I'm kinda old school and I was made to believe switching oil could cause oil consumption.
Re: OIL FOR 1969 CAT D333? [Re: Cat12f] #4532285
10/02/17 06:02 PM
10/02/17 06:02 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
What would the oil used before your ownership have to do with anything since 1960 the grader has had more different oils than a horse has had shoes.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: OIL FOR 1969 CAT D333? [Re: Cat12f] #4539182
10/10/17 01:34 PM
10/10/17 01:34 PM
Chicago
Fraser434 Offline
Fraser434  Offline
Chicago
Understand this engine was produced well before 15W40 was available. I would recommend using SAE 40 oil if you don't need to do cold starting.
Re: OIL FOR 1969 CAT D333? [Re: Linctex] #4540466
10/11/17 04:58 PM
10/11/17 04:58 PM
BrocLuno Offline
BrocLuno  Offline
30 = 15W-40
Pretty much.
There are plenty of modern SAE 30 and SAE 40 grades out there. No VII's to shear down and they lube very well. There are some engines that will tear up any multi grade, so they are recommended for mono's only.
Just becasue it's a mono, does not mean it is "40 years old" ...
Re: OIL FOR 1969 CAT D333? [Re: Cat12f] #4547124
10/18/17 10:56 AM
10/18/17 10:56 AM
Houston, TX
DWC28 Offline
DWC28  Offline
Houston, TX
Your current 15W-40 will work good or better than the SAE 30. The oil quality has gotten better and there was a reason that Cat switched from 30 to 15W-40, better cold weather, better hot weather.
Re: OIL FOR 1969 CAT D333? [Re: Cat12f] #4691959
03/11/18 08:52 PM
03/11/18 08:52 PM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
I fixed a lot of D333s between 1984 and 2003. All of the older cats used 30 wt. I care for four 3516s now and they take 15-40 Rotella. I wouldn't be afraid to run 15-40 in the 333 but you may want to check the condition of a rod and a main bearing before changing oils. I fixed mostly generator sets so it was easy to open a side cover for a peek inside. May be less easy in an earth mover.
Re: OIL FOR 1969 CAT D333? [Re: Cat12f] #4927398
11/18/18 04:53 AM
11/18/18 04:53 AM
wa
Exhaustgases Offline
wa
Just good old straight 30.
Re: OIL FOR 1969 CAT D333? [Re: Cat12f] #4941360
12/02/18 09:25 AM
12/02/18 09:25 AM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
You are in Oklahoma, contrary to popular belief the weather there can get very cold. Is one of your planned uses snow clearing? If so would not use a 30 wt let alone a 40W unless I had block heaters. Changeing your hydraulic oil to a modern oil is not a bad idea.
If summer use building terraces etc, then a straight 30 or 40 is an excellent choice.
Rod
