AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
Practice CLS material
by RDY4WAR. 12/17/18 01:52 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
29 registered members (ChemLabNL, CB900F2, Bjornviken, bluesubie, Char Baby, Brandon9797, 3 invisible), 887 guests, and 45 spiders.
Topics295,206
Posts4,929,892
Members66,711
Most Online2,553
Oct 27th, 2018
SkyActiv drain & fill #4527770
09/27/17 04:40 PM
09/27/17 04:40 PM
America's Dairyland
LotI Offline OP
LotI  Offline OP
America's Dairyland
Changed the ATF in my Mazda6 today. Almost as easy as changing the engine oil. Just had a bigger access panel to remove.
I found a Service manual for the 2014 and they really havenít changed anything since. FZ fluid is easy to find at the stealer and mine charged $14.89/qt.
Mazda was really thoughtful and used the exact same fastener and washer as the engine oil drain. That meant my stash of 14mm washers was all I needed. I bought a 50-pack from Amazon for $8 a couple years ago since I used to have Hondaís and still have a Honda motorcycle that uses the same washer. Instructions
I checked the dipstick when the engine was off so I had a baseline and roughly measured the amount removed at 3+ quarts. Took 3.8qts to put the level right when the fluid temp was 50C on my ScanGuage. if you donít have Popeye forearms, you can get to it from the engine bay. Adjustment
MolaKuleís advice about changing FF before 10k was the reason for the change. Car has 8k on it.
A side funny story...I called another dealer to shop prices and was quoted $26/qt! They parts dork told me that if my fluid is low I should bring it in for warranty. I told him that I wanted to change the fluid and he basically yelled at me not to split the cases...even Mazda pre-fills the new trannyís sent to dealers! I mentioned that Mazda was kind enough to install both a drain plug and dipstick so Itís easy. Donít be that guy! Thereís such thing as the internet now and thereís a good chance your customer may know more than you.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: SkyActiv drain & fill [Re: LotI] #4527783
09/27/17 04:59 PM
09/27/17 04:59 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
You did a D&F on the Skyactiv Drive at 8K? I am going to hold my tongue regarding what a waste that was.
Re: SkyActiv drain & fill [Re: DBMaster] #4527787
09/27/17 05:03 PM
09/27/17 05:03 PM
America's Dairyland
LotI Offline OP
LotI  Offline OP
America's Dairyland
By saying that youíre not holding your tongue. This is a no judgment zone, D-BagMaster
Ever read Molaís posts?
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
Re: SkyActiv drain & fill [Re: LotI] #4527792
09/27/17 05:06 PM
09/27/17 05:06 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
Yes, you are as correct as you are classy.
Re: SkyActiv drain & fill [Re: LotI] #4527794
09/27/17 05:10 PM
09/27/17 05:10 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
DB stands for D*&k Brain, btw.
Re: SkyActiv drain & fill [Re: DBMaster] #4527795
09/27/17 05:13 PM
09/27/17 05:13 PM
America's Dairyland
LotI Offline OP
LotI  Offline OP
America's Dairyland
Lol, I made an assumption! Stay classy, my friend. I know the change wasnít ďnecessaryĒ, but Iíve spent more than that on one steak...not the whole dinner mind you.
I donít need to explain how long the steak lasted...I want the car to be around.
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
Re: SkyActiv drain & fill [Re: LotI] #4527799
09/27/17 05:17 PM
09/27/17 05:17 PM
New York
pbm Offline
pbm  Offline
New York
I read Critic's and DBMaster's threads on changing the ATF on a Skyactive Mazda and both concurred that they would have went longer after seeing how clean the drained ATF was....I think DB was being kind by informing you of this and you were a bit harsh in response but that's just my opinion....oh well.....
'Journalism is Dead'
Re: SkyActiv drain & fill [Re: LotI] #4527802
09/27/17 05:19 PM
09/27/17 05:19 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
I have a 2012 Mazda3 with SA Drive. I felt guilty about not doing a D&F (and, believe me, I have been guilty of over-maintaining for most of my life) so I did it at 60K. The fluid that came out was extremely clean and smelled the same as the new stuff put back in. I ordered it online from a Mazda dealer for right around $15/quart including shipping. I have to let go of the old paradigm and accept the fact that "lifetime" fluid may indeed exist. Transmission and fluid technology changed a lot since my last car - a 1989 Honda Accord.
Re: SkyActiv drain & fill [Re: LotI] #4527818
09/27/17 05:43 PM
09/27/17 05:43 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
I'm not offended. If I post something like I did I'm challenging someone else's opinion or belief. It's OK if the initial response is irritability. If you never challenge anyone opinions and beliefs remain stagnant. And, it's perfectly OK if they don't agree with me. We're all way too sensitive these days - as individuals and as a society.
Re: SkyActiv drain & fill [Re: LotI] #4527838
09/27/17 06:03 PM
09/27/17 06:03 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
$14.89 is list for a quart of FZ.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: SkyActiv drain & fill [Re: bdcardinal] #4527850
09/27/17 06:10 PM
09/27/17 06:10 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Is the Mazda spec and Mercon LV the same or no?
2007 Ford Fusion 235,000 miles
M1 0-20 EP
2017 Ford Fusion 61K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: SkyActiv drain & fill [Re: tig1] #4527855
09/27/17 06:19 PM
09/27/17 06:19 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
FZ has its own proprietary spec. It claims to be "ultra low viscosity." when I did the D&F I can confirm that it is about as viscous as 0W-20 oil.
Re: SkyActiv drain & fill [Re: LotI] #4527866
09/27/17 06:28 PM
09/27/17 06:28 PM
USA
slacktide_bitog Offline
USA
Maxlife is ok to use in a transmission using FZ and it costs much less smile
Re: SkyActiv drain & fill [Re: LotI] #4527895
09/27/17 06:58 PM
09/27/17 06:58 PM
wi
dave123 Offline
dave123  Offline
wi
2012 3 with SA 100k have not touched trany yet shifts like new who knows maybe get the itch at 125k or not. Engine and filter are done with 5k intervals with M1 engine is pristine love the vehicle and sky technology.
Re: SkyActiv drain & fill [Re: LotI] #4527918
09/27/17 07:27 PM
09/27/17 07:27 PM
Florida
Artem Offline
Artem  Offline
Florida
I dumbed the factory transmission fill on my 2014 Mazda 3 with manual transmission at about 10k as well. Fluid came out sparkling with metallic bits. Gear Changes got ALOT smoother with new fluid. It was definitely worth the flush to me.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
