Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
33 registered members (CR94, carlprop, d00df00d, c502cid, bbhero, Brad_C, 2 invisible), 807 guests, and 59 spiders.
Topics286,170
Posts4,903,526
Members67,572
Most Online2,967
Mar 10th, 2019
2005 Nissan Sentra 2.5l Auto trans drain and fill? #4527743
09/27/17 05:09 PM
09/27/17 05:09 PM
Balto, MD
NattyBoh Offline OP
NattyBoh  Offline OP
Balto, MD
I cannot find a solid answer on the forum or online as to what the capacity is on the 2005 2.5l auto ( se-r ) sentra. Its just my wifes OLD car, that has 130k on it and I use it for work. But I figured why not drain the trans... It calls for Matic-D but Im going Maxlife Syn most likely. Does anyone know where to find the capacity of the trans? I cannot even find out WHICH trans is installed...
Thanks.
Re: 2005 Nissan Sentra 2.5l Auto trans drain and fill? [Re: NattyBoh] #4527779
09/27/17 05:56 PM
09/27/17 05:56 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
best thing to do is to leave the car cold and use a large measuring cup to accurately measure the amount that drains out (dont spill any).
Then put the same amount back in but make sure the oil that goes in was at the same temperture of the oil that came out. Oil expands and hot tranny oil replaced with cold oil could cause you to overfill since the hot oil is expanded and the cold oil is not.
Re: 2005 Nissan Sentra 2.5l Auto trans drain and fill? [Re: NattyBoh] #4527780
09/27/17 05:56 PM
09/27/17 05:56 PM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
Amsoil shows the initial fill at 7qts, nothing more.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: 2005 Nissan Sentra 2.5l Auto trans drain and fill? [Re: NattyBoh] #4527857
09/27/17 07:19 PM
09/27/17 07:19 PM
Balto, MD
NattyBoh Offline OP
NattyBoh  Offline OP
Balto, MD
Initial fill being torque converter etc. Im just doing to drain and fill... I cant imagine its more than 5qts total. A big jug of max life should work fine.
Re: 2005 Nissan Sentra 2.5l Auto trans drain and fill? [Re: NattyBoh] #4527868
09/27/17 07:29 PM
09/27/17 07:29 PM
USA
slacktide_bitog Offline
USA
The capacity is whatever you drain out, just put back in that much ATF smile
Re: 2005 Nissan Sentra 2.5l Auto trans drain and fill? [Re: NattyBoh] #4530130
09/30/17 10:18 AM
09/30/17 10:18 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I know the 4spd auto in our 2001 Sentra had an ATF dipstick because that's where I refilled it from. Nice easy accessible drain plug on the AT pan as well. IIRC, 3-4qts came out when you pulled the drain plug. I used Valvoline Maxlife back then IIRC.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
