Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
30 registered members (Black_Thunder, 53' Stude, Black, Bailes1992, ctechbob, BretK, 1 invisible), 845 guests, and 40 spiders.
Topics295,008
Posts4,925,907
Members66,664
Most Online2,553
Oct 27th, 2018
A/C Gauge set Wal-Mart #4527632
09/27/17 12:55 PM
09/27/17 12:55 PM
stl
MarkM66 Offline OP
MarkM66  Offline OP
stl
https://www.walmart.com/ip/Diagnostic-Ma...Hoses/105112541
Look okay? Seems inexpensive..
Free shipping
Re: A/C Gauge set Wal-Mart [Re: MarkM66] #4527633
09/27/17 12:58 PM
09/27/17 12:58 PM
stl
MarkM66 Offline OP
MarkM66  Offline OP
stl
Re: A/C Gauge set Wal-Mart [Re: MarkM66] #4527640
09/27/17 01:08 PM
09/27/17 01:08 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Kinda useless today. Systems are so small an ac machine is the only way to go.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: A/C Gauge set Wal-Mart [Re: MarkM66] #4527650
09/27/17 01:26 PM
09/27/17 01:26 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Neither are actually sold by WalMart.. those are sold by third parties who sell on walmart.com.
The gauges are probably OK. I would have doubts that the vacuum could hold 500mb.. but who knows.
Re: A/C Gauge set Wal-Mart [Re: MarkM66] #4527684
09/27/17 02:17 PM
09/27/17 02:17 PM
US
Need4racin Offline
Need4racin  Offline
US
3rd party. Both are cheaper from harbor freight or ebay. The gauge set has junk ends. Get one with the screw on couplers. Suggest a 2 stage vac pump.
60+" screw on couplers. what i suggest you look for. ebay has best prices.
http://www.ebay.com/itm/Aluminum-AC-Mani...t-/131842705206
Re: A/C Gauge set Wal-Mart [Re: Chris142] #4527768
09/27/17 04:38 PM
09/27/17 04:38 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
If you want to service an A/C properly you will need a way to remove and store the refrigerant, evacuate the system, check for leaks and then fill by weight.
Now if you have a slow leak in an older car, you can dump a can of R134a every once and awhile. If you stay away from stop-leak you should be OK.
2015 Ford F250 w/Powerstroke
Re: A/C Gauge set Wal-Mart [Re: Need4racin] #4528202
09/28/17 07:12 AM
09/28/17 07:12 AM
stl
MarkM66 Offline OP
MarkM66  Offline OP
stl
HF are $60 https://www.harborfreight.com/ac-r134a-manifold-gauge-set-62707.html
Same style ends. Not sure what you mean by screw on couplers. Hoses screw to manifold and to quick disconnect fitting. Quick disconnect goes to ac fitting.
Re: A/C Gauge set Wal-Mart [Re: MarkM66] #4528216
09/28/17 07:28 AM
09/28/17 07:28 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Free shipping
I have one for R-12 only, it is very old. I grabbed one after having Trav give it the two thumbs up. Just one use will cover the cost and them some.
OP- thanks for posting.
God Bless Our Troops
Re: A/C Gauge set Wal-Mart [Re: MarkM66] #4528253
09/28/17 08:05 AM
09/28/17 08:05 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I have one of those pumps. Got it off Amazon. Works great and pumps to 30"Hg easily.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
