PYB 10w30 question
by 1978elcamino. 04/18/19 03:16 PM
Misbehaving Mechanic Caught On Dash Cam
by BlueOvalFitter. 04/18/19 02:38 PM
What oil for my newly acquired Samurai
by ad244. 04/18/19 02:37 PM
Check your Oil (SMA YouTube Video)
by javacontour. 04/18/19 02:37 PM
Wearing Hiking Shoes Full-Time
by oilpsi2high. 04/18/19 01:56 PM
Apply brakes, steering wheel shakes
by grampi. 04/18/19 01:35 PM
F150 Exhaust whistle
by Redright9. 04/18/19 01:20 PM
Boy, what a marketing win!
by SubieRubyRoo. 04/18/19 12:06 PM
auto shipping question for a friend
by earlyre. 04/18/19 11:02 AM
O Reilly motor oil
by porvdub. 04/18/19 10:59 AM
GM & JEEP O/S OIL FILTERS
by adrenalin89. 04/18/19 10:56 AM
Accord AC Issue
by maverickfhs. 04/18/19 10:54 AM
Transatlantic Communication Lines and the story
by StevieC. 04/18/19 10:41 AM
Crazy Neighbor....part deux
by Schmoe. 04/18/19 10:15 AM
Troubles with Mint Mobile formerly Miny Sim
by daves66nova. 04/18/19 09:40 AM
Marine Engine Oil
by Brian553. 04/18/19 09:35 AM
Steering gear rattle video
by LeakySeals. 04/18/19 08:52 AM
Kenzitoz, White12Boss302, terryj, Hadryk, djcavein
67844 Registered Users
121 registered members (1978elcamino, 55hambone, 2010Civic, addyguy, ad244, 9 invisible), 2,163 guests, and 30 spiders.
Topics287,700
Posts4,932,598
Members67,844
Most Online2,967
Mar 10th, 2019
Copper grease on exhaust #4527530
09/27/17 11:57 AM
09/27/17 11:57 AM
Europe
EWPE Offline OP
EWPE  Offline OP
Europe
My 21 years old car still has original exhaust with no holes. Mufflers looks like new, but pipes has a bit rusty surface. I rarely use my car as a short tripper, so it's rather unlikely for exhaust to rust from the inside significantly. Is it a good idea to cover those rusty pipes with copper grease? Should I be afraid of galvanic corrosion? Is there any better way to protect it?
Re: Copper grease on exhaust [Re: EWPE] #4527559
09/27/17 12:41 PM
09/27/17 12:41 PM
California
Kool1 Offline
Kool1  Offline
California
It looks like surface rust on your exhaust which you may want to wire brush off. To make the pipes look better, you can try high heat paint like VHT. I would not coat my pipes with any grease.
Re: Copper grease on exhaust [Re: EWPE] #4527582
09/27/17 01:01 PM
09/27/17 01:01 PM
Warner Robins, GA
nwjones18 Offline
nwjones18  Offline
Warner Robins, GA
I think I would just keep driving it and not worry about it.. Any wire brushing you do it just going to rust again.
2016 Ram 1500 5.7 Hemi 30k
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: Copper grease on exhaust [Re: nwjones18] #4527598
09/27/17 01:17 PM
09/27/17 01:17 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yes, the only solution is to remove the rust and apply high heat paint.
Re: Copper grease on exhaust [Re: Linctex] #4527608
09/27/17 01:29 PM
09/27/17 01:29 PM
Europe
EWPE Offline OP
EWPE  Offline OP
Europe
OK, but it's not so simple to fully remove rust (even on an removed exhaust) and high heat paints wouldn't last very long on rusty surface. As exhaust is fitted in factory, it has no joint somewhere between mufflers and I would have to remove rear suspension first to be able to remove it then - and that's a lot of work. Applying copper grease seemed to be the simplest, yet effective solution.
Re: Copper grease on exhaust [Re: EWPE] #4527617
09/27/17 01:40 PM
09/27/17 01:40 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Would a rust converter work better for you?
The Rustoleum product turns the rust black and takes paint well.
How deeply it will go into rust is something I do not know.
Re: Copper grease on exhaust [Re: EWPE] #4527619
09/27/17 01:41 PM
09/27/17 01:41 PM
Nevada
heynow Offline
heynow  Offline
Nevada
Copper grease will burn off the first time you get the car up to operating temperature.
I don't even want to imagine the huge, foul smelling cloud of smoke that it will produce.
1991 Acura NSX
2010 X5 35d twin turbo diesel
2005 BMW r1200GS
Re: Copper grease on exhaust [Re: EWPE] #4527682
09/27/17 03:16 PM
09/27/17 03:16 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Copper grease on the exhaust? Just leave it, seriously. When you get a hole in it, replace it.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Copper grease on exhaust [Re: EWPE] #4528089
09/28/17 04:23 AM
09/28/17 04:23 AM
Margate England
Claud Offline
Claud  Offline
Margate England
21 years from an exhaust?. Is nothing made to last nowadays?. smile
My wife's Peugeot only managed eleven years on it's original exhaust.
It used to be an annual task, and a battery was a biennial job back in the day.
Leave well alone, don't fix what ain't broke.
Claud.
Re: Copper grease on exhaust [Re: EWPE] #4577772
11/18/17 07:52 AM
11/18/17 07:52 AM
New York
JoeJ Offline
JoeJ  Offline
New York
I've used rust converter to convert rust to a more stable element than painted with high temp header paint. Works for me.
Joe
