Hail damage means newer vehicle time!
by ZZman
24 minutes 31 seconds ago
Trouble with Grease Gun
by tc1446
Today at 02:30 PM
Toyota brand conventional (TGMO)
by Jaha24k
Today at 01:45 PM
Any synthetic oil rebates currently or soon?
by 07Piloteer
Today at 01:32 PM
2018 Hyundai elantra motor oil
by kapama
Today at 01:00 PM
SN Plus on shelves
by 03s
Today at 12:23 PM
Group 90 Battery - 45 vs 60aH rating
by The Critic
Today at 12:19 PM
Tire on Church 15 Passenger Van
by Gebo
Today at 11:58 AM
Battery Disconnect Switch?
by Pike51
Today at 11:35 AM
03 Maxima Cam sensor questions
by LeakySeals
Today at 11:09 AM
Wood Fairing?? Yes, and it's beautiful!
by webfors
Today at 11:08 AM
2006 Prius
by Kira
Today at 11:06 AM
Amsoil XL 5w30, 10K OCI, 2006 Expeditition
by meborder
Today at 10:18 AM
Mouse Visiting Car
by Ifixyawata
Today at 10:07 AM
Hit a shopping cart at 30mph
by LeakySeals
Today at 10:00 AM
Let's Talk Bed Pillows
by LoneRanger
Today at 09:21 AM
Changed Speedo Gear on 700r4 Tailshaft
by Pike51
Today at 09:20 AM
Which do you prefer: ZL-1 Camaro or GS Corvette ?
by Mr Nice
Today at 08:41 AM
CVT Discussion
by Sierra048
Today at 08:28 AM
Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
Today at 07:34 AM
nmac9, Theraven, battleman13, Shassis, Santo
65277 Registered Users
83 registered (28oz, A310, ag_ghost, Aero540T, 1998CamryCE, 853okg, 12 invisible), 1686 Guests and 25 Spiders online.
65277 Members
67 Forums
285656 Topics
Page 1 of 2 1 2 >
#4527404 - 09/27/17 09:22 AM Synthetic Blend help with consumption?
Mossyoakglock Offline
Loc: Nashville, TN, United States
I have a 2008 Silverado w/ 5.3 and slight oil consumption issues (like most of them). Would running Pennzoil 5w-30 Syn Blend help with consumption at all? If I ready the PDS right it looks like it is a little thicker at temp than the full synthetic. Would there be any benefit to running a blend over a full synthetic? Truck has 125,000 on it.
The synthetic cSt @ 40 is 10.3 and the blend is 11.
2008 Chevrolet Silverado
5.3L / 4L60E
#4527413 - 09/27/17 09:29 AM Re: Synthetic Blend help with consumption? [Re: Mossyoakglock]
pbm Offline
Loc: New York
It could go either way...it could consume more, less or the same using syn-blend. I'd try a High Mileage oil, rather than a syn-blend, to see if the seal conditioners help....
'Journalism is Dead'
#4527417 - 09/27/17 09:34 AM Re: Synthetic Blend help with consumption? [Re: Mossyoakglock]
Chris142 Offline
Loc: Deplorable in apple valley, ca
How many miles per qt is it using?
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4527443 - 09/27/17 10:14 AM Re: Synthetic Blend help with consumption? [Re: Mossyoakglock]
ZZman Online   content
Loc: Michigan
What is slight consumption? Many manufacturers consider some consumption normal.
2003 Mercury Grand Marquis. Rotella T6 Multi-Vehicle oil
2008 Sebring Hardtop convertible. Rotella T6 Multi-Vehicle oil
2006 Kawasaki Vulcan 900 LT. Amsoil Metric 10w-40
#4527446 - 09/27/17 10:18 AM Re: Synthetic Blend help with consumption? [Re: Mossyoakglock]
Loc: Michigan
Bad PCV valve?
Worn valve guides?
Sticking rings?
Hard to say if it will help or not.
#4527454 - 09/27/17 10:30 AM Re: Synthetic Blend help with consumption? [Re: Mossyoakglock]
dogememe Offline
Loc: SF BAY AREA, CA
Have you tried using an AFM Range Disable?? https://rangetechnology.com/afm-disabler/
From what I'm heard the AFM/DOD system is responsible for most problems with these engines including oil consumption.
2007 Ford Crown Vic P71 4.6 ~124K Miles, Valvoline SynPower 5W-30, Royal Purple Filter *Daily Driver*
2010 Ford Escape 2.5 ~70K Miles, Valvoline SynPower 5W-30, Wix Filter *Turo Rental Car*
#4527473 - 09/27/17 10:59 AM Re: Synthetic Blend help with consumption? [Re: Mossyoakglock]
dwendt44 Offline
Loc: Central Wisconsin
You could try a 10W-30 oil and see if that helps.
Tennessee doesn't get that cold in winter, not likely to
see single digits on the thermometer.
My 2
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
#4527526 - 09/27/17 11:54 AM Re: Synthetic Blend help with consumption? [Re: Mossyoakglock]
Alex_V Offline
Loc: Campbellsville, KY
I've put Valvoline Maxlife 10w30 in several LS-powered trucks and tens of thousands of miles later (not on the same OCI laugh ) they're still doing just fine. I wouldn't hesitate at all to put in something along those lines and see how it does.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 112K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 167K
'67 Suburban, 350, 331K
#4527590 - 09/27/17 01:08 PM Re: Synthetic Blend help with consumption? [Re: Mossyoakglock]
LeakySeals Offline
Loc: Hudson, NH
Tell us about prior maintenance. Oil changed on time? What kind of oil was used? Knowing that, perhaps a synthetic clean up may help with stuck rings. If the engine is clean and all oil changes were done on time I would try replacing the valve cover with built in PCV. Go read about it in the Amazon reviews some claim it completely stopped.
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
#4527672 - 09/27/17 03:02 PM Re: Synthetic Blend help with consumption? [Re: Mossyoakglock]
To answer all questions at once:
How many miles per qt is it using? - not exactly sure. I check it regularly so not sure how much it's using per 1,000 miles. I'd say around a quart (maybe less).
Have you tried using an AFM Range Disable?? https://rangetechnology.com/afm-disabler/ - I was using the Range but the truck would randomly go back to V4 mode so I ditch it. I went with a tuner and disabled it that way. I didn't do it until around 60K miles so the damage was probably already done at that point.
Tell us about prior maintenance. Oil changed on time? What kind of oil was used? Knowing that, perhaps a synthetic clean up may help with stuck rings. If the engine is clean and all oil changes were done on time I would try replacing the valve cover with built in PCV. Go read about it in the Amazon reviews some claim it completely stopped - Oil always changed based on OLM (maybe a little before or a little after) but usually around the 6,000 mile mark. Always used Synthetic. Used M1 for the first 2-3 years then went with PP. Tried Valvoline but truck didn't like it. Now using M1 Extended. I also replaced the valve cover with the updated cover based on the GM TSB.
I thought about going with a HM oil (most likely Pennzoil) but not sure if I want to because I've never read a definite answer that you can or cannot go back to non-HM after using it.
Also, after thinking about it would it really make a difference between an 10w and 5w since they are both the same at operating temps? Also, we can get into the low 10's and even in he singles here during the winter (which we have the last few years). We just don't get the snow.
Edited by Mossyoakglock (09/27/17 03:13 PM)
5.3L / 4L60E
#4527702 - 09/27/17 04:02 PM Re: Synthetic Blend help with consumption? [Re: Mossyoakglock]
FZ1 Offline
Loc: Texas
Worth a try.
#4527706 - 09/27/17 04:08 PM Re: Synthetic Blend help with consumption? [Re: Mossyoakglock]
SatinSilver Offline
Loc: OH
Seems as though you like Pennzoil so why not use some Pennzoil conventional oil in it? It's full of additives for cleaning and maybe the best thing for it. I'd just skip over the syn-blend and go right to the conventional. And this is coming from someone that runs full syn in one car and a syn-blend in the other.
#4527714 - 09/27/17 04:17 PM Re: Synthetic Blend help with consumption? [Re: SatinSilver]
FZ1 Offline
Loc: Texas
Good idea.
#4528043 - 09/28/17 12:13 AM Re: Synthetic Blend help with consumption? [Re: Mossyoakglock]
Because I don't know the ins and outs of oil specifications, properties, etc and I'm just curious. What would be the reason to try conventional over synthetic? Better cleaning and seal conditioners over synthetic?
5.3L / 4L60E
#4528208 - 09/28/17 08:19 AM Re: Synthetic Blend help with consumption? [Re: Mossyoakglock]
LeakySeals Offline
Loc: Hudson, NH
I have the 6.0L. Using M1 5w30 I "lose" 1/4-1/3 qt during a 6500 OLM OCI. I say lose because it doesn't seem like I'm consuming it necessarily but the area around the oil pan and filter seems to be wet. I recently tried Edge black bottle and saw no drop on the stick, none. And it remained dry underneath. So it would seem like M1 finds way out of engine beyond standard consumption. so I guess the first test would be changing synthetics. See if that makes a difference. if changing synthetics makes no difference after a couple of oil changes then go the high mileage route. High mileage oil can help with tired rubber seals throughout the engine
I stay with M1 and the slight consumption because of butt Dino smoothness during the OCI. Starts getting a little sluggish and rough with other brands like Pennzoil and Castrol. Again that's just butt Dino personal preference with this particular engine.
Page 1 of 2 1 2 >
