DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
Rollo, Drifted, Jcar516, gregjr7, daveed
67613 Registered Users
75 registered members (2010Civic, 69Torino, 4WD, AdditiveOCD, arowbat, 6 invisible), 1,529 guests, and 56 spiders.
Topics286,363
Posts4,907,097
Members67,613
Most Online2,967
Mar 10th, 2019
How to test PCV valve? #4527159
09/26/17 09:58 PM
09/26/17 09:58 PM
Venezuela, South America
Emanuel Offline OP
Emanuel  Offline OP
My car is burning 0.8 qt of oil every 1k miles, I have checked the PCV valve, it isnīt blocked or dirty, I can hear a sound when I shake it which tells me that is in good condition. I can suck from the Intake Manifold very easily, Shouldnīt it require some vacuum pressure to open? And I can also apply pressure with my mouth from the intake manifold side and the air can pass the PCV valve but slowly.
The car is idling at 800 rpm which convinces me that the PCV valve isnīt stuck open.
What do you think?
Re: How to test PCV valve? [Re: Emanuel] #4527176
09/26/17 10:31 PM
09/26/17 10:31 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
It should be open when idling, it's a controlled air leak. Stuck shut is a problem, or guts gone.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: How to test PCV valve? [Re: Silk] #4527184
09/26/17 10:43 PM
09/26/17 10:43 PM
Emanuel Offline OP
Emanuel  Offline OP
I think that itīs fine
Re: How to test PCV valve? [Re: Emanuel] #4527186
09/26/17 10:45 PM
09/26/17 10:45 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
If its cheap to replace where you are just replace it. They are about 10$ here (less in USA). Worst case you are out some cash. Mine seemed normal but once replaced the slight oil usage stopped. Seems like a good amount of consumption though.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: How to test PCV valve? [Re: Emanuel] #4527247
09/27/17 03:54 AM
09/27/17 03:54 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Instead of sucking on the hose, do you have good vacuum from that hose when the engine is idling? You should.
The "thinking" man's friend.
Re: How to test PCV valve? [Re: Emanuel] #4527261
09/27/17 04:56 AM
09/27/17 04:56 AM
NY
demarpaint Offline
demarpaint  Offline
NY
If you do replace it, I would go with an OE part. I learned the hard way that the only way to go with a PCV valve is OE.
God Bless Our Troops
Re: How to test PCV valve? [Re: Emanuel] #4527410
09/27/17 09:28 AM
09/27/17 09:28 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
They're just a check valve. Flow should only go one way, towards the intake manifold. During periods of slight positive crankcase pressure (wide open throttle, etc), the valve should close.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: How to test PCV valve? [Re: demarpaint] #4527433
09/27/17 10:03 AM
09/27/17 10:03 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
+1 OE is a good way to go. I would replace it anyways. It traditionally isn't an expensive part.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: How to test PCV valve? [Re: Emanuel] #4527444
09/27/17 10:14 AM
09/27/17 10:14 AM
New England
Virtus_Probi Offline
New England
I just bought a Subaru OEM PCV for my FXT and it was $8 before shipping.
The bad thing is that I have to pop the intercooler off to get to it...this is the reason a local dealer totally blew off replacing it at my 60kmile service after I had been assured on the phone that it would be done. They pointed to an "if applicable" line in their standard paperwork for the service, I was stupid enough to read this as meaning if the vehicle had one and not if the techs felt like doing it. Gotta get this stuff in writing when dealing with shady dealerships...
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: How to test PCV valve? [Re: Emanuel] #4527474
09/27/17 11:05 AM
09/27/17 11:05 AM
D/FW Metroplex
The_Nuke Offline
The_Nuke  Offline
D/FW Metroplex
An oil with a lower NOACK value should slow that oil consumption rate, or switching to a 10W-30 (assuminb you're running 5W-30 now) will prob help.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.62 (215mm)
Re: How to test PCV valve? [Re: demarpaint] #4527496
09/27/17 11:24 AM
09/27/17 11:24 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
I agree. I hate using plastic parts, but I replaced a metal aftermarket PCV valve with a plastic Motorcraft PCV valve, and my car idles better. The difference is that the aftermarket PCV valves seem to let some air both ways, so it's like having a vacuum leak. The OE one only let air in one direction. Still cheap enough too (Motorcraft part bought off eBay, or Amazon).
Re: How to test PCV valve? [Re: Emanuel] #4527882
09/27/17 07:44 PM
09/27/17 07:44 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
What do you think?
The spring can fatigue and cause it to pass too much flow. This can contribute to consumption. Replace it and monitor oil level
My car was up to about a qt in 2k mi. I changed the PCV and now I'm
Back to about a qt every 6k mi
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: How to test PCV valve? [Re: The_Nuke] #4527983
09/27/17 10:08 PM
09/27/17 10:08 PM
Emanuel Offline OP
Emanuel  Offline OP
Iīm currently using a 15w40 HDEO
Re: How to test PCV valve? [Re: Emanuel] #4528079
09/28/17 03:26 AM
09/28/17 03:26 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
You're supposed to be able to blow through one way, but not the other way.
