Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
35 registered members (claluja, CR94, carlprop, c502cid, bbhero, Brad_C, 3 invisible), 798 guests, and 58 spiders.
Topics286,170
Posts4,903,526
Members67,572
Most Online2,967
Mar 10th, 2019
Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA #4527036
09/26/17 07:27 PM
09/26/17 07:27 PM
Michigan
cutlassvillager Offline OP
Michigan
The first UOA is listed here. This has had a steady diet of M1 0w-40 since I bought it a few years ago with 45k miles. Filters have usually been the M1-108 except for a few PureOnes along the way - first UOA was a P1.
The last few runs have been the new "FS" formula. I'm glad it seems to perform about the same. Filter was an M1-108a. Note: this is the VQ35HR, not the "DE" they have listed.
I was in Fort Wayne for a couple days (for work) so I was able to drop this off in person yesterday. They finished it before EOB today!
OCI was approx 5 months and 9,588 miles, so obviously a lot of highway miles. I tend to drive a bit "spirited" with some WOT.
'98 BMW 328is 138k
Current: M1 0w-40/MANN filter
'07 Infiniti G35x 110k
Current: M1 0w-40 FS/M1-108
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: cutlassvillager] #4527124
09/26/17 09:02 PM
09/26/17 09:02 PM
MN
oil_film_movies Offline
MN
10 years old... Time to switch to a High Mileage synthetic oil. Any brand full synthetic HM 5w30 you see will do it. Keeps those seals flexible so leaks don't start happening.
Good report. I really think you'd get the same results using the OEM spec viscosity 5w30 or 0w30 oil though. And better MPG and peak power too.
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: cutlassvillager] #4527132
09/26/17 09:14 PM
09/26/17 09:14 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
This looks very good to me, 9588 miles and only 11 ppm iron and with a retained TBN of 4.0 shows a lot more life left in the oil and nice low wear numbers.
The oil looks good too with Ca at 2700 ppm, Boron at 155 ppm, Moly at 73 ppm and Zinc a strong 968 ppm. With a KV100 of 12.85 cSt it's still within it's viscosity grade, and at the thin end (typical of a 0W40), with 12.5 cSt being the J300 30 grade cut off.
With the long-life Euro spec M1 0W40 A3/B4 being this good, I still don't understand the point of M1 AP (apart from marketing).
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: cutlassvillager] #4527153
09/26/17 09:48 PM
09/26/17 09:48 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
You won't get good results with the other foreign-owned oil. Kudos.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: SR5] #4527157
09/26/17 09:51 PM
09/26/17 09:51 PM
MN
MN
Who's to say the 5w30 M1 AP isn't simply a 0w40 without as much VII, and with Mg substituting for all that Ca (for LSPI prevention)?
They could have easily done that.
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: oil_film_movies] #4527225
09/27/17 01:18 AM
09/27/17 01:18 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Well to be Euro A3/B4 it is required to have a TBN above 10, with something like 11 to 12 being typical values. It's also common (but not strictly necessary) for Euro grades to have about 1000 ppm Zinc for strong wear protection over a long OCI. Don't forget in Europe a typical OCI on a synthetic A3/B4 oil would typically be 20,000 miles and 2 years.
M1 0W40 FS is listed as 1100 ppm zinc in Mobil documents with a 12.6 for the TBN .
Here is a VOA for M1 0W20 AP
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4401328/
It has a TBN of 7.8 with 520 ppm Zinc, much lower numbers.
Also the M1 0W20 AP has Ca at 785 ppm and Mg at 581 ppm to give a total Ca + Mg = 1366 ppm, while the UOA above for M1 0W40 A3/B4 shows 2732 ppm Ca which is about double, also the M1 0W40 has 155ppm Boron, again about double the 74ppm Boron for the M1 0W20 AP.
Not saying M1 AP is a bad oil, the opposite in fact, I'm sure it's a good oil like all M1 products. But I believe the M1 0W40 with Euro OEM specs like MB 229.5 and Porsche A40 is still their best oil and would still be my personal pick if I could only get one M1 product.
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: SR5] #4527238
09/27/17 02:24 AM
09/27/17 02:24 AM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
I agree with you SR5. Based upon specs the Mobil 1 0w40 is their best offering available. I do strongly suspect that the Mobil 1 annual protection has a lot of shall we say goodies in it that don't show up on a VOA. I also saw where an elemental analysis by Napa was a fair amount different than the ones by Blackstone. Makes one wonder a bit about that has well.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: oil_film_movies] #4527266
09/27/17 05:12 AM
09/27/17 05:12 AM
South OZ
KL31 Offline
KL31  Offline
South OZ
I usually have a good sarcasm detector. But I'm putting that one down to mental failure.
OP seems like a good run to me!
95 MX-3 2.5L|Shell Helix Ultra 5W40|Wix 51356
04 Focus 1.8L|Wesfil Cooper WZ63|Valvoline MST 5W30
05 Kluger 3.3L|Wesfil Cooper WZ418|Magnatec 10W30 Semi Syn
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: SR5] #4527269
09/27/17 05:25 AM
09/27/17 05:25 AM
Texas
4WD Offline
4WD  Offline
Texas
Being M1 AP is offered only in 20's and 30's seems that's another market. I would not think there are that many (outside a group like this) running a grade higher. Have already done so on my ecoboost - and M1 0w40 is the next oil I have on deck - paid $23/jug with free shipping...
My searches were defaulting local a few days back in Oz - that's where this one appeared:
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: 4WD] #4527296
09/27/17 06:37 AM
09/27/17 06:37 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Yeah, that makes sense. I personally would just step it up a grade, especially if DI and fuel dilution was a concern over a long OCI. But I can see many wanting to follow the book, which is fair enough. Still when did one year become a long oil change ? That is my standard.
Are you in Texas or Oz ?
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: cutlassvillager] #4527354
09/27/17 08:17 AM
09/27/17 08:17 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Excellent run from what is arguably Mobil's best PCMO product thumbsup Keep doing what you are doing.
2016 Grand Cherokee SRT - Castrol Edge 0w-40, FRAM Ultra
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: SR5] #4527399
09/27/17 09:18 AM
09/27/17 09:18 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Marketing works.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: cutlassvillager] #4527448
09/27/17 10:21 AM
09/27/17 10:21 AM
Utah, USA
28oz Offline
28oz  Offline
Utah, USA
Very nice on the VQ! Wish Mobil 1 0W-40 held up that well against shear in my VG30DE.
1990 Nissan 300zx VG30DE - PP Euro 0W-40
2004 Nissan Quest VQ35DE - PP Euro 0W-40
2003 Ford Excursion 7.3 PSD - Rotella T6 5W-40
2005 Ford Taurus 3.0 Vulcan - Havoline HM 5W-20
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: 28oz] #4529612
09/29/17 05:28 PM
09/29/17 05:28 PM
Michigan
Michigan
Apparently my VQ was much easier on the oil than your VG! Wonder why that is. It looks like Blackstone chose the wrong engine code for yours too.
'98 BMW 328is 138k
Re: Mobil 1 0w-40, 9k MI, '07 Infiniti G35x 2nd UOA [Re: cutlassvillager] #4529614
09/29/17 05:28 PM
09/29/17 05:28 PM
Michigan
Michigan
Thanks for the input everyone. I was mostly concerned if the "FS" version of 0w-40 would hold up the same - glad to see it does! I also felt a little bad going nearly 10k with an engine that's supposedly hard on oil. The M1-108 filter also seems super small compared to some other vehicles I've worked on. More M1 it is!
'98 BMW 328is 138k
