Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
Household lubricants (general purpose) differences
by 92saturnsl2. 09/22/18 04:35 PM
debris in my engine oil--what to do?
by Jasper8146. 09/22/18 03:50 PM
Is this seal bad?
by parshisa. 09/22/18 03:44 PM
Leather Masters Protection Cream review....
by gregk24. 09/22/18 03:13 PM
Aisin WS
by RodneyM. 09/22/18 03:11 PM
Husqvarna trimmer questions
by BrianF. 09/22/18 02:51 PM
Uber Self-Driv Death: Disabled Pedest Avoidance!!!!
by oil_film_movies. 09/22/18 02:29 PM
Question on Backlight setting on LED tv's
by LoneRanger. 09/22/18 02:16 PM
Are all Dexos 1 Gen 2 Oils the Same?
by Gene K. 09/22/18 01:58 PM
ECOGARD X10479 CUT OPEN
by 53' Stude. 09/22/18 01:38 PM
Rust-Oleum Driveway Sealer review
by SVTCobra. 09/22/18 01:24 PM
Flush OAT/IAT mixture
by OpenClose. 09/22/18 12:20 PM
And They Say Spelling is Not Important.
by PimTac. 09/22/18 12:06 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
90 registered members (2004tdigls, 2015_PSD, 53' Stude, 2013ecof150, 77GrandPrix, 12 invisible), 1,635 guests, and 41 spiders.
Topics290,839
Posts4,851,233
Members66,040
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Caterpillar Hydo Alternatives ? #4526996
09/26/17 06:48 PM
09/26/17 06:48 PM
Upstate NY
mtnxtreme Offline OP
Upstate NY
Is there any alternative to the Cat HYDO oil for hydraulic system ? I saw some Traveller brand "Premium" Trans Hydraulic Fluid at Tractor Supply but it only lists Cat T0-2 designation which is an older one, so I'm afraid to buy it. Is there any aftermarket oil that matches the HYDO spec, Cat Hydo is $ 150 for 5 gallons at the Cat dealer and I need 4 pails.
Re: Caterpillar Hydo Alternatives ? [Re: mtnxtreme] #4527175
09/26/17 10:28 PM
09/26/17 10:28 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Cat HYDO is hydraulic oil, with minimum 900 ppm of zinc.
Cat TO-2 is a an obsolete spec for transmission oil, which could be used as a hydraulic oil.... but may contain VI improvers.
I would use any branded hydraulic oils in AW 46 /AW 68/AW 100 grades.
Re: Caterpillar Hydo Alternatives ? [Re: mtnxtreme] #4527387
09/27/17 08:55 AM
09/27/17 08:55 AM
Battle Creek, MI
SVTCobra Online sleepy
SVTCobra  Online Sleepy
Battle Creek, MI
Are you looking for hydraulic oil that meets the HYDO spec, or light weight gear lube that meets the TO-4 specificiation? As zeng said the hydo is hydraulic, the TO-4 is transmission oil.
If marriage was outlawed only outlaws would have in-laws.
Re: Caterpillar Hydo Alternatives ? [Re: zeng] #4527392
09/27/17 09:08 AM
09/27/17 09:08 AM
Upstate NY
Upstate NY
What about ISO 46 and GL4 are they compatible or old also ? So basically stay away from anything rated for TO-2 because it's the older spec. and anything that states "hydraulic/transmission oil" ? My 2003 manual just says HYDO 10/30, Cat put out a bulletin in 2016 stating new oils, HYDO 10 wt, HYDO 20 wt, and HYDO 30 wt. and states : If a different viscosity is required due to ambient temperatures, the following Caterpillar oils can be used: Cat Diesel Engine oil 10/30 or 15/40. I mean is that basically saying I can throw 5/40 Rotella full synthetic or 15/40 Rotella synthetic blend oil in there ? If I gotta pay the same price, I think I'd rather have synthetic, although they state if using DEO then the fluid change interval should be 2000 hours instead of 6000 ??
Re: Caterpillar Hydo Alternatives ? [Re: SVTCobra] #4527393
09/27/17 09:09 AM
09/27/17 09:09 AM
Upstate NY
Upstate NY
" Are you looking for hydraulic oil that meets the HYDO spec, or light weight gear lube that meets the TO-4 specificiation? As zeng said the hydo is hydraulic, the TO-4 is transmission oil. "
Looking for HYDO but not wanting to pay Cat $150 a pail !
Re: Caterpillar Hydo Alternatives ? [Re: mtnxtreme] #4527520
09/27/17 11:45 AM
09/27/17 11:45 AM
lllinois
salesrep Offline
salesrep  Offline
lllinois
Schaeffers 239s is an excellent cross reference for this application.
http://www.schaefferoil.com/documents/125-239S-td.pdf
High quality Specialized Lubricants pay for themselves!
Re: Caterpillar Hydo Alternatives ? [Re: mtnxtreme] #4527523
09/27/17 11:51 AM
09/27/17 11:51 AM
Battle Creek, MI
Battle Creek, MI
From the Cat website I found that if Cat HYDO oil is not available, TO-4 oil can be used. This oil meets the TO-4 spec.
http://www.schaefferoil.com/239-superlube.html
Re: Caterpillar Hydo Alternatives ? [Re: mtnxtreme] #4527616
09/27/17 01:39 PM
09/27/17 01:39 PM
Upstate NY
Upstate NY
I just checked my manual and it says HYDO only. And the 2016 bulletin says DEO to substitute HYDO. looking thru the Schaeffer 239 it doesn't state anywhere it meets HYDO spec.
Re: Caterpillar Hydo Alternatives ? [Re: mtnxtreme] #4527649
09/27/17 02:24 PM
09/27/17 02:24 PM
Upstate NY
Upstate NY
Would be nice to find a HYDO spec sheet to see whats in it and/or who makes it ?
Re: Caterpillar Hydo Alternatives ? [Re: mtnxtreme] #4527675
09/27/17 03:05 PM
09/27/17 03:05 PM
Middle of Iowa
DriveHard Offline
DriveHard  Offline
Middle of Iowa
This should have most of the info you are looking for.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&uact=8&ved=0ahUKEwjm5beblMbWAhWBblAKHW20Bj4QFghEMAQ&url=http%3A%2F%2Fwww.toromontcat.com%2Fpdf%2FHydraulicOil.pdf&usg=AFQjCNGPlj7OH1Pim00HvNx0JVCCLjPe5Q
Smile, it increases your face value
2011 Silverado Crew Cab LT 6.2L/6spd
2017 Jeep Renegade Trailhawk (wife's)
2007 Nissan Xterra (trail toy)
2013 Fiat 500 Abarth (my DD)
Elio...?
Re: Caterpillar Hydo Alternatives ? [Re: mtnxtreme] #4527679
09/27/17 03:13 PM
09/27/17 03:13 PM
lllinois
salesrep Offline
salesrep  Offline
lllinois
Schaeffers meets and exceeds all the specs discussed here. Updating TD sheets for every manufacturers newest fluid is a timely and costly process.a Schaeffers 239s will not only reduce your temperatures, extend the life of your components, but will generally save you money in fuel usage.
Re: Caterpillar Hydo Alternatives ? [Re: salesrep] #4527686
09/27/17 03:18 PM
09/27/17 03:18 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Do you sell the stuff or something? You mention it all the time. Proper disclosure would be nice.
Re: Caterpillar Hydo Alternatives ? [Re: mtnxtreme] #4527859
09/27/17 07:21 PM
09/27/17 07:21 PM
lllinois
salesrep Offline
salesrep  Offline
lllinois
I do and have for over 14 years.
Most on the board are aware of that, as I am one of early members
This makes me prejudiced and biased, but far from un-factual.
Re: Caterpillar Hydo Alternatives ? [Re: mtnxtreme] #4527949
09/27/17 09:12 PM
09/27/17 09:12 PM
Upstate NY
Upstate NY
Wher do you buy this Schaeffer stuff ?
Re: Caterpillar Hydo Alternatives ? [Re: mtnxtreme] #4527955
09/27/17 09:15 PM
09/27/17 09:15 PM
lllinois
salesrep Offline
salesrep  Offline
lllinois
Page 1 of 3 1 2 3
