Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
Back to Basics II
by MolaKule. 12/14/18 04:31 PM
"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
All Mazda 3’s have bad OCV’s?
by buster. 12/14/18 03:44 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
78 registered members (Ag76, 4WD, alphadog, 2015Corolla, alcyon, 13 invisible), 1,385 guests, and 39 spiders.
Topics295,089
Posts4,927,564
Members66,684
Most Online2,553
Oct 27th, 2018
Are Toyota OEM Good For 10K? #4526945
09/26/17 05:04 PM
09/26/17 05:04 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
No, I haven't searched this as I don't know what words to type in the search. If I am gonna push my OCI's to 10K, are the stock Toyota OEM oil filters ok to use? Should I go to the Napa Platinum? Or Fram Ultra? Wix XP?
Please don't suggest I change the oil filters at 5k and the oil at 10K. Please?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: Are Toyota OEM Good For 10K? [Re: Gebo] #4526953
09/26/17 05:09 PM
09/26/17 05:09 PM
USA
slacktide_bitog Offline
USA
depends on the car and the driving conditions. On some cars, Toyota's spec OCI is 10k. OEM filters are good for the OEM OCI smile
Even though you like Toyota OEM filters, Mahle makes awesome cartridge filters for Toyota applications.
Re: Are Toyota OEM Good For 10K? [Re: Gebo] #4526960
09/26/17 05:16 PM
09/26/17 05:16 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Why wouldn't they be. Toyota recommends the oil change interval.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Are Toyota OEM Good For 10K? [Re: CT8] #4526962
09/26/17 05:19 PM
09/26/17 05:19 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
I'm asking about the fleet in my sig. All old stuff..
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: Are Toyota OEM Good For 10K? [Re: Gebo] #4526971
09/26/17 05:32 PM
09/26/17 05:32 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
If your engines are clean probably yes. If sludggy nope. If you want a guarantee goe with framultra, m1 or other synthetic filter.
Re: Are Toyota OEM Good For 10K? [Re: Gebo] #4526974
09/26/17 05:33 PM
09/26/17 05:33 PM
New Jersey
THafeez Offline
THafeez  Offline
New Jersey
toyota care doesnt change the oil until 10k on dealer bulk and their own filters. Millions of toyotas under the 2 year free maint and some who extend it indefinitely run those intervals. I think you will be fine. My moms sienna and sisters prius both have oem filters and dealer bulk and they are both running great. My own solara is much older so I don't push oil past 7k because of many factors, but my fram ultra has been on over about a year and 10k. Plan on changing it soon to see how much it collected.
2004 Toyota Solara SE 2.4 2AZFE
182,000 miles
Castrol Magnatec Semi-Syn 5W30
Royal Purple 20-400 oversize 2nd run
Re: Are Toyota OEM Good For 10K? [Re: THafeez] #4526977
09/26/17 05:35 PM
09/26/17 05:35 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Yes, no sweat. OEM filter and TGMO, I topped off with some Mobil HM oil and it hasn't used any since. OEM air filter had 40k on it and was changed out at 60k. And so was the cabin filter fyi.
Re: Are Toyota OEM Good For 10K? [Re: Gebo] #4527079
09/26/17 07:19 PM
09/26/17 07:19 PM
CA
raytseng Offline
raytseng  Offline
CA
it dependa on your conditions so nobody can tell you for sure.
i think the cartridge filters will be fine as all of those are newer design.
the older cars regular usage interval is 7500miles so you arent extending that far
but i would ask which oem filters for the canister filters? the v6 or the v8 longer one).
i would say the v8 one is probably fine for the fleet. the v6 one maybe iffy if used on the v8. same thing for aftermarket parts. many spec the same filter for v6 and v8 and its sizes like the toyota v6.
i dont think you should get sucked in by the fancy marketting for extended drain. if you want something fancy instead go for oversized filters, e.g. purolator pl20195 instead of pl10241 assuming it will fit.
if you want to test then do the worst case and put 10k miles on the ls400 with the smallest v6 filter and then cut it open and take a look.
Re: Are Toyota OEM Good For 10K? [Re: Gebo] #4527171
09/26/17 09:26 PM
09/26/17 09:26 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Confident you are good. The OEM for my car resembles the TG once opened up. If you can get a good deal on a napa gold, id personally go with that over the OEM just to make me sleep easy (i blame bitog for making me overly cautious and possibly somewhat neurotic)
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Are Toyota OEM Good For 10K? [Re: Gebo] #4527191
09/26/17 09:51 PM
09/26/17 09:51 PM
TN
mballard70 Offline
mballard70  Offline
TN
I just pulled a Toyota OEM cartridge filter out of my wife's 2015 4Runner after a 10,300 mile run. I was astounded at how good it looked, it was literally as perfect as the one I put back in it, just discolored. I was a little skeptical, as the cartridge Mobil One filters looked much sturdier, but after using both, I'm sold on the Toyota filter. It was only $7 from the dealer.
2015 Toyota 4 Runner SR5 Premium 4x4
2007 Lexus ES 350
2003 Nissan 350Z Enthusiast
2002 Toyota 4 Runner SR5 Sport Edition
1997 Toyota 4 Runner SR5 4x4
Re: Are Toyota OEM Good For 10K? [Re: Gebo] #4527212
09/26/17 10:45 PM
09/26/17 10:45 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Doesn't Toyota say 10K OCIs when using sythetic oil? If so, then they are also saying their OEM filterd are good for 10K.
Re: Are Toyota OEM Good For 10K? [Re: ZeeOSix] #4527219
09/26/17 11:51 PM
09/26/17 11:51 PM
CA
raytseng Offline
raytseng  Offline
CA
only for newer cars. this rec isn't backspecced all the way to 1990.
Re: Are Toyota OEM Good For 10K? [Re: raytseng] #4527222
09/27/17 12:11 AM
09/27/17 12:11 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
I'd say the OEM filter would do 10K if the engine is well maintained and clean inside since Toyota says it will today on their newer vehicles.
If the OP isn't comfortable doing 10K on an OEM filter then go with a full synthetic like the Ultra. Also, even older engines in good shape should be able to go 10K OCIs on a good full synthetic oil, regardless if Toyota didn't back spec their service requirements.
Re: Are Toyota OEM Good For 10K? [Re: Gebo] #4527233
09/27/17 12:43 AM
09/27/17 12:43 AM
CA
raytseng Offline
raytseng  Offline
CA
I agree with your end recommendation, but not with your logic.
Toyota didn't backspec and that is a binary yes/no fact. Just because you feel it to be true doesn't make it true.
it's nothing about the "shape" or condition of the engine, but the engine design. The Older engines, even if brand new consumed more fuel, and had dumber vvti and all that other fancy stuff, which means more combustion byproducts into the oil. OCI recommendation on the older cars is 7500.
That being said, all those engines are bulletproof, so the engine will be "fine" and will keep running, even if you threw sludge into a 1UZ or 2JZ, the engine is still going to run on the sludge, perhaps less than optimally, but will get you from point a to point b, and will run fine again once you finally change the sludge out. But end of the story, it's not recommended by toyota, and they did not say those words.
Re: Are Toyota OEM Good For 10K? [Re: raytseng] #4527235
09/27/17 01:04 AM
09/27/17 01:04 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
^^^ Does Mobil, Pennzoil, Amsoil, or anyone else who makes full synthetic oil say it can"t go 10K OCIs in an older clean engine? If those older engines did 7500 miles on dyno they can certainly do 10K miles on full synthetic. That's all I'm saying regardless of what Toyota says about "back specing" or not. OPs oldest vehicle in his signature is a 1998.
OP said in his 1st post that he's going to do 10K OCIs - didn't mention what oil he's using - I'm assuming a full synthetic.
