Radiative Cooling into space
'Stralia
While investigating ice storage a few weeks ago, I found that they were making ice in Egypt in clay vessels at night, and apparently Iran's shah like sorbet that they made by placing dishes at the bottom of wells.
Apparently if you can exclude direct sunlight, plus get the emissivities right at different spectrums, you can radiate heat into the 3K sky in the middle of the day and cool stuff down.
This is an interesting topic and I remember one of my thermodynamics professors mentioning it in regards to the black body temperature of the night sky. I recall it depended on a lot of things but overall it could be around 0 degrees C.
From my schooling I remember the sky in outer space is around 4 degrees Kelvin, around what Shannow posted.
If it was 0 degrees C, nowhere on Earth could it be below that.
Yep, it's common to get ice on the top of cars on a clear night if there's moisture on them due to the direct view factor and heat loss to space, even though the ambient air temperature is above freezing.
We can get that ice on roads here too, couple of local overpasses can lose a lot of heat that the morning fog freezes...
There doesn't have to be moisture on them, other than moisture that condenses from the air (aka, dew) due to the same radiative cooling to space on a clear night. Basic Heat Transfer! For related reasons, a white roof can not only be less hot than a black roof on a sunny day, but also less hot than a shiny metal one.
Yep, another good example. Happens here all the time with the high humidity and clear nights even if the air temp is well above freezing. The highway department lays down that salt brine juice to keep the overpasses from getting black ice.
Yep, if the air humidity is high enough the cold sheet metal from losing heat to space on a clear night will condense moisture from the air and it may also freeze. Similar to an iced drink in a glass condensing moisture from humid air.
Now you're talking about solar absorption properties of surfaces along with their radiative and conductive losses. If the roof was chromed like a car bumper it would absorb less solar radiation than some white paints. Here's a quick search that shows a table of different surfaces ... chromium plate (I assume very shiny chrome surface) is only 0.20 absorption.
http://www.engineeringtoolbox.com/radiation-surface-absorptivity-d_1805.html
Here's another table showing solar absorption properties. Aluminum foil (which is pretty shiny) is alpha 0.15, and white paint ranges from 0.23 - 0.49 depending on what is is exactly.
http://www.solarmirror.com/fom/fom-serve/cache/43.html
Handy chart that shows the wavelength dependence discussed in the video
Having lived in a white painted fibro cement house for 20+ years, it's no surprise that at night, it released heat like a black body...red double brick in the new place makes cold mornings much more tolerable
Coldest night I ever spent was in the Sierra Madre in Mexico, and I've camped out in the Scottish Highlands in winter quite a lot.
Very clear, no wind, lots of stars, bloody freezing.
