Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
85 registered members (bfleeman, aquariuscsm, 4WD, aba4430, Bailes1992, 12 invisible), 1,749 guests, and 42 spiders.
Topics295,012
Posts4,925,993
Members66,664
Most Online2,553
Oct 27th, 2018
Radiative Cooling into space #4526170
09/25/17 07:14 PM
09/25/17 07:14 PM
'Stralia
Shannow Offline OP
Shannow  Offline OP
'Stralia
While investigating ice storage a few weeks ago, I found that they were making ice in Egypt in clay vessels at night, and apparently Iran's shah like sorbet that they made by placing dishes at the bottom of wells.
Apparently if you can exclude direct sunlight, plus get the emissivities right at different spectrums, you can radiate heat into the 3K sky in the middle of the day and cool stuff down.
Re: Radiative Cooling into space [Re: Shannow] #4526175
09/25/17 07:22 PM
09/25/17 07:22 PM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
This is an interesting topic and I remember one of my thermodynamics professors mentioning it in regards to the black body temperature of the night sky. I recall it depended on a lot of things but overall it could be around 0 degrees C.
1994 BMW 530i, 238K
1996 Honda Accord, 266K
1999 Toyota Sienna, 407K
2000 Toyota ECHO, 280K
Re: Radiative Cooling into space [Re: Shannow] #4526229
09/25/17 08:22 PM
09/25/17 08:22 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
You mean we could generate Glo Bull Cooling?
2004 Corolla 126649
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Radiative Cooling into space [Re: kschachn] #4526236
09/25/17 08:29 PM
09/25/17 08:29 PM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
From my schooling I remember the sky in outer space is around 4 degrees Kelvin, around what Shannow posted.
If it was 0 degrees C, nowhere on Earth could it be below that.
Re: Radiative Cooling into space [Re: Shannow] #4526243
09/25/17 08:38 PM
09/25/17 08:38 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Yep, it's common to get ice on the top of cars on a clear night if there's moisture on them due to the direct view factor and heat loss to space, even though the ambient air temperature is above freezing.
Re: Radiative Cooling into space [Re: ZeeOSix] #4526250
09/25/17 08:58 PM
09/25/17 08:58 PM
'Stralia
Shannow Offline OP
Shannow  Offline OP
'Stralia
We can get that ice on roads here too, couple of local overpasses can lose a lot of heat that the morning fog freezes...
Re: Radiative Cooling into space [Re: ZeeOSix] #4526259
09/25/17 09:09 PM
09/25/17 09:09 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
There doesn't have to be moisture on them, other than moisture that condenses from the air (aka, dew) due to the same radiative cooling to space on a clear night. Basic Heat Transfer! For related reasons, a white roof can not only be less hot than a black roof on a sunny day, but also less hot than a shiny metal one.
2011 Toyota Prius now at 94K
Re: Radiative Cooling into space [Re: Shannow] #4526261
09/25/17 09:12 PM
09/25/17 09:12 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Yep, another good example. Happens here all the time with the high humidity and clear nights even if the air temp is well above freezing. The highway department lays down that salt brine juice to keep the overpasses from getting black ice.
Re: Radiative Cooling into space [Re: CR94] #4526266
09/25/17 09:18 PM
09/25/17 09:18 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Yep, if the air humidity is high enough the cold sheet metal from losing heat to space on a clear night will condense moisture from the air and it may also freeze. Similar to an iced drink in a glass condensing moisture from humid air.
Now you're talking about solar absorption properties of surfaces along with their radiative and conductive losses. If the roof was chromed like a car bumper it would absorb less solar radiation than some white paints. Here's a quick search that shows a table of different surfaces ... chromium plate (I assume very shiny chrome surface) is only 0.20 absorption.
http://www.engineeringtoolbox.com/radiation-surface-absorptivity-d_1805.html
Here's another table showing solar absorption properties. Aluminum foil (which is pretty shiny) is alpha 0.15, and white paint ranges from 0.23 - 0.49 depending on what is is exactly.
http://www.solarmirror.com/fom/fom-serve/cache/43.html
Re: Radiative Cooling into space [Re: Shannow] #4526379
09/26/17 04:31 AM
09/26/17 04:31 AM
Margate England
Claud Offline
Claud  Offline
Margate England
Apparantly more people die from hypothermia than heat stroke in high elevation deserts...
Claud.
Re: Radiative Cooling into space [Re: Shannow] #4526386
09/26/17 04:47 AM
09/26/17 04:47 AM
'Stralia
Shannow Offline OP
Shannow  Offline OP
'Stralia
Handy chart that shows the wavelength dependence discussed in the video
Having lived in a white painted fibro cement house for 20+ years, it's no surprise that at night, it released heat like a black body...red double brick in the new place makes cold mornings much more tolerable
Re: Radiative Cooling into space [Re: Shannow] #4526395
09/26/17 05:05 AM
09/26/17 05:05 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Coldest night I ever spent was in the Sierra Madre in Mexico, and I've camped out in the Scottish Highlands in winter quite a lot.
Very clear, no wind, lots of stars, bloody freezing.
