Looking at a cheap commuter!
by ryan2022. 09/21/18 09:46 AM
Does Your 3.5EB Make Oil
by Gene K. 09/21/18 09:07 AM
F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
91 registered members (9050lx, aquariuscsm, andyd, 2010Civic, advocate, 7 invisible), 1,635 guests, and 35 spiders.
Topics290,754
Posts4,849,697
Members66,034
Most Online3,590
Jan 24th, 2017
Water contamination in a hydraulic system #4525924
09/25/17 03:40 PM
09/25/17 03:40 PM
Battle Creek, MI
SVTCobra Offline OP
SVTCobra  Offline OP
Battle Creek, MI
One of my buddies has a Case 480D loader and a problem he has had is water in the hydraulic system. We've installed a water faucet instead of the drain plug to drain water off, but that doesn't fix the underlying problem. Researching it there is a lot of info, but most of the solutions are expensive (like vacuum dehydrators), or something that is impractical without a lot of modifications to the current system (like using an oil filter that can trap water, there is only one filter and apparently don't trap dirt as well.)
What the underlying problem is that it doesn't have a proper vent - it vents through the cap and the previous owners put silicone in it thinking that there were problems with water ingress. My initial idea with my buddy was to use a desiccant filter so that as the air flows through it dries out and only dry air can enter the hydraulic system. He doesn't run it long enough at one time to heat the oil to an appreciable amount to evaporate water that well.
So the question is: Are there products available that would help remove water as it runs like a centrifuge or bypass filtration?
If marriage was outlawed only outlaws would have in-laws.
Re: Water contamination in a hydraulic system [Re: SVTCobra] #4525982
09/25/17 04:57 PM
09/25/17 04:57 PM
Buffalo, NY
JTK Online content
JTK  Online Content
Buffalo, NY
How much hydraulic oil does the machine hold? The easiest method is to fix the breather system and just keep changing the oil.
I know we've run into this with the lube systems on big industrial compressors at work with sumps that hold 100's of gallons of oil. Very expensive oil changes.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Water contamination in a hydraulic system [Re: SVTCobra] #4526061
09/25/17 06:16 PM
09/25/17 06:16 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
I had this problem with my log splitter when I got it, it had sat uncovered for years with a bad vent on the tank. Several 5 gallon buckets of cheap hydraulic oil, use, & changes got almost all of the water out (along with a new vent).
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Water contamination in a hydraulic system [Re: SVTCobra] #4526142
09/25/17 07:46 PM
09/25/17 07:46 PM
Amarillo Texas
csx7006 Offline
csx7006  Offline
Amarillo Texas
Its a case, what do you expect? just do alot of flushing and filter changes
Re: Water contamination in a hydraulic system [Re: SVTCobra] #4526186
09/25/17 08:39 PM
09/25/17 08:39 PM
Battle Creek, MI
SVTCobra Offline OP
SVTCobra  Offline OP
Battle Creek, MI
It's a 12 gallon system with synthetic oil, so hate to just drain it after a year.
Re: Water contamination in a hydraulic system [Re: csx7006] #4526188
09/25/17 08:40 PM
09/25/17 08:40 PM
Battle Creek, MI
SVTCobra Offline OP
SVTCobra  Offline OP
Battle Creek, MI
Doesn't really address how it got contaminated to begin with.
Re: Water contamination in a hydraulic system [Re: SVTCobra] #4526264
09/25/17 10:17 PM
09/25/17 10:17 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
That's what I would sort out first, and get the right vented cap. I would be tempted just to run it hard and get the fluid hot enough to evaporate the water but that could get expensive if there's too much water... Flash boiling probably isn't good for a hyd pump.
I guess you could drain it and evaporate the water, maybe an outdoor propane burner and a 10 gal steel pot would be pretty quick, just don't over do it.
07 Focus ZXW, 5spd manual, 210km M1 5W30
18 Outback 2.5 CVT 10km 0W20 "bulk subaru" whatever that is
Re: Water contamination in a hydraulic system [Re: IndyIan] #4526728
09/26/17 01:12 PM
09/26/17 01:12 PM
Battle Creek, MI
SVTCobra Offline OP
SVTCobra  Offline OP
Battle Creek, MI
I like that idea - cheap and already have an outdoor propane burner. Throw on a desiccant filter/breather and he parks it under a lean to so no other sources of water ingress.
