Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Pr 1970 Superbirds For sale - Barn Find
by user52165. 09/20/18 12:32 PM
Fram Ultra Air Filters
by StevieC. 09/20/18 12:20 PM
Change oil filter or not. Very low miles
by Martin10. 09/20/18 11:37 AM
Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
A woman I work with wants an affair with me!
by Drew99GT. 09/20/18 11:08 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Carolina Reaper hot peppers
by gman2304. 09/20/18 09:54 AM
New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
02 Focus head replacement
by Eric Smith. 09/20/18 08:08 AM
A5/B5 or A3/B3
by ka9mnx. 09/20/18 07:53 AM
2018 Mazda 3 2.5 Castrol or Mazda Moly
by mazdamonky. 09/20/18 07:44 AM
What fuel are you running?
by Matagonka. 09/20/18 07:25 AM
Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
104 registered members (Astro14, 94astro, ABomb369, ad244, 13 invisible), 1,741 guests, and 44 spiders.
Topics290,714
Posts4,848,926
Members66,021
Most Online3,590
Jan 24th, 2017
Extending OCI in Oil Burner #4525865
09/25/17 02:45 PM
09/25/17 02:45 PM
Venezuela, South America
Emanuel Offline OP
Emanuel  Offline OP
My 284k miles Corolla is burning 0.8 quarts every 1k miles. I usually do 3k OCI on conventional oil so I add 2 quarts of oil between oil changes and in the last 300 miles I let the oil level drop to the middle, which is the lowest that Iīm confortable with.
If I adding that quantity of oil between oil changes could I safely extend the OCI? The make up oil should replenish the additives, but Iīm concerned that there could be fuel dilution caused by the blowby the engine must have.
An oil analysis isnīt possible for me, down here in Venezuela it costs 40$ and a oil change cost less than 10$ so I would rather do frequent oil changes that doing a oil analysis.
I donīt consider my car a pretty bad oil burner, I think that 0.8 qt (and sometimes 0.65 qt) every 1k miles is pretty decent for its age and mileage. Iīm currently using a 15w40 HDEO with CI4/SL rating.
Re: Extending OCI in Oil Burner [Re: Emanuel] #4525872
09/25/17 02:49 PM
09/25/17 02:49 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yes, you are correct.
You can change the oil at 15,000 (or more) miles,
no harm will come to your engine since you are often adding fresh oil.
Re: Extending OCI in Oil Burner [Re: Emanuel] #4525876
09/25/17 02:52 PM
09/25/17 02:52 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
What year? I know the 98-02 has a problem with the oil control return holes.
06 Escalade 6.0L LQ9 AWD 165k M1 5w30
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Extending OCI in Oil Burner [Re: Emanuel] #4525879
09/25/17 02:53 PM
09/25/17 02:53 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
I would have no problem extending the OCI, I did this on my last prius that burned about as much oil as your car and I would just change the filter every 5k miles and do a full change at the 10k mark (though you could probably go longer!)
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: Extending OCI in Oil Burner [Re: Emanuel] #4525887
09/25/17 03:02 PM
09/25/17 03:02 PM
Michigan
slug_bug Offline
slug_bug  Offline
Michigan
I decided to stretch the OCI on my oil burning Chrysler mini-van the last time. It burns about the same amount of oil as yours. I put a Fram Ultra on it and ran it 20,000 miles while adding a quart whenever it reached the low mark. I started with synthetic and added whatever leftover synthetic I had on hand from the $2.00 per quart stash. The car ran great and the oil actually looked pretty good when I drained it at 20k. This is going to be my plan going forward on the Dodge Grand Caravan.
2016 Miata 2.0l (12k)
2013 Fusion 2.5l(78k)
2013 Focus(56K)
2010 Linc MKX 3.5l(88k)
2007 Dodge Caravan 3.8l(179k)
2003 Merc. Mountaineer 4.6l(114k)
Re: Extending OCI in Oil Burner [Re: Emanuel] #4525891
09/25/17 03:06 PM
09/25/17 03:06 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Originally Posted By: Emanuel
My 284k miles Corolla is burning 0.8 quarts every 1k miles. I usually do 3k OCI on conventional oil so I add 2 quarts of oil between oil changes and in the last 300 miles I let the oil level drop to the middle, which is the lowest that Iīm comfortable with.
As mentioned above, use a very good filter and perform a normal oil change every 15000 miles. There are several oil burners on here doing the same thing, and I have seen an analysis that looked good at that distance.
Thick vs Thin test: 15k / 43k miles complete
Re: Extending OCI in Oil Burner [Re: Emanuel] #4525909
09/25/17 03:24 PM
09/25/17 03:24 PM
South OZ
KL31 Offline
KL31  Offline
South OZ
In 3k miles you'd have added at least 2 quarts. That's probably half the sump capacity? I'd do as the others have said and go many more miles considering how much fresh oil is going in.
95 MX-3 2.5L|Shell Helix Ultra 5W40|Wix 51356
04 Focus 1.8L|Wesfil Cooper WZ63|Valvoline MST 5W30
05 Kluger 3.3L|Wesfil Cooper WZ418|Magnatec 10W30 Semi Syn
Re: Extending OCI in Oil Burner [Re: Emanuel] #4525926
09/25/17 03:42 PM
09/25/17 03:42 PM
Vienna, VA
TinyVoices Offline
TinyVoices  Offline
Vienna, VA
I'd change to a cheaper high mileage oil like MaxLife red bottle. Should slow the burning and is still cheap. Don't know what's a valuable to you down there, but I'm sure there is some high mileage oil available to you.
1993 Toyota MR2 Hardtop N/A - 160k miles - Valvoline Max Life 5w30
2006 Toyota Matrix XR AWD (Fiancee) - 130k miles - Valvoline Max Life 5w30
Re: Extending OCI in Oil Burner [Re: Emanuel] #4525942
09/25/17 03:54 PM
09/25/17 03:54 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
My car is using a quart every 4,000 miles and I have run the oil [with top ups] out to 12,000 miles. The problem is the filter comes out black and I find carbon/soot at the ends of the pleats in the oil filter. I am guessing that blow by is dumping soot into the oil at a high rate. UOA tells me everything is fine but I don't like the situation. 3,000 miles seems like a short OCI, I would go at least 5,000 miles but not to far.
Re: Extending OCI in Oil Burner [Re: Emanuel] #4526007
09/25/17 05:17 PM
09/25/17 05:17 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
I don't think it's a bad oil burner either. Burning 0.8 quartz in 1000 miles in a car with that many miles is quite reasonable. Some new car manufacturers would claim it was normal on a new car today - though I think that's a bit of a stretch. It would have been quite normal in any engine 40 or 50 years ago.
Topping up regularly and changing a quality oil every 5,000 miles would be just fine. Only thing I'd change is to a more modern oil, something with an SN rating. Though a 10W-40 would make for easier starting. I would stick with a dino (non synthetic) oil too; no point in going through expensive oil (6 or 7 quartz over 5,000 miles) when you don't need it.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: Extending OCI in Oil Burner [Re: Emanuel] #4526020
09/25/17 05:26 PM
09/25/17 05:26 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
I agree with ecotourist that 0.8 quarts in 1000 miles is not bad consumption. Running a 15w40 HDEO, you should easily be able to exceed 6000 mile change intervals with no problem, probably even stretch it to 10k miles.
How much sulfur is in the fuel in Venezuela? That might effect the OCI.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Extending OCI in Oil Burner [Re: Emanuel] #4526023
09/25/17 05:27 PM
09/25/17 05:27 PM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
It may be the oil pump gasket leaking and not burning. Oil pump leaks generally happen when the engine is running.
Re: Extending OCI in Oil Burner [Re: LeakySeals] #4527015
09/26/17 07:02 PM
09/26/17 07:02 PM
Emanuel Offline OP
Emanuel  Offline OP
Itīs a 01 but with a 98 engine (the 7AFE)
Re: Extending OCI in Oil Burner [Re: KL31] #4527018
09/26/17 07:06 PM
09/26/17 07:06 PM
Emanuel Offline OP
Emanuel  Offline OP
Thatīs true, the sump holds 3.8 qts, and if I want to keep to oil level in the full mark I have to add 2.5 qts every 3k miles.
Right now Iīm in the first 1k miles of my last oil change and I have noticed lower oil consumption with this 15w40 HDEO than with Conventional 20w50, I hope this consumption rate doesnīt increases as the OCI gets longer (it shouldnīt).
Re: Extending OCI in Oil Burner [Re: TinyVoices] #4527022
09/26/17 07:11 PM
09/26/17 07:11 PM
Emanuel Offline OP
Emanuel  Offline OP
Venezuelans donīt know anything of Oil Science so the only available High Mileage Oil is a 20w50. I used to use that oil but now Iīm testing a HDEO 15w40 and I think the oil consumption is now lower (that has been the case in the last 1k miles).
I also gonna try adding TCW3 Outboard Oil in the gas tank to see if that helps the oil rings to seal better and it can help lowering the oil consumption.
