Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
41 registered members (AP9, BKlab, 928, Bailes1992, Ag76, 4 invisible), 987 guests, and 35 spiders.
Topics290,920
Posts4,852,511
Members66,055
Most Online3,590
Jan 24th, 2017
Purolator PL24651-F07F30G1 cut & post #4525032
09/24/17 05:04 PM
09/24/17 05:04 PM
Houston, Texas
WellOiled Offline OP
Houston, Texas
I had a couple of Purolator PL24651 filters in my stash and thought I would run at least one of them for 3000 miles to see how these were doing rather than use them for target practice. I figured the filter should go 3000 miles in 2 months using Maxlife 5W30.
Purolator PL24651
Date code: F07F30G1
After 3000 miles, I did notice a little startup rattle so I arranged to see if the ADBV held or not. I came in from a long run, parked the truck and after a couple hours spun the filter off expecting to see a flood of oil which would be normal for this engine. About a tablespoon of oil fell into the drain pan from removing the filter. This means the filter did not have ADBV function. The photos will show the ADBV is in pristine condition so the source of the leak down is not likely the ADBV itself. The ADBV had no tears or cuts and was one of the best ADBVs I have touched. I suspect the sealant they use between the base plate and the external can which holds the gasket is not complete or failing. I had to use a cap wrench to remove the filter as it would not budge. The gasket stuck to the filter mount. I like the gasket, but that is not why I would buy the filter. smile
If you look closely at photo #5 at about 9 O'clock on the base plate, you will see some black residue. I believe that to be the sealant. I do not know if this is the leakage path or not. It would need closer examination and dissection.
IMG_0567-Purolator PL24651-F07F30G1 Filter label
IMG_0569-Purolator PL24651-F07F30G1 Date Code
IMG_0566-Purolator PL24651-F07F30G1 Inside of can with leaf spring
IMG_0570-Purolator PL24651-F07F30G1 Inside surface of the base plate with silicone ADBV in place
IMG_0571-Purolator PL24651-F07F30G1 Inside surface of the base plate with silicone ADBV showing inlet side of the ADBV
IMG_0580-Purolator PL24651-F07F30G1 Base plate exterior view
IMG_0573-Purolator PL24651-F07F30G1 Filter media showing wide pleat spaces either side of the splice
IMG_0574-Purolator PL24651-F07F30G1 Filter media rotated 90 degrees
IMG_0575-Purolator PL24651-F07F30G1 Filter media rotated 180 degrees
IMG_0576-Purolator PL24651-F07F30G1 Filter media rotated 300 degrees
IMG_0577-Purolator PL24651-F07F30G1 Bypass valve
IMG_0578-Purolator PL24651-F07F30G1 Inlet/Outlet end of the filter
IMG_0579-Purolator PL24651-F07F30G1 Inlet/Outlet end of the filter on axis view
Since the filter did not tear on the short run, I will use the second one on another short run. I think the Valvoline Maxlife 5W30 shears down a bit after 2000 miles or so and this may contribute to how quickly the oil drains back.
Since the wide pleat spaces are still there, I do not want to take a risk running the filter type for a longer OCI / FCI.
Enjoy and let the discussions begin.
Welloiled.
2004 Ford Ranger 4.0L V6
Valvoline Advanced Full Synthetic 5W30 + Fram Tough Guard
Re: Purolator PL24651-F07F30G1 cut & post [Re: WellOiled] #4525039
09/24/17 05:15 PM
09/24/17 05:15 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Purolator PL24651
Date code: F07F30G1
Welloiled.
I'm a bit lost as to why only spoonful of oil drained out. This filter actually looks OK
If only I could get my dam stubborn brother to stop using Purolator stuff frown
09' Camry LE, 141,020 miles
PP 5w30 and TG 4967
Re: Purolator PL24651-F07F30G1 cut & post [Re: 53' Stude] #4525044
09/24/17 05:18 PM
09/24/17 05:18 PM
Houston, Texas
Houston, Texas
The ADBV failed and the oil drained back into the sump. The filter was full of oil.
And yes, the filter and the oil could have gone further.
Re: Purolator PL24651-F07F30G1 cut & post [Re: WellOiled] #4525050
09/24/17 05:25 PM
09/24/17 05:25 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Ahh I understand now.
Purolator: NEVER AGAIN
PP 5w30 and TG 4967
Re: Purolator PL24651-F07F30G1 cut & post [Re: WellOiled] #4525059
09/24/17 05:30 PM
09/24/17 05:30 PM
Houston, Texas
Houston, Texas
I would have liked to had a couple of the new ones hot off the press. However, I am not sure it would be worth the effort. Way to many cut ADBVs.
Thanks for the feedback.
Re: Purolator PL24651-F07F30G1 cut & post [Re: WellOiled] #4525073
09/24/17 05:53 PM
09/24/17 05:53 PM
Houston, Texas
Houston, Texas
Thanks to ZeeOSix:
https://bobistheoilguy.com/forums/ubbthr...ble#Post4474681
The date code dissects as follows:
F07F30G1
F = Fayetteville, NC plant
07 = July
F = 2014
30 = 30th day
July 30, 2014.
Re: Purolator PL24651-F07F30G1 cut & post [Re: WellOiled] #4525085
09/24/17 06:06 PM
09/24/17 06:06 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Thanks for posting. I think rather than use them in your car, target practice would be the better option for them.
God Bless Our Troops
Re: Purolator PL24651-F07F30G1 cut & post [Re: WellOiled] #4525086
09/24/17 06:06 PM
09/24/17 06:06 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Thanks to ZeeOSix:
F07F30G1
07 = July
F = 2014
30 = 30th day
July 30, 2014.
We don't use any Purolators at work. On diesels which we don't have bulk oil for I use Autozone for oil and filter. Don't want a Purolator tearing on a diesel
PP 5w30 and TG 4967
Re: Purolator PL24651-F07F30G1 cut & post [Re: demarpaint] #4525089
09/24/17 06:08 PM
09/24/17 06:08 PM
Houston, Texas
Houston, Texas
I feel like I wasted the Maxlife. frown grin
And, you are welcome.
Re: Purolator PL24651-F07F30G1 cut & post [Re: 53' Stude] #4525097
09/24/17 06:14 PM
09/24/17 06:14 PM
Houston, Texas
Houston, Texas
The BITOG members in the know with diesels have given Purolator diesel filters two thumbs down. I defer to them.
Re: Purolator PL24651-F07F30G1 cut & post [Re: WellOiled] #4525118
09/24/17 06:35 PM
09/24/17 06:35 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
LOL!
Even my pops uses nothing but Donaldson or Baldwin on his diesel pickup
PP 5w30 and TG 4967
Re: Purolator PL24651-F07F30G1 cut & post [Re: WellOiled] #4525144
09/24/17 07:10 PM
09/24/17 07:10 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Well, you could have just changed the filter & left the oil in the sump (since virtually none was left in the removed filter)-Purolator, the ANTI-Ultra, TWO filters per standard OCI!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Purolator PL24651-F07F30G1 cut & post [Re: bullwinkle] #4525156
09/24/17 07:40 PM
09/24/17 07:40 PM
NY
demarpaint Offline
demarpaint  Offline
NY
That would have worked.
Thanks again to the OP for reminding me that my decision to ditch Purolator for good was a wise one.
Re: Purolator PL24651-F07F30G1 cut & post [Re: demarpaint] #4525190
09/24/17 08:27 PM
09/24/17 08:27 PM
Houston, Texas
Houston, Texas
You guys are right. That would have worked. If I could have found a few more on close out, I could have done a Maxlife TBN retention study. 99.9% efficiency @ 20 microns ISO 4548-12 according to the box. LOL crackmeup That would be just prior to the tear.
Bullwinkle, the filter was full of oil. Only a tablespoon or so came from above the filter.
Re: Purolator PL24651-F07F30G1 cut & post [Re: WellOiled] #4525228
09/24/17 08:56 PM
09/24/17 08:56 PM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
Thanks for posting these photos!
1997 Maxima 181k, Edge 10w30, K&N HP-1003
2004 Corolla 191k, VWB 5w20 + SSS 10w40, MGL4967
