Ford 4.6L Durability?
by Auae85
Yesterday at 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
Yesterday at 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
Yesterday at 10:01 PM
Fireworks Stores
by Warstud
Yesterday at 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
Yesterday at 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
Yesterday at 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
Yesterday at 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
Yesterday at 08:49 PM
My FIL in hospice
by fdcg27
Yesterday at 08:41 PM
Spraying Polyurethane
by Texican
Yesterday at 08:37 PM
Dehumidifier icing
by Kestas
Diesel lube in Petrol Engine
by Ducked
Yesterday at 07:46 PM
New key programming cost
by 92saturnsl2
Yesterday at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Yesterday at 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
Yesterday at 07:08 PM
Wheel says 50 mph max
by pda1122
Yesterday at 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
Yesterday at 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
Yesterday at 06:36 PM
Old Engine SOUND
by MasterSolenoid
Yesterday at 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
Yesterday at 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
26 registered (citationxeleven, Char Baby, clinebarger, Black, bbhero, ctechbob, 3 invisible), 888 Guests and 32 Spiders online.
65282 Members
67 Forums
285683 Topics
#4525019 - 09/24/17 04:46 PM how to shut off window motor power
mobilaltima Offline
Loc: Golden Meadow, LA
I had the Dodge in my sig's windows tinted around 2 years ago, it is a lot darker than what Louisiana law allows but thats what I wanted on my truck, really helps with glare and heat. State troopers are notorious down here for stopping and ticketing people for window tint, one trooper in particular we call him the "Tint Nazi" as thats pretty much what gets his blood flowing is when he sees a tinted vehicle. The parish cops leave us alone and dont even bother us about it. Usually when I see a trooper, I put all 4 windows down to avoid being pulled over, but if you do get pulled over theyll still make you put your windows up to check the tint with a meter. I was curious if theres a way that I can hook up a toggle switch or button under my dash, out of view, to cut off power to all 4 windows in the event of getting pulled over and made to put my windows up, that would essentially render my windows "broken". I asked an electrician friend of mine but he said it would probably be pretty complicated.
And yes, if I ruffle any feathers with this post, please refrain from negative comments or going off topic on this post,many are known to do that on here. I'm not trying to be rude. I'm a proud American and I 100% back the blue. I just feel that tint is not really that big of an issue and I dont want to constantly get ticketed for something which is so miniscule. If someone can answer my question in regards to disabling the windows, I'd greatly appreciate it.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
#4525060 - 09/24/17 05:35 PM Re: how to shut off window motor power [Re: mobilaltima]
14Accent Offline
Loc: MN
They won't buy it. I'm all for tricking the law but if he sees your back window he'll write you a ticket regardless of whether your side windows work or not. He could also charge you with failure to comply if he doesn't believe your story about the windows inop.
I live in MN and the troopers here are tint Nazi's too. Nothing you can do about it. It's an easy ticket to write and write it they will.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
#4525067 - 09/24/17 05:46 PM Re: how to shut off window motor power [Re: mobilaltima]
KrisZ Offline
Loc: Toronto, Canada
Splicing in a switch to the positive cable that goes into the up/down windows switch would be my choice. The wire should be accessible under the driver's side kick panel.
2015 Dodge Grand Caravan-21k miles.
2006 Mazda 3-155k miles
#4525074 - 09/24/17 05:54 PM Re: how to shut off window motor power [Re: mobilaltima]
skyactiv Offline
Loc: The Midwest
It can be done. Don't expect a how to tutorial online. You could get real ghetto and tap into the fuse with an add a circuit and run a switch somewhere. BUT, expect a vehicle search when your windows can't be rolled down and a cop thinks you have China White behind the door panels. Depending on your criminal background, find an MD that will sign off on the form for your heat exhaustion problem your having.
http://www.lsp.org/pdf/WindowTintExemption-Medical.pdf Find the appropriate World Health Organization International Classification of Disease ICD- 9-CM code which is T67.6.
Make a DR appointment at a pill mill if you got to. Don't shower the night before, don't wear deodorant and mow a lawn before the appointment.
Edited by skyactiv (09/24/17 05:54 PM)
Edit Reason: omitted a word
Me: 13' VW GTI 3 door 6 speed manual
#4525107 - 09/24/17 06:24 PM Re: how to shut off window motor power [Re: mobilaltima]
JHZR2 Offline
Loc: New Jersey
Seriously?
