Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
104 registered members (-SyN-, andyd, 4WD, 97prizm, 14Accent, 11 invisible), 2,111 guests, and 41 spiders.
Topics295,223
Posts4,930,346
Members66,716
Most Online2,553
Oct 27th, 2018
Clutch Engagement Point very beginning of pedal? #4524715
09/24/17 09:47 AM
09/24/17 09:47 AM
Midwest USA
LoneRanger Offline OP
Midwest USA
What does it indicate when the clutch engagement point, when it hooks up, is right at the beginning of the pedal's travel such as you're bringing the pedal up from floor and it doesn't hook up until right near the end when it's time for your foot to come off? Pedal feels fine, not soft or hard, just steady.
'09 Subaru Forester ...................(QS HM 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
Re: Clutch Engagement Point very beginning of pedal? [Re: LoneRanger] #4524721
09/24/17 09:53 AM
09/24/17 09:53 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Like the animation on this page?
http://www.angelfire.com/al4/drive/
Re: Clutch Engagement Point very beginning of pedal? [Re: LoneRanger] #4524724
09/24/17 09:54 AM
09/24/17 09:54 AM
New York
pbm Online content
pbm  Online Content
New York
Is there any adjustment possible?
I hate that even more than when it engages near the floor (as soon as you start coming up from the floor.)
'Journalism is Dead'
Re: Clutch Engagement Point very beginning of pedal? [Re: Reddy45] #4524732
09/24/17 09:59 AM
09/24/17 09:59 AM
Midwest USA
Midwest USA
Yes, except without the extra release travel after hook-up. Hook-up like right at the end of release travel or something.
Hydraulic clutch, should have mentioned. Would say air bleed but pedal travel feels steady and consistent, just the engagement point seems to have moved out?
Re: Clutch Engagement Point very beginning of pedal? [Re: LoneRanger] #4524743
09/24/17 10:13 AM
09/24/17 10:13 AM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
Usually means the clutch is nearing the end of it's life and the friction material on the disk and pressure plate is used up; as it wears away, the fingers on the pressure plate will actually move outward and the release fork will also move outward to compensate for the space that was once occupied with friction material. So the pressure plate/clutch fork/release bearing will actually travel more - hence engaging at the top of the pedal.
If it's bothering you, you can likely adjust the master cylinder push rod where it hooks to the pedal; you'd want to take out some length in the pushrod, and then adjust the pedal height down. But you'd have to readjust it to where it was when/if you need to get a new clutch.
Been through this very thing with my Corolla. After getting a new clutch, it engages right off the floor and had to readjust the master cylinder pushrod and pedal height to get some more travel.
Re: Clutch Engagement Point very beginning of pedal? [Re: LoneRanger] #4524747
09/24/17 10:19 AM
09/24/17 10:19 AM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
Another possibility is there isn't enough freeplay in the pedal and at rest, the master cylinder piston is blocking the port to the reservoir and after driving, you're getting what's called "clutch pump up"
http://forums.nicoclub.com/clutch-engagement-point-moves-up-as-car-warms-t361456.html
"I've got the exact same thing going on with my '90. I actually replaced the clutch thinking it might have been the pressure plate, but that didn't fix it. I've got a new (within 6 months) master and slave and a stainless steel braided clutch line. I haven't removed the damper box yet.
The big thing I'm trying to figure out is if it's in the hydraulics or something else. maybe something going on with the fork?
Edit:
Looks like there are a lot of people having this problem. 2g DSMs apparently had a problem called "pump-up". This occurred due to poor adjustment of the clutch rod. If the rod was adjusted so that it's too far out, there's a valve that will never release and pressure just keeps building every time the clutch is depressed. I don't know how our cylinder's compare, but it sounds pretty close.
Here's a link: http://www.roadraceengineering...h.htmCheck 3/4 down the page.
Some others:
http://www.3si.org/forum/f35/c...97157/ ... tchadj.htm -- This one looks good.
Modified by Spectre_240sx at 12:34 AM 9/23/2008"
Re: Clutch Engagement Point very beginning of pedal? [Re: LoneRanger] #4524765
09/24/17 10:36 AM
09/24/17 10:36 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I'd try bleeding it and see if it improves. OTOH as mentioned the clutch might be nearing the end of its life.
God Bless Our Troops
Re: Clutch Engagement Point very beginning of pedal? [Re: Drew99GT] #4524777
09/24/17 10:57 AM
09/24/17 10:57 AM
NorCal
Seventh Offline
Seventh  Offline
NorCal
+1
Re: Clutch Engagement Point very beginning of pedal? [Re: LoneRanger] #4524863
09/24/17 12:24 PM
09/24/17 12:24 PM
Reddy45 Offline
Reddy45  Offline
Is this your Moto Guzzi or a car? If it's the bike then you may have some adjustments since it is hydraulic. I know on bikes with cable clutches, you can't adjust the bite point unless you buy some expensive compound lever.
Re: Clutch Engagement Point very beginning of pedal? [Re: LoneRanger] #4525026
09/24/17 03:59 PM
09/24/17 03:59 PM
Midwest USA
Midwest USA
My Forester actually, which is hydraulic as well.
