Water Pump Paper Gasket With RTV? Longevity?
by nobb
19 minutes 24 seconds ago
Who makes Briggs & Stratton oil?
by spk2000
28 minutes 40 seconds ago
Shure stylus replacement
by aquariuscsm
47 minutes 25 seconds ago
Any 'crazy UCL overdose' fans out there?
by addyguy
Today at 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
Today at 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
Today at 06:27 PM
Why buy low mileage tires?
by HowAboutThis
Today at 05:49 PM
Mercury 35-8M0065104 cut open w/ oil change pics
by dlundblad
Today at 05:37 PM
2019 Honda’s miniMOTOs (125cc)
by DuckRyder
Today at 05:18 PM
Car Sales Scammers on Letgo
by ZZman
Today at 04:18 PM
Air shocks or Timbren for trailer towing ?
by Oldtom
Today at 04:10 PM
Which coil for a 2002 Focus Zetec?
by slacktide_bitog
Today at 04:07 PM
Blink -Roadside assistance, any experience?
by MoneyJohn
Today at 03:22 PM
Some garage art!
by ls1mike
Today at 03:12 PM
California Law
by PiperOne
Today at 02:37 PM
honda vs tyc a/c condenser?
by researcher
Today at 02:31 PM
To all the Fathers out there.
by rollinpete
Today at 01:37 PM
'14 Mercedes E350 Coupe - Castrol Edge 0w40
by FlyPenFly
Today at 01:08 PM
2007 Chrysler 4.0L SOHC engine - why 10w-30 req'd?
by 92saturnsl2
Today at 12:54 PM
you can see my crack when I dismount a tire
by eljefino
Today at 12:44 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
85 registered (4WD, 330indy, 08z06, 2009Edge, alcyon, 12 invisible), 1514 Guests and 43 Spiders online.
65258 Members
67 Forums
285491 Topics
#4524652 - 09/24/17 09:39 AM Battery Switch on Boat
Sierra048 Offline
Loc: N. Georgia Mtns
I wasn't sure what forum to post this in so please move if necessary.
I would like to add an additional battery, with a battery switch, to our new pontoon boat. I've researched switches and will probably go with a Perko Battery Selector Swich.
https://cdn3.bigcommerce.com/s-6rtev5oww...80.1280.jpg?c=2
All I really want to do is have an extra battery aboard for Emergecy back-up that I can switch to if necessary and charge both while the engine is running. Except for starting power, and running courtesy and nav lights (which wouldn't be very often, if at all) the stereo radio would be the only other draw. I've read some articles where people will use one battery for starting and another battery for lights and/or accessories. I don't think I would need that and I might be wrong but that would also entail some rewiring. I'm thinking that all I need is a back-up I can switch too should my primary battery lose its charge. This a pontoon boat, not a yacht. Has anyone ever set up a battery switch like this? If so, how did you wire it up. Any thoughts and suggestions would be welcomed.
Edited by Sierra048 (09/24/17 09:41 AM)
#4524660 - 09/24/17 09:49 AM Re: Battery Switch on Boat [Re: Sierra048]
JHZR2 Offline
Loc: New Jersey
I like that switch because it looks like it lets you run on either or both batteries.
You'll need to be smart about charging, cycling and balancing batteries with the approach you propose.
#4524741 - 09/24/17 11:10 AM Re: Battery Switch on Boat [Re: JHZR2]
Sierra048 Offline
That's just what I was thinking off the top of my head. I am open to suggestions. I am also limited with my options when not using the boat as far as keeping the batteries charged. There are no outlets for a battery charger at the covered marina we're at. So I'll probably have to remove one and take it home with me if there is any lengthy time away from the boat. Frustrating but that"s what we have to deal with.
2014 Nissan Frontier
2014 GMC Sierra 1500
#4524776 - 09/24/17 11:56 AM Re: Battery Switch on Boat [Re: Sierra048]
Linctex Offline
Loc: Waco, TX
You really just need one of these for $30.
"Human Factors" dictates you'll leave your switch int the wrong position someday.
This takes all the error out of it, and is automatic.
https://www.etrailer.com/Accessories-and-Parts/Deka/DW08770.html
#4524952 - 09/24/17 03:14 PM Re: Battery Switch on Boat [Re: Sierra048]
wrcsixeight Offline
Loc: california
The product above is basically a diode, Those large heatsinks are basically dissipating alternator energy while that Diode/ electical check valve reduces the voltage to the second battery, slowing its recharge time significantly, and basically insuring it never gets fully recharged. People who care about their battery's longevity do not use diode based isolators.
The 1/2/BOTH/Off switches do have the human error factor, and if turned to OFF while the engine is running can blow the diodes in the alternator.
There are many dozens of automatic isolation products for secondary batteries out there.
I use the manual switch, the Blueseas 6007m. My previous switch that wore out after many years was a Guest brand.
For good battery life, the battery must be recharged to a full state of charge every so often and would prefer to always be cool, and 1005 charged. It takes no less than 3.5 hours for a healthy battery to go from 80% charged to 100% charged, and that is assuming a high absorption voltage of 14.4v+. So lesser voltages will increase that time considerably and that time also increases as the battery ages.
If thievery is not an issue where you store your boat, then consider a small solar panel to keep the batteries full, but even 10 watts with enough time is enough to seriously overcharge a battery that has no loads on it.
Some good reading:
https://forums.sailboatowners.com/index.php?threads/1-both-2-off-switches-thoughts-musings.137615/
http://www.pbase.com/mainecruising/boat_projects
https://www.youtube.com/watch?v=z5RtZe9AW2E&index=9&list=UUoPqTkOluQsuu3RpGnxVwFw
LA 318 Roller Cam
M1 0w-40
Fram ultra XG8A
Fram Ultra XG16 on remote transmission filter mount
#4525075 - 09/24/17 05:54 PM Re: Battery Switch on Boat [Re: Sierra048]
ArcticDriver Offline
Loc: USA
Can't you accomplish your goal by simply having two batteries in parallel? We have dual batteries on all of our boats with a switch allowing both ON, both OFF and the choice of Bank-1 or Bank-2 only but all we ever use is both ON and both OFF.
It is our experience the batteries that stay equally charged have the longest combined health.
Multiple Diesel and Gasoline vehicles
#4525087 - 09/24/17 06:07 PM Re: Battery Switch on Boat [Re: ArcticDriver]
SOHCman Offline
Loc: USA
This, isn't this how diesel trucks do it?
If you want to do the whole "I'm a complete drop-kick" thing properly, they're the cars you drive, complete with the "doof-doof" sound system, loud exhaust, low profile tires and so on. -B320i
#4525093 - 09/24/17 06:10 PM Re: Battery Switch on Boat [Re: Sierra048]
Donald Offline
Loc: Upstate NY
A pontoon boat is not in the same situation as a boat going 20 miles out into the ocean. But here is how a boat going into the ocean might wire things.
The best solution would be to alter the wiring to have the stereo and other non critical loads run off a house battery and have the engine run off a starting battery and install a "combiner" that combines them when the engine is running.
2015 Ford F250 w/Powerstroke
#4525114 - 09/24/17 06:28 PM Re: Battery Switch on Boat [Re: Sierra048]
JHZR2 Offline
Loc: New Jersey
That's a bit more of an issue. What's your plan for recharge, especially on the one used for hotel loads? I know you said take it home, but what's more important is how to make that convenuent. Hopefully your plan includes an easy access hatch and quick disconnects of some kind in order to bring them home and charge them right...
#4525147 - 09/24/17 07:14 PM Re: Battery Switch on Boat [Re: Sierra048]
Loc: USA
Do you ever use this pontoon forum?
http://www.pontoonforums.com/viewtopic.php?f=2&t=11132
http://www.pontoonforums.com/viewtopic.php?f=2&t=23547
In the system I described earlier you can isolate power draw to Bank-1 or Bank-2.
This would allow you to keep both batteries functioning while under power and charging and then turn off one with a full charge for starting while you are using the second for recreating. Its the typical wiring for watercraft.
Search "
Blue Sea"
#4525592 - 09/25/17 09:32 AM Re: Battery Switch on Boat [Re: Sierra048]
Sierra048 Offline
First of all, thanks to everyone who offered help and suggestions.
I have to be honest here, this has become more complicated than I wanted. I spent a good portion of the weekend reading and watching videos. I have seen some extremely exotic, and expensive set-ups, that are really impressive but for me I think overkill. Granted most of these set-up serviced a lot more elaborate situations than mine. As I mentioned in my opening post, I doubt that I'll ever really use any nav or courtesy lights, leaving the gauges and the radio as the only power draws after the engine is started. I did take the time to read all the links you posted. Thanks for linking the info. While adding VSRs and other automatic switching/isolating components might be nice, I just think that's making it more complicated and expensive. This is a lake pontoon boat. If I was talking about an ocean going vessel I would be more open to these types of things. So to simplify things please help me consider these two options:
1) If this is feasable, just buy a second battery, hook them up parallel, utilize the additional power for basically using the radio while anchored, while recharging both when running the engine.
2) Install this:
And accomplish the same goal as #1 with the additional requirement of having to turn the switch to the back-up battery if needed, or to dual charge them. From what I've read, this set up would protect one battery from being damaged should the other one go bad from being wired in parallel.
If I'm wrong please let me know. I'm no expert. I was actually amazed at how complicated battery technology and application can be.
#4525619 - 09/25/17 09:49 AM Re: Battery Switch on Boat [Re: Sierra048]
mk378 Offline
Loc: USA
With that simple setup you have to remember to switch to "both" when the engine is running so that both batteries get charged. Then remember to switch off of "both" while at anchor playing the stereo so that only one battery is running down. If you forget and leave the switch on "both" and run stuff connected to battery 2, battery 1 will also discharge and you may not be able to start the engine.
The isolator contains two big diodes. It would automatically direct the power from the alternator mostly into whichever battery is run down more, regardless of the switch setting. Having two diodes means that the voltage drop is balanced between the batteries.
Wiring an isolator requires bringing the alternator output out of the engine separately. This is very simple on inboard engines with an automotive type alternator, but with an outboard you will need to consult the manufacturer's recommendations.
The isolator setup is very useful since you could leave the switch on "1" for the whole cruise and start and stop the engine as much as you want, without thinking about batteries at all. If battery #2 runs down, the engine still starts from #1.
If you can't charge at the dock you should remove battery 2 from the boat and take it home to charge after each trip. Don't count on a few minutes of alternator charging to recover from a deep cycle of using the lights and stereo.
Edited by mk378 (09/25/17 09:55 AM)
#4526508 - 09/26/17 09:14 AM Re: Battery Switch on Boat [Re: mk378]
Sierra048 Offline
So your opinion is to take option #2 and add an isolator into the set-up? Does anyone have a diagram of how that would be wired? I do like the fact this set-up would decide on/manage the charging requirements between the two batteries automatically. I perused the Blue Sea website and I'll send them some questions on how best to move forward with their products and this set-up.
