sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
85 registered members (antonmnster, 53' Stude, amblerman, A310, 69GTX, 7 invisible), 1,905 guests, and 38 spiders.
Topics295,101
Posts4,927,813
Members66,684
Most Online2,553
Oct 27th, 2018
Shell AV-L ECT C2C3 0w30 vs Ravenol SSO 0w30 #4524503
09/24/17 02:01 AM
09/24/17 02:01 AM
Poland
Janusz Offline OP
Janusz  Offline OP
Poland
engine oil for VW 1.8tfsi (0w30, API SN, ACEA A3 v C3) and these two are taken into account.
I know that shell is vw504 and ravenol vw502 but I keep 15000 km intervals so you can use any of them.
Looking at the voa, I have a question: will Bor compensate lower levels of Zinc and Phosphor ?
'14 Superb 1.8tfsi (Shell Helix Ultra Professional AV-L 0W-30)
'98 VFR800FI (Valvoline SynPower 4T 10w-50)
Re: Shell AV-L ECT C2C3 0w30 vs Ravenol SSO 0w30 [Re: Janusz] #4525348
09/24/17 10:34 PM
09/24/17 10:34 PM
Albury, NSW
JFAllen Offline
JFAllen  Offline
Albury, NSW
You'll have to forgive me as my Cyrillic isn't great...
I've been using this oil in my Saab 9-5 turbo for the last year, but have had to shorten OCI to 7,500kms. The Saab 2.3T uses about 1 litre every 6-7,000kms, so it makes sense to swap the whole lot out.
The only effect I've noticed since I've had 4 sumps of that oil though my car is that oil consumption has been reduced (I'm guessing better ring seal through de-gunking.) Ant my fuel economy has improved ~10%. It's one of a few 0W30 oils with a HTHS of >3.5. Not to mention it's +200 viscosity index.Inspections of the cams and lifters have show no additional wear or scuffing since I've owned the car and been using that oil.
Boron additives fall under the calls of EP and AW additives, and work by producing a hard 'borate film.' They also have detergency and anti acid properties. Shell have decided to go this way vs Moly, for whatever reason in this particular blend.
Regards
Jordan
Re: Shell AV-L ECT C2C3 0w30 vs Ravenol SSO 0w30 [Re: JFAllen] #4525443
09/25/17 05:31 AM
09/25/17 05:31 AM
Poland
Janusz Offline OP
Janusz  Offline OP
Poland
Originally Posted By: JFAllen
I've been using this oil ...
I guess you write about shell, but please confirm that ?
Re: Shell AV-L ECT C2C3 0w30 vs Ravenol SSO 0w30 [Re: Janusz] #4526013
09/25/17 04:23 PM
09/25/17 04:23 PM
Albury, NSW
JFAllen Offline
JFAllen  Offline
Albury, NSW
Yes, I use SHU: 0W30 ECT C2/C3. (Same as PP Euro LX 0W30 in the states)
