Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
35 registered members (Bailes1992, 2015_PSD, bullwinkle, askani79705, 92saturnsl2, 53' Stude, 3 invisible), 815 guests, and 35 spiders.
Topics290,699
Posts4,848,487
Members66,021
Most Online3,590
Jan 24th, 2017
Motorcycle Tire Direction question? #4524381
09/23/17 10:02 PM
09/23/17 10:02 PM
VA
maverickfhs Offline OP
VA
For a front wheel on the motorcycle, arrow direction on the wheel is opposite to the tire. While I tried my best to make sure it's going properly, but oh well mistake happened!
Question is, can I install in the right direction of wheel and opposite direction of tire? So can tire be installed in opposite direction of it's directional arrow?
If not, no biggie and I'll just change the direction of tire!
Thanks for the advice thumbsup
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: Motorcycle Tire Direction question? [Re: maverickfhs] #4524395
09/23/17 10:17 PM
09/23/17 10:17 PM
Deep in the heart of Jersey
BigCahuna Offline
BigCahuna  Offline
Depends if you have one rotor or two. If it has two, remove wheel slide axle back in so the arrow is on the top side of the tire facing forward, as viewed from the right side of the bike. If it only has one rotor, you mave have to unmount the tire so the arrow is the same as mentioned above.,,,
Re: Motorcycle Tire Direction question? [Re: maverickfhs] #4524396
09/23/17 10:19 PM
09/23/17 10:19 PM
VA
VA
It has 2 rotors, but rotors won't slide into pads properly if I use the direction of tire. Have a look on the picture.
As you can see direction on the wheel and tire arrows are in opposite direction:
Re: Motorcycle Tire Direction question? [Re: maverickfhs] #4524410
09/23/17 10:37 PM
09/23/17 10:37 PM
BigCahuna Offline
BigCahuna  Offline
You have to push the pads back into the calipers, to get the disks back in place. It will probably be easier to remove the calipers , put the wheel and axle in, tighten the axle nuts, then slide the calipers over the discs.,,
Re: Motorcycle Tire Direction question? [Re: maverickfhs] #4524472
09/24/17 12:39 AM
09/24/17 12:39 AM
The Canyons
02SE Offline
02SE  Offline
The Canyons
Some wheels have the rotors offset slightly from one side to the other, so the wheel can't be installed running backwards. IIRC, your R1 is one of the wheels. Some wheels are also directional in consideration of other design factors, as are some rotors.
As for the tire, there's water clearing, but there's also the tread splice to consider. The tire's integrity is better rolling in the direction it was designed to. Especially if you plan to ever use that R1's capability.
If it were me, I'd take the tire off and re-mount it correctly.
Re: Motorcycle Tire Direction question? [Re: maverickfhs] #4524483
09/24/17 01:09 AM
09/24/17 01:09 AM
The Canyons
02SE Offline
02SE  Offline
The Canyons
That is to say that if the wheel is installed backwards, on some bikes the wheel will be offset, thus the rotors will be offset.
Re: Motorcycle Tire Direction question? [Re: maverickfhs] #4524528
09/24/17 05:39 AM
09/24/17 05:39 AM
VA
VA
Thanks guys. I'll remount the tire again. No biggie.
